PCS.06.A
PCS.06.A
    TAOGLASLIMITED
    低剖面SMD LTE/cellular 4G/3G/2G嵌入式天线,设计用于直接SMD安装在设备PCB上。它在非常小的尺寸42*10*3mm下提供高效率。
PCS.06.A 数据手册
Havok Part No: PCS.06.A Description: Low Profile LTE/Cellular 4G/3G/2G SMD Dielectric Antenna Features: SMD Dielectric Antenna 698~960MHz/1710~2690MHz High Efficiency SMD antenna Low profile 42*10*3mm RoHS & REACH Compliant SPE-13-8-070-Q 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 6 4. Radiation Patterns 9 5. Mechanical Drawing 18 6. Antenna Intergration Guide 19 7. Solder Reflow Profile 27 8. Packaging 28 9. Application Note 30 Changelog 32 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-13-8-070-Q www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. The Havok PCS.06.A is a low profile SMD LTE/cellular 4G/3G/2G embedded antenna designed for direct SMD mount on a device PCB. It provides high efficiency in a very small factor 42*10*3mm. If tuning is required it can be tuned for the device environment, while there is no need for new tooling. 1. Its rectangular shape and small size makes it very easy to integrate – packaged in tape and reel, it can be mounted via pick and place to reflow solder directly on the edge of the PCB board. This antenna is recommended to be used with long ground-plane lengths of 120mm or more to attain its highest rated efficiency, note the return loss and efficiency graphs. 1. 1. Introduction Introduction Introduction Typical Applications Include: - Connected Health - Handheld Devices - Wearables Introduction The antenna is suitable for lower cost LTE/cellular applications due to the ease of integration. Contact your regional Taoglas customer support team for quick and professional support from our senior engineering team on integration and matching of the antenna to your device. SPE-13-8-070-Q www.taoglas.com 3 2. Specifications ELECTRICAL (MHz) 698~803 824~894 880~960 1710~1880 1850~1990 3.Frequency Antenna Characteristics2. Specifications Peak Gain (dBi)* Average Gain (dBi)* 1.1 -2.6 Efficiency (%)* 56 1.3 -2.0 63
PCS.06.A 价格&库存
很抱歉,暂时无法提供与“PCS.06.A”相匹配的价格&库存,您可以联系我们找货
PCS.06.A
    PCS.06.A
