SPECIFICATION
Part No.
AA.162.301111
Product Name
Ulysses Ultra-Low Profile Miniature Magnet Mounted
GPS-GLONASS Antenna
Feature
1575MHz – 1610MHz
40mm*38mm*10mm
1.8-5.5V
3m RG174 SMA(M)
IP67 Rated
Custom cables and connectors available
RoHS
SPE-12-8-148/D/SS
Page 1 of 15
1. Introduction
The Ulysses miniature super low profile (only 10mm in height) GNSS antenna is designed for
applications which require high positioning accuracy by combining signals from GPS and
GLONASS systems. A high gain wide-band patch antenna on an integral ground delivers
reliable performance. Fully IP67 waterproof rating allows use in outdoors environments. Front
end SAW filter configuration eliminates potential LNA burn-out from nearby out of band
radiated power bursts from other antennas that may be co-located nearby.
The antenna is manufactured to strict first tier Automotive quality controlled manufacturing
process in TS16949 approved facility.
SPE-12-8-148/D/SS
Page 2 of 15
2. Specification
ELECTRICAL
Centre Frequency
VSWR
1574~1610MHz
26±3dBic @ zenith @ 1575.42MHz
27±3dBic @ zenith @ 1602MHz
2.0 max.
Impedance
50Ω
Outer Band Attenuation
Pout at 1dB Gain
Compression Point
DC input
1592±140MHz 15dB Min
1.8V (min.)
3.0V (typ.)
5.5V (max.)
LNA Gain
22dB
28dB
31dB
Noise Figure
2.6dB
2.6dB
2.9dB
Power Consumption
5mA
10mA
23mA
Antenna Gain
-6dBm Min. -2dBm Typ.
MECHANICAL
Antenna Dimensions
37.8 x 40.4 x 10mm
Housing Material
UV Resistant ABS
Cable
3m RG174 (fully customizable)
Connector
SMA(M) (fully customizable)
ENVIRONMENTAL
Operation Temperature
-40°C to 85°C
Storage Temperature
-40°C to 85°C
Relative Humidity
40% to 95%
SPE-12-8-148/D/SS
Page 3 of 15
3. Antenna Block Diagram
SPE-12-8-148/D/SS
Page 4 of 15
4. Antenna S11 Property
4.1 Return Loss
SPE-12-8-148/D/SS
Page 5 of 15
4.2 Impedance
SPE-12-8-148/D/SS
Page 6 of 15
4.3 VSWR
SPE-12-8-148/D/SS
Page 7 of 15
5. Radiation Patterns
SPE-12-8-148/D/SS
Page 8 of 15
1575.42MHz YZ Plane
SPE-12-8-148/D/SS
Page 9 of 15
1602MHz XZ Plane
SPE-12-8-148/D/SS
Page 10 of 15
1602MHz YZ Plane
SPE-12-8-148/D/SS
Page 11 of 15
6. LNA Gain and Output Band Rejection @3.0V
SPE-12-8-148/D/SS
Page 12 of 15
7. LNA Noise Figure @3.0V
SPE-12-8-148/D/SS
Page 13 of 15
8.Drawing
SPE-12-8-148/D/SS
Page 14 of 15
9.Packaging
SPE-12-8-148/D/SS
Page 15 of 15
很抱歉,暂时无法提供与“AA.162.301111”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+259.457571+33.72166
- 10+226.5743810+29.44784
- 30+213.0003630+27.68363
- 100+199.52811100+25.93264
- 250+190.17607250+24.71716
- 国内价格 香港价格
- 100+139.47851100+18.12800
- 国内价格 香港价格
- 1+291.904531+37.93879
- 10+187.3819310+24.35400
- 30+185.5199630+24.11200
- 100+166.90025100+21.69200
- 250+165.03828250+21.45000
- 国内价格 香港价格
- 1+198.046001+25.74001
