TG.30.8113W
TG.30.8113W
    TAOGLASLIMITED
    TG.30.8113W
TG.30.8113W 数据手册
SPECIFICATION PATENT PENDING Part No. : TG.30.8113W Product Name : Apex White Hinged TG.30 Ultra-Wideband 4G LTE Antenna Feature : LTE / GSM / CDMA /DCS /PCS / WCDMA / UMTS / HSDPA / GPRS / EDGE /GPS /Wi-Fi 698MHz to 960MHz, 1575.42MHz 1710MHz to 2700Mhz Typical 70%+ Efficiency and 3dBi+ Peak Gain Dipole Swivel Terminal Antenna Hinged 90° termination with SMA(M) Connector RoHS Compliant SPE-12-8-125/A/WY Page 1 of 40 1. Introduction The hinged Apex TG.30 Ultra-Wideband Dipole LTE Antenna – is primarily designed for use with 4G LTE modules and devices that require the highest possible efficiency and peak gain to deliver best in class throughput on all major cellular (2g/3g/4g) bands worldwide for access points, terminals and routers. The antenna is a ground plane independent antenna with a SMA (M) connector and swivel mechanism that allows the antenna part to be rotated. The Apex exhibits high efficiency across the ultra wide band and is backward compatible with 2G and 3G cellular applications such as GSM, LTE, UMTS, WI-FI and even has GPS included for Assisted GPS and/or E911 applications. With very high efficiency on every cellular band globally it is an ideal solution for any device requiring high, reliable performance. It is also guaranteed to meet any type approval or carrier certification requirements from a RF standpoint. It is an omni-directional antenna and the radiation patterns display this and are stable across all bands. It has a quality robust IP67 UV resistant housing (SMA connector is IP65) for use with wireless terminals. The swivel and hinge mechanism allows the antenna part itself to be orientated in different directions and can help avoid touching off other antennas or objects close by as well as helping with isolation by orientating the antenna in different directions in MIMO systems for when other TG.30 antennas are present on the same device. This patent pending antenna is available in White and Black versions. The antenna blade can swivel 90 degrees from the connector accommodating different installation environments. It is also available with Straight and Right Angle connectors. SPE-12-8-125/A/WY Page 2 of 40 2. Specification ELECTRICAL Frequency (MHz) 700~800 824~960 1575.42 1710 ~ 1880 1850 ~ 1990 1710 ~ 2170 2400~2800 Peak Gain (dBi) Free Space Straight 1.1 0.3 1.1 1.9 2.7 2.6 2.7 Free Space Bent 2.6 1.5 2.9 2.7 3.1 3.1 2.0 2.1 0.7 2.9 1.5 1.9 2.0 2.9 3.5 1.7 5.2 5.9 6.7 6.4 4.9 2.6 1.3 1.7 2.1 2.1 2.3 4.3 Bent 2.6 1.8 3.1 2.1 3.0 2.8 5.1 PCB edge Straight 1.4 1.2 0.9 2.5 3.2 3.0 1.4 PCB edge Bent 2.1 0.1 2.1 2.4 3.6 3.4 3.0 Straight -1.1 -2.2 -2.0 -1.5 -1.2 -1.3 -3.5 Free Space Bent -1.1 -2.3 -1.5 -1.5 -1.1 -1.2 -3.1 -0.6 -1.6 -2.0 -1.8 -1.7 -1.7 -3.8 -3.5 -4.9 -2.8 -2.4 -1.8 -2.0 -3.0 -0.6 -1.5 -1.9 -1.6 -1.4 -1.4 -3.1 Bent -0.6 -1.7 -1.6 -1.5 -1.2 -1.3 -3.1 PCB edge Straight -1.0 -2.0 -2.0 -1.6 -1.4 -1.4 -3.5 PCB edge Bent -0.8 -2.5 -1.6 -1.5 -1.1 -1.3 -3.0 30x30cm GP center Straight 30x30cm GP center Bent 30x30cm GP edge Straight 30x30cm GP edge Average Gain (dB) Free Space 30x30cm GP center Straight 30x30cm GP center Bent 30x30cm GP edge Straight 30x30cm GP edge SPE-12-8-125/A/WY Page 3 of 40 ELECTRICAL Frequency (MHz) 700~800 824~960 1575.42 1710 ~ 1880 1850 ~ 1990 1710 ~ 2170 2400~2800 Efficiency (%) Free Space Straight 79 61 63 71 76 75 45 Free Space Bent 78 60 70 72 78 75 49 86 69 62 66 67 68 42 47 32 51 58 66 64 51 88 70 65 69 72 72 49 Bent 88 67 69 70 76 74 49 PCB edge Straight 80 63 63 69 73 73 45 PCB edge Bent 83 57 70 71 77 75 50 30x30cm GP center Straight 30x30cm GP center Bent 30x30cm GP edge Straight 30x30cm GP edge Impedance 50Ω Polarization Linear Radiation Pattern Omni Input Power 10 W MECHANICAL Casing UV Resistant PC/ABS Connector SMA Male Hinged 90° ENVIRONMENTAL Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-12-8-125/A/WY Page 4 of 40 3. Antenna Characteristics 3.1 Return Loss SPE-12-8-125/A/WY Page 5 of 40 3.2 Peak Gain SPE-12-8-125/A/WY Page 6 of 40 3.3 Average Gain SPE-12-8-125/A/WY Page 7 of 40 3.4 Efficiency SPE-12-8-125/A/WY Page 8 of 40 4. Antenna Radiation Patterns 4.1 Antenna setup (Free Space Straight) y z x Radiation Patterns XY plane SPE-12-8-125/A/WY Page 9 of 40 SPE-12-8-125/A/WY Page 10 of 40 XZ plane SPE-12-8-125/A/WY Page 11 of 40 4.2 Antenna setup (Free Space Bent) y z x SPE-12-8-125/A/WY Page 12 of 40 Radiation Patterns XY plane SPE-12-8-125/A/WY Page 13 of 40 XZ plane SPE-12-8-125/A/WY Page 14 of 40 SPE-12-8-125/A/WY Page 15 of 40 4.3 Antenna setup (On 300x300mm ground center straight) SPE-12-8-125/A/WY Page 16 of 40 Radiation Patterns XY plane SPE-12-8-125/A/WY Page 17 of 40 XZ plane SPE-12-8-125/A/WY Page 18 of 40 SPE-12-8-125/A/WY Page 19 of 40 4.4 Antenna setup (On 300x300mm ground center bent) Radiation Patterns XY plane SPE-12-8-125/A/WY Page 20 of 40 SPE-12-8-125/A/WY Page 21 of 40 XZ plane SPE-12-8-125/A/WY Page 22 of 40 4.5 Antenna setup (On 300x300mm ground edge straight) SPE-12-8-125/A/WY Page 23 of 40 Radiation Patterns XY plane SPE-12-8-125/A/WY Page 24 of 40 SPE-12-8-125/A/WY Page 25 of 40 XZ plane SPE-12-8-125/A/WY Page 26 of 40 4.6 Antenna setup (On 300x300mm ground edge bent) SPE-12-8-125/A/WY Page 27 of 40 Radiation Patterns XY plane SPE-12-8-125/A/WY Page 28 of 40 SPE-12-8-125/A/WY Page 29 of 40 XZ plane SPE-12-8-125/A/WY Page 30 of 40 4.7 Antenna setup (On Ground edge straight) SPE-12-8-125/A/WY Page 31 of 40 Radiation Patterns XY plane SPE-12-8-125/A/WY Page 32 of 40 XZ plane SPE-12-8-125/A/WY Page 33 of 40 SPE-12-8-125/A/WY Page 34 of 40 4.8 Antenna setup (On Ground edge bent) Radiation Patterns XY plane SPE-12-8-125/A/WY Page 35 of 40 SPE-12-8-125/A/WY Page 36 of 40 XZ plane SPE-12-8-125/A/WY Page 37 of 40 SPE-12-8-125/A/WY Page 38 of 40 5. Mechanical Drawing SPE-12-8-125/A/WY Page 39 of 40 6. Packaging Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © 2012, Taoglas Ltd. SPE-12-8-125/A/WY Page 40 of 40
TG.30.8113W
PDF文档中的物料型号为MAX31856KASA+,这是一款由Maxim Integrated生产的热电偶数字冷端补偿放大器。
器件简介指出,它具有高精度和低噪声的特性,支持多种热电偶类型。
引脚分配包括VCC、GND、SCK、CS、SDI、SDO和THERM,分别用于供电、接地、时钟信号、片选、串行数据输入、串行数据输出和热电偶接口。
参数特性包括供电电压范围、功耗、温度范围和精度。
功能详解说明了其内部结构和工作原理,包括冷端补偿、热电偶类型选择和数字滤波。
应用信息涵盖工业过程控制、医疗设备和环境监测。
封装信息显示该器件采用28引脚TSSOP封装。
TG.30.8113W 价格&库存
很抱歉,暂时无法提供与“TG.30.8113W”相匹配的价格&库存,您可以联系我们找货
TG.30.8113W
  • 10+57.45645
  • 40+56.41662
  • 80+55.28007
  • 100+53.18832
库存:245
TG.30.8113W
    • 1+175.46760
    • 200+70.01640
    • 500+67.67280
    • 1000+66.51720
    TG.30.8113W
    • 1+123.387771+15.99341
    • 10+97.2330110+12.60325
    • 50+86.7483150+11.24424
    • 100+83.50315100+10.82360
    • 250+80.07601250+10.37938
    • 500+78.01093500+10.11171
    • 1000+76.311471000+9.89142
    库存:675
    TG.30.8113W
    • 1+88.652681+11.49108
    • 40+65.6153640+8.50500
    • 80+64.3192680+8.33700
    • 100+61.88906100+8.02200
    库存:179
