TG.30.8113
TG.30.8113
    TAOGLASLIMITED
    TG.30.8113
TG.30.8113 数据手册
Apex Hinged TG.30 Part No: TG.30.8113 Features: 600-6000MHz Covers 5G/4G Bands Typical 50%+ Efficiency and 3dBi+ Peak Gain Dipole Swivel Terminal Antenna Hinged 90° termination with SMA(M) Connector RoHS and REACH Compliant SPE-12-8-124-L 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 7 4. Radiation Patterns 9 5. Mechanical Drawing 75 6. Packaging 76 Changelog 77 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-12-8-124-L www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. The hinged Apex TG.30 is a Wideband Dipole 5G/4G Antenna – is primarily designed for use with 5G/4G modules, routers and devices that require the highest possible efficiency and peak gain to deliver best in class throughput on all major cellular bands worldwide between 600MHz and 6GHz. 1. The antenna is a ground plane independent antenna with a SMA (M) connector and swivel mechanism that allows the antenna part to be rotated. The Apex exhibits high efficiency across the wide spectrum and is backward compatible with 2G and 3G cellular applications such as NB-IoT, Cat-M, LTE, UMTS, Wi-Fi and even has GPS included for Assisted GPS and/or E911 applications. 1. 1. Introduction Introduction Introduction Typical Applications include: - Routers and Gateways - Access Points - Remote Monitoring Introduction With very high efficiency on every cellular band globally it is an ideal solution for any device requiring high, reliable performance. It is also guaranteed to meet any type approval or carrier certification requirements from a RF standpoint. It is an omni-directional antenna and the radiation patterns display this and are stable across all bands. It has a quality robust UV resistant housing for use with wireless terminals. The swivel and hinge mechanism allows the antenna part itself to be orientated in different directions and can help avoid touching off other antennas or objects close by as well as helping with isolation by orientating the antenna in different directions in MIMO systems for when other TG.30 antennas are present on the same device. This patented antenna is available in White and Black versions. The antenna blade can swivel 90 degrees from the connector accommodating different installation environments. It is also available with Straight and Right Angle connectors. For further information please contact your regional Taoglas customer support team. SPE-12-8-124-L www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. Band 3. -2.8 2.6 Straight_Freespace 54 -3.0 3.0 Bent_On_Edge_30X30cm_GP 53 -3.1 2.8 Straight_On_Edge_30X30cm_GP 53 -3.2 2.7 Bent_In_Centre_30X30cm_GP 19 -7.7 1.4 Straight_In_Centre_30X30cm_GP 56 -2.9 2.0 Bent_Freespace 50 -3.3 5.6 Straight_Freespace 50 -3.2 4.8 Bent_On_Edge_30X30cm_GP 66 -2.0 2.5 Straight_On_Edge_30X30cm_GP 66 -1.9 3.1 67 -2.0 7.2 55 -3.3 5.9 Bent_Freespace 80 -1.0 4.3 Straight_Freespace 78 -1.1 4.0 Bent_On_Edge_30X30cm_GP 66 -1.8 3.0 Straight_On_Edge_30X30cm_GP 67 -1.7 3.9 Bent_In_Centre_30X30cm_GP 64 -1.9 7.8 Straight_In_Centre_30X30cm_GP 68 -1.7 3.2 Bent_Freespace 68 -1.7 4.2 Straight_Freespace 62 -2.1 3.3 Bent_On_Edge_30X30cm_GP 62 -2.1 3.9 Straight_On_Edge_30X30cm_GP 59 -2.3 3.4 Bent_In_Centre_30X30cm_GP 31 -5.1 3.1 Straight_In_Centre_30X30cm_GP 31 -5.3 2.5 Bent_Freespace 69 -1.6 4.4 Straight_Freespace 61 -2.2 4.7 Bent_On_Edge_30X30cm_GP 50 -2.9 4.6 Straight_On_Edge_30X30cm_GP 49 -3.1 4.7 Bent_In_Centre_30X30cm_GP 56 -2.7 7.1 Specifications Antenna Characteristics Impedance Polarization 3 Max 50Ω Linear Specifications 1710~2200 Antenna Radiation Patterns3.Antenna 2400~2500 Antenna Radiation Patterns 2490~2690 Antenna Radiation Patterns3.Antenna Characteristics 5GNR/4G Band 22,42,43,48,77,78 VSWR 1427~1518 Straight_In_Centre_30X30cm_GP 4G/3G Band 7,38,41 4. (dBi) 617~960 Characteristics 4. (dB) 57 Bent_In_Centre_30X30cm_GP Wi-Fi 2400 4. Peak Gain Bent_Freespace Antenna Characteristics2. 4G/3G Band 1,2,3,4,9,23,25,35,39,66 4. Average Gain Antenna Radiation Patterns3.Antenna 5GNR/4G Band 21,32,74,75,76 3. (%) Antenna Characteristics Characteristics2. 3. Efficiency Frequency (MHz) 5GNR/4G Band 5,8,12,13,14,17,18,20, 26,27,28, 29,71 4. Specifications 5G/4G Elecrical Straight_In_Centre_30X30cm_GP 39 -4.3 7.1 Bent_Freespace 63 -2.2 6.5 Straight_Freespace 60 -2.4 5.7 Bent_On_Edge_30X30cm_GP 48 -3.7 5.5 Straight_On_Edge_30X30cm_GP 47 -3.7 4.2 Bent_In_Centre_30X30cm_GP 43 -4.2 6.8 -4.5 5.5 3300~3800 Antenna Radiation Patterns3.Antenna Characteristics2. SPE-12-8-124-L Straight_In_Centre_30X30cm_GP Specifications 40 www.taoglas.com 4 LTE5200/ Wi-Fi 5800 Bent_Freespace 66 -1.9 5.7 Straight_Freespace 63 -2.1 6.5 Bent_On_Edge_30X30cm_GP 42 -3.9 4.7 Straight_On_Edge_30X30cm_GP 42 -3.9 4.3 Bent_In_Centre_30X30cm_GP 35 -4.9 7.1 Straight_In_Centre_30X30cm_GP 40 -4.3 8.4 5150~5925 Mechanical Casing UV Resistant PC/ABS Flammability Rating UL-94 Connector SMA Male Hinged 90° Environmental Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-12-8-124-L www.taoglas.com 5 5G/4G Bands Band Number 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 18 UL: 815 to 830 DL: 860 to 875 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 28 UL: 703 to 748 DL: 758 to 803 29 UL: - DL: 717 to 728 30 UL: 2305 to 2315 DL: 2350 to 2360 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 32 UL: - DL: 1452 - 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 3550 to 3700 48 66 UL: 1710-1780 DL: 2110-2200 71 617 to 698 74/75/76 1427 to 1518 78 3300 to 3800 79 4400 to 5000 85 SPE-12-8-124-L 698-716 728-746 Covered ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ www.taoglas.com 6 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna 3.1 Return Loss Characteristics 0 Bent_In_Freespace -5 Antenna Radiation Patterns -10 Return Loss [dB] 4. 4. Straight_In_Freespace -15 Bent_On_Edge_30X30cm_GP -20 Antenna Radiation Patterns3.Antenna -25 Straight_On_Edge_30X30cm_GP Characteristics -30 Bent_In_Centre_30X30cm_GP -35 -40 4. -45 600 1200 Characteristics 3.2 4. Straight_In_Centre_30X30cm_GP Antenna Radiation Patterns3.Antenna 1800 2400 3000 3600 4200 4800 5400 6000 Frequency [MHz] Efficiency Antenna Radiation Patterns 100 Bent_In_Freespace 90 80 4. Antenna Radiation Patterns 70 Efficiency [%] 4. Straight_In_Freespace 60 Bent_On_Edge_30X30cm_GP 50 Antenna Radiation Patterns 40 Straight_On_Edge_30X30cm_GP 30 Bent_In_Centre_30X30cm_GP 20 4. 10 Antenna Radiation Patterns3.Antenna Straight_In_Centre_30X30cm_GP 0 600 1200 Characteristics 1800 2400 3000 3600 4200 4800 5400 6000 Frequency [MHz] 4. Antenna Radiation Patterns3.Antenna SPE-12-8-124-L www.taoglas.com 7 3.3 Average Gain 4 Bent_In_Freespace 2 Straight_In_Freespace Aver Gain [dB] 0 -2 Bent_On_Edge_30X30cm_GP -4 Straight_On_Edge_30X30cm_GP -6 Bent_In_Centre_30X30cm_GP -8 Straight_In_Centre_30X30cm_GP -10 600 1200 1800 2400 3000 3600 4200 4800 5400 6000 Frequency [MHz] 3.4 Peak Gain 8 Bent_In_Freespace 6 4 Straight_In_Freespace Gain [dBi] 2 Bent_On_Edge_30X30cm_GP 0 Straight_On_Edge_30X30cm_GP -2 -4 Bent_In_Centre_30X30cm_GP -6 Straight_In_Centre_30X30cm_GP -8 600 1200 1800 2400 3000 3600 4200 4800 5400 6000 Frequency [MHz] SPE-12-8-124-L www.taoglas.com 8 4. Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup – Bent in Freespace 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Z 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-12-8-124-L www.taoglas.com 9 4.2 650MHz Bent_In_Freespace 2D & 3D Radiation Patterns 3D and 2D Radiation Patterns XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 10 750MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 11 890MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 12 1470MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 13 1805MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 14 1920MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 15 1990MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 16 2595MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 17 3550MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 18 5530MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 19 4.3 Test Setup – Straight in Freespace SPE-12-8-124-L www.taoglas.com 20 4.4 650MHz Straight_In_Freespace 2D & 3D Radiation Patterns 3D and 2D Radiation Patterns XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 21 750MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 22 890MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 23 1470MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 24 1805MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 25 1920MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 26 1990MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 27 2595MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 28 3550MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 29 5530MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 30 4.5 Test Setup – Bent On Edge 30X30cm Ground plane SPE-12-8-124-L www.taoglas.com 31 4.6 650MHz Bent On Edge 30X30cm Ground plane 2D & 3D Radiation Patterns 3D and 2D Radiation Patterns XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 32 750MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 33 890MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 34 1470MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 35 1805MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 36 1920MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 37 1990MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 38 2595MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 39 3550MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 40 5530MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 41 4.7 Test Setup – Straight On Edge 30X30cm Ground plane SPE-12-8-124-L www.taoglas.com 42 4.8 650MHz Straight On Edge 30X30cm Ground plane 2D & 3D Radiation Patterns 3D and 2D Radiation Patterns XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 43 750MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 44 890MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 45 1470MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 46 1805MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 47 1920MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 48 1990MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 49 2595MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 50 3550MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 51 5530MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 52 4.9 Test Setup – Bent In Centre 30X30cm Ground plane SPE-12-8-124-L www.taoglas.com 53 4.10 650MHz Bent In Centre 30X30cm Ground plane 2D & 3D Radiation Patterns 3D and 2D Radiation Patterns XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 54 750MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 55 890MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 56 1470MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 57 1805MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 58 1920MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 59 1990MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 60 2595MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 61 3550MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 62 5530MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 63 4.11 Test Setup – Straight In Centre 30X30cm Ground plane SPE-12-8-124-L www.taoglas.com 64 4.12 650MHz Straight In Centre 30X30cm Ground plane 2D & 3D Radiation Patterns 3D and 2D Radiation Patterns XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 65 750MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 66 890MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 67 1470MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 68 1805MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 69 1920MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 70 1990MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 71 2595MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 72 3550MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 73 5530MHz XY Plane SPE-12-8-124-L XZ Plane YZ Plane www.taoglas.com 74 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-12-8-124-L Mechanical Drawing www.taoglas.com 75 8. 6. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-12-8-124-L Mechanical Drawing www.taoglas.com 76 Changelog for the datasheet SPE-12-8-124 - TG.30.8113 Revision: L (Current Version) Date: Changes: Changes Made by: 2022-09-26 Updated specifications Cesar Sousa Previous Revisions Revision: F Revision: K Date: Changes: Changes Made by: 2022-04-04 Full datasheet template update and show data 600-6000. Gary West Revision: J Date: Changes: Changes Made by: 2018-03-23 Technical Writer Revision: E Date: 2018-08-16 Changes: Changes Made by: Date: 2018-03-13 Changes: Technical Writer Revision: I Changes Made by: Technical Writer Revision: D Date: Changes: Changes Made by: 2018-08-14 Change to IP Rating - Removed David Connolly Revision: H Date: Changes: Changes Made by: Changes Made by: SPE-12-8-124-L Changes Made by: 2017-05-10 Technical Writer Revision: C 2018-06-14 Re-tested "Bent on Ground Planer Edge" configuration and results are much improved and consistent with the other three test configuration results. Technical Writer Revision: G Date: Changes: Date: Changes: Date: Changes: Changes Made by: 2017-04-04 Updated Spec with LTE table Andy Mahoney Revision: B 2018-05-08 Technical Writer Date: Changes: Changes Made by: 2017-01-13 Technical Writer www.taoglas.com 77 Previous Revisions (Continued) Revision: A (Original First Release) Date: 2012-10-02 Notes: Author: SPE-12-8-124-L Technical Writer www.taoglas.com 78 www.taoglas.com © Taoglas SPE-12-8-124-L www.taoglas.com 79
TG.30.8113 价格&库存
很抱歉,暂时无法提供与“TG.30.8113”相匹配的价格&库存,您可以联系我们找货
TG.30.8113
    • 5+188.253415+24.38540
    • 20+169.4106220+21.94460
    库存:10
    TG.30.8113
    • 1+125.514381+16.25850
    • 10+98.9651410+12.81945
    • 50+88.3228650+11.44090
    • 100+85.02906100+11.01424
    • 250+81.54981250+10.56356
    • 500+79.45399500+10.29207
    • 1000+77.728081000+10.06851
    库存:9861
    TG.30.8113
      TG.30.8113
      • 5+174.87880
      • 20+157.40290
      库存:10
