ANT-418-CW-HWR-ccc
Data Sheet
by
Product Description
8.2 mm
(0.32")
HWR Series antennas deliver outstanding
performance in a rugged and cosmetically
attractive package. The articulating base allows the
antenna to tilt 90 degrees and rotate 360 degrees.
The antennas attach via a standard SMA or Part
15 compliant RP-SMA connector. Custom colors
and connectors are available for volume OEM
customers.
Features
Low cost
Tilts and rotates
Omni-directional pattern
Outstanding VSWR
Rugged & damage-resistant
Standard SMA or Part 15 compliant RP-SMA
connector
• Custom colors and terminations for volume
OEMs
• Use with plastic* or metal enclosures
• Internal O-ring seal on connector
142 mm
(5.59")
116 mm
(4.57")
* Requires proximity ground plane
26 mm
(1.02")
Electrical Specifications
Center Frequency:
Recom. Freq. Range:
Bandwidth:
Wavelength:
VSWR:
Peak Gain:
Impedance:
Connection:
Oper. Temp. Range:
418MHz
398–438MHz
40MHz
¼-wave
≤ 2.0 typical
0.7dBi
50-ohms
RP-SMA or SMA
–30°C to +80°C
10 mm
(0.39")
30 mm
(1.18")
Ordering Information
ANT-418-CW-HWR-RPS (with RP-SMA connector)
ANT-418-CW-HWR-SMA (with SMA connector)
Electrical specifications and plots measured with a 10.16 cm x
10.16 cm (4.00” x 4.00”) reference ground plane
–1–
Revised 8/1/2017
Counterpoise
Quarter-wave or monopole antennas require an associated ground plane counterpoise for proper operation.
The size and location of the ground plane relative to the antenna will affect the overall performance of the
antenna in the final design. When used in conjunction with a ground plane smaller than that used to tune the
antenna, the center frequency typically will shift higher in frequency and the bandwidth will decrease. The
proximity of other circuit elements and packaging near the antenna will also affect the final performance. For
further discussion and guidance on the importance of the ground plane counterpoise, please refer to Linx
Application Note AN-00501: Understanding Antenna Specifications and Operation.
VSWR Graph
VSWR
3:1
1.386
Reflected Power
25%
11%
2:1
1:1
318MHz
418MHz
0%
518MHz
What is VSWR?
The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source
impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load
versus the voltage wave that is reflected back from the load. A perfect match has a VSWR of 1:1. The higher
the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot
ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this
is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free
space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In
the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side
note, since the “:1” is always implied, many data sheets will remove it and just display the first number.
How to Read a VSWR Graph
VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s
operational center frequency. In most cases, this is different than the designed center frequency due to
fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx
specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1.
Copyright © 2017 Linx Technologies
159 Ort Lane, Merlin, OR 97532
Phone: +1 541 471 6256
Fax: +1 541 471 6251
www.linxtechnologies.com
– 2 – ANT-418-CW-HWR-ccc Data Sheet
by
很抱歉,暂时无法提供与“ANT-433-CW-HWR-RPS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+229.30560
- 200+91.49760
- 500+88.44120
- 1000+86.92920
