ANT-DB1-LP-RM-01-N
ANT-DB1-LP-RM-01-N
    LINXTECHNOLOGIES(灵思)
    ANT-DB1-LP-RM-01-N
ANT-DB1-LP-RM-01-N 数据手册
ANT-DB1-LP-RM-01-N Data Sheet Product Description The Antenna Factor Log Periodic antenna is designed for long-distance directional communication over a wide range of frequencies. The DB1-LP antenna provides gain and directivity comparable to a Yagi, but in a much smaller overall form factor, and over a considerably wider range of frequencies. Constructed of UV stabilized materials, the antenna is suitable for long-term use in indoor or outdoor environments. The antenna includes complete mounting hardware for standard masts. 395.0 mm (15.55") N Style Connector Note: Use of these antennas may result in TX and RX emission levels in excess of legal limits. 165.1 mm (6.50") Features • • • • • • 2X M8x1.25 High gain Wide bandwidth Fully weatherized N female connector Rugged & damage-resistant Excellent performance over common frequency antennas 80.0 mm (3.15") 210.0 mm (8.27") 36.5 mm (1.44") Mounting Hardware (included) Electrical Specifications Recom. Freq. Range: 824–960MHz Ordering Information 1.71–2.17GHz ANT-DB1-LP-RM-01-N (with N female connector) 2.40–2.48GHz Polarization: Vertical VSWR: ≤1.5 typ. at center Impedance: 50-ohms Gain: 8.5dBi (Band 1) 9.0dBi (Bands 2 and 3) 3dB H Beamwidth: 57º, 53º, 50º (Bands 1, 2, 3 resp.) 3dB V Beamwidth: 85º, 70º–80º, 70º (Bands 1, 2, 3 resp.) Max. Power: 100W Connector: N-style female Mounting: Bracket with U-bolts, 1.58"–1.97" (40–50mm) mast Weight : 2.4lbs (1.1kg) Wind Velocity: 75mph (120kph) Front/Back Ratio: ≥20dB –1– Revised 2/20/2018 VSWR Graph VSWR 3:1 1.161 1.226 1.113 11% 2:1 1:1 Reflected Power 25% Center Center Center 916MHz 1910MHz 2450MHz 0% Span 200MHz What is VSWR? The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load versus the voltage wave that is reflected back from the load. A perfect match has a VSWR of 1:1. The higher the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side note, since the “:1” is always implied, many data sheets will remove it and just display the first number. How to Read a VSWR Graph VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s operational center frequency. In most cases, this is different than the designed center frequency due to fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1. Copyright © 2018 Linx Technologies 159 Ort Lane, Merlin, OR 97532 Phone: +1 541 471 6256 Fax: +1 541 471 6251 www.linxtechnologies.com –2– ANT-DB1-LP-RM-01-N Data Sheet
ANT-DB1-LP-RM-01-N
物料型号:ANT-DB1-LP-RM-01-N
器件简介:该天线设计用于在广泛的频率范围内进行长距离定向通信。DB1-LP天线提供了与Yagi天线相当的增益和方向性,但整体尺寸更小,覆盖的频率范围更广。由紫外线稳定的材料制成,适合在室内或室外环境中长期使用。
引脚分配:天线包括完整的标准杆安装硬件,包括2个M8x1.25的螺孔,用于安装。
参数特性: - 推荐频率范围:824-960MHz,1.71-2.17GHz,2.40-2.48GHz - 极化:垂直 - VSWR:典型值中心频率下≤1.5 - 阻抗:50欧姆 - 增益:Band 1为8.5dBi,Bands 2和3为9.0dBi - 3dB水平波束宽度:分别为57º、53º、50º - 3dB垂直波束宽度:分别为85º、70º-80º、70º - 最大功率:100W - 连接器:N型母头 - 安装:带有U型螺栓的支架,适用于1.58"-1.97"(40-50mm)的杆
功能详解:VSWR图显示了天线在不同频率下的电压驻波比,解释了VSWR的概念及其如何衡量天线与源阻抗的匹配程度。
应用信息:该天线适用于需要高增益、宽带宽和全天气条件下的通信系统。
封装信息:天线尺寸为395.0mm x 165.1mm x 80.0mm,重量为2.4磅(1.1公斤),可承受75mph(120kph)的风速。
ANT-DB1-LP-RM-01-N 价格&库存
很抱歉,暂时无法提供与“ANT-DB1-LP-RM-01-N”相匹配的价格&库存,您可以联系我们找货
