MB.TG30.A.305111
MB.TG30.A.305111
    TAOGLASLIMITED
    MB.TG30.A.305111
MB.TG30.A.305111 数据手册
SPECIFICATION PATENT PENDING Part No. : MB.TG30.A.305111 Product Name : Apex Magforce Magnetic Mount LTE Antenna with 3 meter Low Loss Cable Feature : High Efficiency and Peak Gain Worldwide 4G/3G/2G LTE / GSM / CDMA /DCS /PCS / WCDMA / UMTS / HSDPA / GPRS / EDGE /GPS /Wi-Fi 698MHz to 960MHz, 1575.42MHz 1710MHz to 2700Mhz Straight Fixed Dipole Terminal Antenna Strong Magnetic Bond to Metal Surfaces 3 Meters CFD-200 Low Loss Coaxial Cable SMA(M) Connector Cable length and connector customizable RoHS Compliant SPE-14-8-086/B/WY Page 1 of 14 1. Introduction The Apex Magforce MB.TG30.A.305111 Magnetic Mounted LTE Antenna with cable and connector is primarily designed for use with 4G LTE modules that require highest possible efficiency and peak gain to deliver best in class throughput on all major LTE bands worldwide for terminal applications. The antenna can be easily mounted on any metal plate. This Magnetic Mount LTE antenna utilizes the highly successful TG.30 antenna as its main element, providing an ultra wide-band response so it can also be used for other cellular and wireless applications such as fallback to 3G, WI-FI, and assisted GPS. With its unique ultra-wideband dipole design, best in industry performance characteristics is provided, with up to 90% efficiency. It is the recommended solution for products that require highest standard network certifications. The radiation patterns are Omni-directional and stable across all bands. It has a quality robust IP67 housing (connector and magnetic base is IP65) for use with wireless devices. The antenna comes as standard with 3 meters CFD-200 low loss coaxial cable and a SMA male connector. A super magnet in the base provides a strong magnetic bond (max magnetic Pull Force 2.92kgf) to the metal surface it is mounted on. Cable length and connector type are customizable for a minimum order quantity. Contact your regional Taoglas office for support. SPE-14-8-086/B/WY Page 2 of 14 2. Specification ELECTRICAL Frequency (MHz) 700~800 824~896 880~960 1575.42 1710 ~ 1880 Efficiency (%) 77.54 61.02 50.99 46.55 48.09 44.77 43.68 41.44 Peak Gain (dBi) 2.97 1.45 0.62 1.61 1.23 1.19 1.23 2.84 Average Gain (dBi) -1.14 -2.16 -2.95 -3.32 -3.22 -3.50 -3.61 -3.84 Return Loss (dB)
MB.TG30.A.305111 价格&库存
很抱歉,暂时无法提供与“MB.TG30.A.305111”相匹配的价格&库存,您可以联系我们找货
MB.TG30.A.305111
    • 2+378.509732+48.95160
    • 10+340.5888610+44.04740
    库存:4
    MB.TG30.A.305111
    • 50+235.83500
    库存:4
    MB.TG30.A.305111
    • 2+355.59089
    • 10+320.02820
    库存:4
