ISA.01.A.301111
ISA.01.A.301111
    TAOGLASLIMITED
    ISA.01.A.301111
ISA.01.A.301111 数据手册
SPECIFICATION Part No. : ISA.01.A.301111 Product Name : Wide-band Omni-directional Low Profile 400~470MHz Adhesive Glass Mount Antenna For ISM/ TETRA/CDMA 450/ SCADA Family Radio Service/General Mobile Radio Service/Bio-Medical Telemetry Features : 239mm x 42mm x 11mm 1.5dBi gain, 35%+ efficiency Omni-Directional Stable Wide-band response from 400Mhz to 470MHz Semi-Flexible, Low profile IP67 Waterproof Housing Standard 3 meters RG174 cable Automotive Approved 3M Adhesive SMA (M) Connector RoHS Compliant SPE-13-8-005/B/EZ Page 1 of 11 1. Introduction The ISA.01 is an Omni-directional wide-band low profile 400MHz to 470MHz antenna for internal or external applications adhesive mounted on glass. Its applications are in the automotive industry and telematics. At only 10.5mm thick and 42mm in width, its semi-flexible properties and strong 3M automotive approved double-sided adhesive allows for convenient glass installation. ISA.01 antenna offers exceptionally stable peak gain and efficiency across a very wide bandwidth, tuned to operate optimally on glass, which makes it a unique low frequency solution in low profile form. Unlike our competitors, Taoglas shows full performance data for our antennas. The ISA.01 shows real gain figures and radiation patterns INCLUDING cable losses, tested in state of the art low frequency anechoic chambers. We have invested heavily in research to create a uniquely wide-band UHF antenna with minimum 70MHz bandwidth that can replace expensive externally mounted antenna solutions. The wide-band compared to other narrow-band 20MHz antennas delivers more stable performance in a range of diverse on-glass environments with more resistance to detuning. All low frequency UHF antennas need to be tuned to suit their mounting conditions. For this reason this antenna is tuned to be mounted on glass. (i.e. excluding plastic or metal mounting), so is ideal for vehicles or building windows. The standard cable is the RG174. Cable length and connector type are fully customizable The antenna can be customized for other low frequency bands for a minimum order quantity. Please contact your local sales office. For mounting applications on plastic please use ISA.06. For mounting directly on metal please use our FW series whip antennas. SPE-13-8-005/B/EZ Page 2 of 11 1. Specification ISM Frequency 410 433 450 470 MHz Peak Gain * 0.5 1.5 0.8 0 dBi Average Gain * -5.0 -4.3 -5.0 -5.0 dB Efficiency * 30 35 30 30 % Return Loss * -10.0
ISA.01.A.301111 价格&库存
很抱歉,暂时无法提供与“ISA.01.A.301111”相匹配的价格&库存,您可以联系我们找货
