Ultima A.30
Part No:
A.30.A.301111
Description:
A.30 Ultima Series Low Profile GPS-GLONASS-Galieo Permanent Mount Antenna
Features:
Height 20.6mm
Diameter 55.4mm
Heavy duty Permanent(screw) Mount
UV and vandal resistant PC housing and thread
IP67 waterproof rated
Cable: 3m RG-174
Connector: SMA(M)ST
RoHS & Reach Compliant
SPE-14-8-088-E
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
7
4.
2D Radiation Patterns
11
5.
Installation
13
6.
Mechanical Drawing
14
7.
Packaging
15
Changelog
16
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-14-8-088-E
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
1.
1.
Introduction
The A.30 Ultima Series GPS/GLONASS/Galileo Antenna is a low profile combination high performance
GPS/GLONASS/Galileo antenna solution for professional telematics applications. At only 21 mm height it is
one of the lowest profile antennas in the market, with a diameter of 55 mm. Durable UV resistant PC housing,
thread and nut withstands vandalism and direct attack.
Introduction
Typical Applications Include
- Asset Tracking
- Transportation
- Connected Enterprise
Introduction
The IP67 waterproof robust plastic body makes it extremely light, economical for shipping and with minimum
weight impact on vehicles. This also makes it ideal for use in humid environments such as water pits or marine
applications as there are no external metal parts to corrode. The closed cell foam with double-sided adhesive
provides a permanent waterproof seal and can adjust to different curvatures, stopping water from leaking
under the antenna into the mounting hole.
Introduction
Cable length and connector is customizable. Contact you regional Taoglas Customer Support Team for more
information or installation instructions.
SPE-14-8-088-E
www.taoglas.com
3
2.
Specifications
3.
Antenna Characteristics2.
Specifications
GNSS Frequency Bands Covered
GPS/QZSS
3.
L1
1575.42MHz
L2
1227.6MHz
L5
1176.45MHz
L6
1278.75MHz
1176.45MHz
1201.5MHz
L2PT
1246MHz
L1CR
1575.42MHz
L1PT
1602MHz
Antenna
Characteristics
L5R
L3PT
GLONASS
E5a
E5b
E4
E3
4. GalileoAntenna
Radiation
Patterns3.
Antenna
1176.45MHz
1201.5MHz
1215MHz
1256MHz
Characteristics2.
BeiDou
Specifications
B2
1207.14MHz
B3
1268.52MHz
3.
4.
SBAS
Omnistar
1542.5MHz
WAAS/EGN OS
1575.42MHz
E2
1561MHz
L1
1575.42MHz
B1
1561MHz
E5B(B2)/ E6(B3)
E2(B1)
3. Compass
Antenna
Characteristics2.
1268.56MHz
1561MHz
E6
1278.75MHz
Specifications
Antenna Radiation Patterns3.Antenna
Characteristics
4.
4.
Characteristics
4.
Characteristics2.
SPE-14-8-088-E
Specifications
www.taoglas.com
4
Electrical
Frequency (MHz)
1575.42MHz
1602MHz
Average Gain
dB
-2.07
-2.02
Efficiency
62.07
62.8
Peak Gain
dBi
3.65
4.08
Impedance
50Ω
GPS/GALILEO Patch Gain@
Zenith
GLONASS Patch Gain@ Zenith
-1.4dBi Passive Gain @ Zenith
-1.3dBi Gain @ Zenith
VSWR
2.0 max
Out Band Rejection
fo = 1575.42MHz
fo ± 30 MHz 5dB Min.
fo ± 50 MHz 20dB Min.
fo ± 100 MHz 25dB Min.
Input Voltage(V)
Typ. 2.5~5.5V
Total Gain @ Zenith
27dB typical at 3.0V
Current consumption(mA)
10mA typical at 3.0V
Noise figure
1.3dB typical
Polarization
RHCP
Radiation Pattern
Omni
SPE-14-8-088-E
www.taoglas.com
5
Mechanical
Diameter
55.4mm
Height
20.6mm
Cable type
RG-174
Cable length
3000±30mm
Casing
PC
Connector
SMA Male
Weight (1 pc)
89g
Shock (drop test)
1m drop on concrete 6 axes
Environmental
Humidity
Non-condensing 65°C 95% RH
Temperature Range
-40°C to 85°C
Waterproof
IP67
Thermal Shock
100 cycles -40°C to +80°C
SPE-14-8-088-E
www.taoglas.com
6
3.
4.
3.1
LNA Block Diagram
Characteristics
4.
4.
Characteristics
4.
Characteristics
4.
4.
4.
4.
Characteristics
4.
SPE-14-8-088-E
www.taoglas.com
7
3.2
Return Loss
-10
(dB)
-15
-20
-25
A.30.A
-30
1550
3.3
1570
1590
1610
1630
1650 (MHz)
Efficiency
100
A.30.A
90
80
70
60
50
40
30
SPE-14-8-088-E
1520
1540
1560
1580
1600
1620
1640
1660
1680
1700
(MHz)
www.taoglas.com
8
3.4
Average Gain
10
A.30.A
5
(dB)
(MHz)
-10
1500
3.5
1520
1540
1560
1580
1600
1620
1640
1660
1680
1700
Peak Gain
10
A.30.A
(dBi)
5
-10
1500
SPE-14-8-088-E
(MHz)
1520
1540
1560
1580
1600
1620
1640
1660
1680
1700
www.taoglas.com
9
3.6
LNA Noise Figure
10.00
9.00
8.00
7.00
[dB]
6.00
5.00
4.00
3.00
2.00
1.00
0.00
1560
1565
1570
1575
1580
1585
1590
1595
1600
1605
1610
Frequency [MHz]
SPE-14-8-088-E
www.taoglas.com
10
4.
4.
4.
4.1
Test Setup
4.
4.
4.
Y
4.
X
4.
Z
4.
SPE-14-8-088-E
www.taoglas.com
11
4.2
XY Plane
SPE-14-8-088-E
XZ Plane
YZ Plane
www.taoglas.com
12
5.
Installation
4.
4.
4.
4.
4.
4.
4.
SPE-14-8-088-E
www.taoglas.com
13
6.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-14-8-088-E
Mechanical Drawing
www.taoglas.com
14
8.
7.
Footprint
Packaging
1pcs A.30.A.301111 per PE Bag
- 300*160mm
4. Dimensions
6.
Antenna
Packaging5.
Radiation
Mechanical
Patterns3.
Drawing
Antenna
Weight - 89g
Characteristics
6.
Packaging
4.
A.30.A.301111 per carton
7. 60pcsApplication
Note6. Packaging5.
Mechanical
Dimensions - 320*300*250mm
Weight - 6.8Kg
4. Antenna Radiation Patterns3.Antenna
Drawing
Characteristics
300mm
6.
Packaging5.
Mechanical Drawing
4.
320mm
250mm
6.
Packaging
Characteristics
Pallet Dimensions:
1100*1100*1300mm
60 Cartons Per Pallet
7.
4.
Application
Note6. Patterns
Packaging
Antenna Radiation
1290mm
7.
4.
Application
Note Patterns
Antenna Radiation
1100mm
7.
4.
Application
Note6. Patterns
Packaging
Antenna Radiation
7.
4.
Application
Note6. Patterns3.
Packaging5.
Mechanical
Antenna Radiation
Antenna
1100mm
Drawing
Characteristics
6.
4.
Packaging5.
Mechanical
Drawing
Antenna Radiation
Patterns3.
Antenna
SPE-14-8-088-E
www.taoglas.com
15
Changelog for the datasheet
SPE-14-8-088 – A.30.A.301111
Revision: E (Current Version)
Date:
Changes:
Changes Made by:
2022-10-13
Added LNA block diagram
Cesar Sousa
Previous Revisions
Revision: D
Date:
Changes:
Changes Made by:
2022-05-26
Added LNA noise figure graph
Gary West
Revision: C
Date:
Changes:
Changes Made by:
2021-11-12
Updated to reflect new data
Jack Conroy
Revision: C
Date:
Changes:
Changes Made by:
2019-07-11
Jack Conroy
Revision: B
Date:
Changes:
Changes Made by:
2018-12-11
Amended Drawing to show Heatshrink
Jack Conroy
Revision: A (Original First Release)
Date:
Notes:
2014-05-09
Author:
Jack Conroy
SPE-14-8-088-E
www.taoglas.com
16
www.taoglas.com
© Taoglas
SPE-14-8-088-E
www.taoglas.com
17
很抱歉,暂时无法提供与“A.30.A.301111”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+581.691951+75.61807
