SPECIFICATION
Part No.
TI.19.2113
Product Name
2dBi 915MHz ISM Band Dipole Terminal
Antenna, SMA(M) Hinge
Feature
High efficiency dipole terminal antenna
ROHS compliant
SPE-11-8-014/G/ZL
Page 1 of 23
1. Introduction
TI.19 is a high performance 915MHz ISM band dipole omnidirectional antenna.
The hinged design enables the antenna to be positioned at its most suitable
angle. This antenna features a SMA(M) Plug Connector.
For a lot of antenna applications, such as Wi-Fi Hotspot or cellular Pico-cell, the
antenna of the operator’s device and the antenna of the user’s remote device
are not on the same horizontal level. The TI.19 has been designed with a
butterfly shape radiation pattern, to help counteract this effect.
2. Specification
ELECTRICAL
Frequency
902 ~ 928MHz
Peak Gain (bent)
2.5dBi
Peak Gain (straight)
2.4dBi
Average Gain (bent)
-1.0dBi
Average Gain (straight)
-0.9dBi
Efficiency (bent)
81%
Efficiency (straight)
82%
Impedance
50Ω
VSWR
< 1.9 : 1
Polarization
Linear
Radiation Pattern
Omnidirectional
Input Power
10 W
MECHANICAL
Antenna Length
389 ± 5 mm
Antenna Diameter
13 ± 0.5 mm
Casing
TPU
Connector
SMA Male
ENVIRONMENTAL
Temperature Range
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
SPE-11-8-014/G/ZL
Page 2 of 23
3. Antenna S11 Properties
3.1 Return Loss
-4
-6
(dBi)
-8
-10
-12
-14
bend
-16
straight
-18
-20
700
800
900
1000
1100
3.2 VSWR
10
9
8
7
6
5
4
bend
3
straight
2
1
700
800
900
1000
1100
SPE-11-8-014/G/ZL
Page 3 of 23
4. Antenna Radiation Properties
4.1.
3D Radiation Efficiency
100
90
80
70
60
50
40
bend
30
straight
860
880
900
920
940
960
SPE-11-8-014/G/ZL
980
Page 4 of 23
4.2.
Peak Gain
4
3
2
(dBi)
1
bend
-1
straight
-2
-3
-4
840
4.3.
860
880
900
920
940
960
980
Average Gain
(dBi)
-2
-3
bend
-4
straight
-5
-6
840
860
880
900
920
940
960
SPE-11-8-014/G/ZL
980
Page 5 of 23
4.4.
Radiation Pattern of 90 Degree Bent Position
Y
Z
X
4.4.1 3D Radiation Pattern
SPE-11-8-014/G/ZL
Page 6 of 23
4.4.2 XZ Plane Radiation
330
30
-10
300
60
-15
-20
-25
-30
-35
270
90
240
120
900MHz
915MHz
210
930MHz
150
180
(Unit : dBi)
4.4.3 XY Plane Radiation
330
30
-10
300
60
-15
-20
-25
-30
-35
270
90
9 0 0 M Hz
240
120
210
9 1 5 M Hz
9 3 0 M Hz
150
180
( Uni t : d B i )
SPE-11-8-014/G/ZL
Page 7 of 23
4.4.4 Radiation at 45 Degree from XY Plane
330
30
-10
300
60
-15
-20
-25
-30
270
-35
90
240
120
900MHz
915MHz
930MHz
210
150
180
(Unit : dBi)
SPE-11-8-014/G/ZL
Page 8 of 23
4.5.
Radiation Pattern of 180 Degree Straight Position
y
x
z
x
4.5.1 3D Radiation Pattern
SPE-11-8-014/G/ZL
Page 9 of 23
4.5.2 XZ Plane Radiation
330
30
-10
300
60
-15
-20
-25
-30
-35
270
90
240
120
900MHz
915MHz
210
930MHz
150
180
(Unit : dBi)
4.5.3 XY Plane Radiation
330
30
-10
300
60
-15
-20
-25
-30
-35
270
90
9 0 0 M Hz
240
120
210
9 1 5 M Hz
9 3 0 M Hz
150
180
( Uni t : d B i )
SPE-11-8-014/G/ZL
Page 10 of 23
4.5.4 Radiation at 45 Degree from XY Plane
330
30
-10
300
60
-15
-20
-25
-30
270
-35
90
240
120
900MHz
915MHz
930MHz
210
150
180
(Unit : dBi)
SPE-11-8-014/G/ZL
Page 11 of 23
5. Ground Plane Effect
Three ground setups are used to see the affect of positioning TI.19 close to
ground 1. Small Ground (15*9cm) – common size of CPE devices. TI.19 is mounted at
the longer edge for testing.
2. Big Ground Edge (45*30cm) – simulate the effect of mounting antenna on a
base station device. TI.19 is mounted at the centre of the longer edge.
3. Big Ground Centre (45*30cm) – simulate the effect of mounting antenna in
a centre of a big ground plane, such as vehicle top.
SPE-11-8-014/G/ZL
Page 12 of 23
5.1.
S11 Return Loss
Bent
-4
-6
(dBi)
-8
-10
-12
-14
-16
stand alone
-18
small gnd
big gnd edge
-20
big gnd centre
-22
700
800
900
1000
1100
Straight
-4
(dBi)
-6
-8
-10
-12
stand alone
small gnd
big gnd edge
-14
big gnd centre
-16
700
800
900
1000
1100
SPE-11-8-014/G/ZL
Page 13 of 23
5.2.
VSWR
Bent
6
5
4
3
stand alone
small gnd
big gnd edge
2
big gnd centre
1
700
800
900
1000
1100
Straight
6
5
4
3
stand alone
small gnd
big gnd edge
2
big gnd centre
1
700
800
900
1000
1100
SPE-11-8-014/G/ZL
Page 14 of 23
5.3.
Bent
100
90
80
70
60
50
40
stand alone
30
small gnd
big gnd edge
big gnd center
10
850
860
870
880
890
900
910
920
930
940
950
960
970
980
(MHz)
Straight
100
90
80
70
60
50
40
stand alone
30
small gnd
big gnd edge
big gnd center
10
850
860
870
880
890
900
910
920
930
940
950
960
970
SPE-11-8-014/G/ZL
980
(MHz)
Page 15 of 23
5.4.
Average Gain
Bent
(dBi)
-2
-3
stand alone
-4
small gnd
big gnd edge
big gnd center
-5
-6
840
850
860
870
880
890
900
910
920
930
940
950
960
970
980
(MHz)
Straight
(dBi)
-2
-3
stand alone
-4
small gnd
big gnd edge
big gnd center
-5
-6
840
850
860
870
880
890
900
910
920
930
940
950
960
970
SPE-11-8-014/G/ZL
980
(MHz)
Page 16 of 23
5.5.
Peak Gain
Bent
5
4
3
(dBi)
2
1
stand alone
small gnd
big gnd edge
big gnd center
-1
-2
840
850
860
870
880
890
900
910
920
930
940
950
960
970
980
(MHz)
Straight
5
4
3
(dBi)
2
1
stand alone
small gnd
big gnd edge
big gnd center
-1
-2
840
850
860
870
880
890
900
910
920
930
940
950
960
970
980
SPE-11-8-014/G/ZL
(MHz)
Page 17 of 23
5.6.
5.6.1 XZ Plane Radiation
330
30
-10
300
60
-15
-20
-25
-30
270
-35
90
240
120
stand alone
small gnd
210
150
big gnd edge
big gnd center
180
(dBi)
SPE-11-8-014/G/ZL
Page 18 of 23
5.6.2 XY Plane Radiation
330
30
-10
300
60
-15
-20
-25
-30
-35
270
90
240
120
s t a nd a l o ne
210
s m a l l g nd
b i g g nd e d g e
b i g g nd c e nt e r
150
180
(dB i )
5.6.3 Radiation at 45 Degree from XY Plane
330
300
270
5
-10
-15
-20
-25
-30
-35
60
90
240
120
210
150
stand alone
small gnd
big gnd edge
big gnd center
180
(dBi)
SPE-11-8-014/G/ZL
Page 19 of 23
5.7.
5.7.1 XZ Plane Radiation
330
30
-10
300
60
-15
-20
-25
-30
270
90
-35
240
120
stand alone
small gnd
big gnd edge
210
150
180
big gnd center
(dBi)
5.7.2 XY Plane Radiation
330
30
-10
300
60
-15
-20
-25
-30
-35
270
90
240
120
stand alone
small gnd
big gnd edge
210
150
180
big gnd center
(dBi)
SPE-11-8-014/G/ZL
Page 20 of 23
5.7.3 Radiation at 45 Degree from XY Plane
330
30
-10
300
60
-15
-20
-25
-30
270
-35
90
240
120
210
150
stand alone
small gnd
big gnd edge
big gnd center
180
(dBi)
SPE-11-8-014/G/ZL
Page 21 of 23
6. Mechanical Drawing (Unit: mm)
SPE-11-8-014/G/ZL
Page 22 of 23
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-11-8-014/G/ZL
Page 23 of 23
很抱歉,暂时无法提供与“TI.19.2113”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+143.137061+18.55329
- 10+113.3362010+14.69053
- 50+101.3968950+13.14297
- 100+97.70026100+12.66382
- 250+93.79721250+12.15791
- 500+91.44555500+11.85309
- 国内价格
- 1+218.45160
- 200+87.16680
- 500+84.25080
- 1000+82.81440
