CMD69273P
698-960 MHZ/1710-2700 MHz
Low PIM 2-port MIMO Ceiling Mount Antenna
LOW PIM 2-PORT MIMO MULTI-BAND CEILING MOUNTED OMNIDIRECTIONAL ANTENNA
The CMD69273P is an indoor broadband low PIM 2-port MIMO omnidirectional ceiling mount antenna.
It is designed to provide pattern coverage that is optimized for indoor requirements at 698-960 MHz and
1710-2700 MHz frequency bands. The individual antenna elements are designed with linear H/V-polarization
components oriented to provide a pattern that has been specifically shaped to provide optimal performance
from a ceiling mount location.location.
FEATURES
• Low Profile aesthetically neutral housing
• Mounts directly and easily to ceiling tile
• Wide bandwidth 700/850/900/1800/1900/2100/2300/2400/25
00/2600
• Two radiating elements optimized for indoor MIMO Applications
• Low cross correlation between radiating elements
• Low Passive Intermodulation
• Conformance to RoHS
BENEFITS
• Complete cellular and 3G/4G data communications in a single
antenna
• Radiating elements are oriented to provide maximal coverage
Frequency
Peak Gain
Nominal Impedance
VSWR
Polarization
• To mitigate the multipath polarization
propagation issue, each radiating element is designed to have dual-linear H/V
polarization characteristics
MARKETS
• Cellular
• LTE/WiMAX
• 802.11 a/b/g/n
• Warehouse, Offices and Meeting Rooms
• Hotels, Museums, Libraries, Retail Malls
• Airport, Bus Terminals and Train Stations
• Other in-building areas
CMD69273P
698-960 MHz/1710-2700 MHz
3.1 (typical), 3.9 (max) @ 700 Band
3.1 (typical), 3.8 (max) @ 800 Band
2.8 (typical), 3.5 (max) @ 900 Band
5.9 (typical), 6.8 (max) @ 1800 Band
4.5 (typical), 5.1 (max) @ 1900 Band
4.3 (typical), 4.7 (max) @ 2100 Band
5.9 (typical), 6.3 (max) @ 2300 Band
6.9 (typical), 7.4 (max) @ 2600 Band
50 Ω
Max 2.0:1
Linear H/V for each radiator
Azimuth Beam Width (deg)
Omni directional
PIM, 3rd Order, 2 x 20 W
< -150 dBc
Max Power (Ambient temp of 25°C)
50 Watts
Isolation
很抱歉,暂时无法提供与“CMD69273P-46NF”相匹配的价格&库存,您可以联系我们找货
