CMD69273P-30NF
CMD69273P-30NF
    LAIRD(莱尔德)
    ANT MIMO DUAL 12"CBL 2PORT N-FEM
CMD69273P-30NF 数据手册
CMD69273P 698-960 MHZ/1710-2700 MHz Low PIM 2-port MIMO Ceiling Mount Antenna LOW PIM 2-PORT MIMO MULTI-BAND CEILING MOUNTED OMNIDIRECTIONAL ANTENNA The CMD69273P is an indoor broadband low PIM 2-port MIMO omnidirectional ceiling mount antenna. It is designed to provide pattern coverage that is optimized for indoor requirements at 698-960 MHz and 1710-2700 MHz frequency bands. The individual antenna elements are designed with linear H/V-polarization components oriented to provide a pattern that has been specifically shaped to provide optimal performance from a ceiling mount location.location. FEATURES • Low Profile aesthetically neutral housing • Mounts directly and easily to ceiling tile • Wide bandwidth 700/850/900/1800/1900/2100/2300/2400/25 00/2600 • Two radiating elements optimized for indoor MIMO Applications • Low cross correlation between radiating elements • Low Passive Intermodulation • Conformance to RoHS BENEFITS • Complete cellular and 3G/4G data communications in a single antenna • Radiating elements are oriented to provide maximal coverage Frequency Peak Gain Nominal Impedance VSWR Polarization • To mitigate the multipath polarization propagation issue, each radiating element is designed to have dual-linear H/V polarization characteristics MARKETS • Cellular • LTE/WiMAX • 802.11 a/b/g/n • Warehouse, Offices and Meeting Rooms • Hotels, Museums, Libraries, Retail Malls • Airport, Bus Terminals and Train Stations • Other in-building areas CMD69273P 698-960 MHz/1710-2700 MHz 3.1 (typical), 3.9 (max) @ 700 Band 3.1 (typical), 3.8 (max) @ 800 Band 2.8 (typical), 3.5 (max) @ 900 Band 5.9 (typical), 6.8 (max) @ 1800 Band 4.5 (typical), 5.1 (max) @ 1900 Band 4.3 (typical), 4.7 (max) @ 2100 Band 5.9 (typical), 6.3 (max) @ 2300 Band 6.9 (typical), 7.4 (max) @ 2600 Band 50 Ω Max 2.0:1 Linear H/V for each radiator Azimuth Beam Width (deg) Omni directional PIM, 3rd Order, 2 x 20 W < -150 dBc Max Power (Ambient temp of 25°C) 50 Watts Isolation
CMD69273P-30NF 价格&库存
很抱歉,暂时无法提供与“CMD69273P-30NF”相匹配的价格&库存,您可以联系我们找货
