ANT-418-CW-RCS
ANT-418-CW-RCS
    LINXTECHNOLOGIES(灵思)
    ANT-418-CW-RCS
ANT-418-CW-RCS 数据手册
ANT-418-CW-RCS Data Sheet by Product Description The RCS Series is ideally suited for products requiring an attractive, yet compact, ¼-wave antenna in a right-angle form factor. The antennas attach via a Part 15 compliant RP-SMA connector. 7.0 mm (0.28") Features • • • • • • • Reduced height helical whip Right-angle mount Excellent performance Omni-directional pattern Fully weatherized Part 15 compliant RP-SMA connector Use with plastic* or metal enclosures 45.0 mm (1.77") 53.5 mm (2.11") * Requires proximity ground plane Electrical Specifications Center Frequency: Recom. Freq. Range: Wavelength: VSWR: Impedance: Oper. Temp. Range: Connector: 8.5 mm (0.33") 418MHz 411–426MHz ¼-wave < 2.0 typical at center 50-ohms –20°C to +85°C RP-SMA 8.0 mm (0.31") 9.4 mm (0.37") Electrical specifications and plots measured on 10.16 cm x 10.16 cm (4.00" x 4.00") reference ground plane Ordering Information ANT-418-CW-RCS –1– Revised 1/15/15 Counterpoise Quarter-wave or monopole antennas require an associated ground plane counterpoise for proper operation. The size and location of the ground plane relative to the antenna will affect the overall performance of the antenna in the final design. When used in conjunction with a ground plane smaller than that used to tune the antenna, the center frequency typically will shift higher in frequency and the bandwidth will decrease. The proximity of other circuit elements and packaging near the antenna will also affect the final performance. For further discussion and guidance on the importance of the ground plane counterpoise, please refer to Linx Application Note AN-00501: Understanding Antenna Specifications and Operation. VSWR Graph VSWR 3:1 1.146 2:1 1:1 318MHz Reflected Power 25% 11% 0% 518MHz 418MHz What is VSWR? The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load versus the voltage wave that is reflected back from the load. A perfect match will have a VSWR of 1:1. The higher the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side note, since the “:1” is always implied, many data sheets will remove it and just display the first number. How to Read a VSWR Graph VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s operational center frequency. In most cases, this will be different than the designed center frequency due to fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1. –2– Data Sheet ANT-418-CW-RCS by
ANT-418-CW-RCS 价格&库存
很抱歉,暂时无法提供与“ANT-418-CW-RCS”相匹配的价格&库存,您可以联系我们找货
