WCM.01.0151W
WCM.01.0151W
    TAOGLASLIMITED
    WCM.01.0151W
WCM.01.0151W 数据手册
SPECIFICATION Part No. : WCM.01.0151W Product Name: : 2.4GHz Button Antenna Features : Smallest External Wi-Fi/Bluetooth Antenna 2dBi˜5dBi Peak Gain Dims: 19.8*14.3*16.4mm 2400MHz to 2500MHz Antenna Wi-Fi/Bluetooth 60%+ Efficiency RP SMA(M) Connector IP67 Housing Omnidirectional ROHS Compliant *Gain varies depending on ground-plane size SPE-16-8-079/A/WY Page 1 of 30 1. Introduction The WCM.01w 2.4GHz antenna is the smallest RP-SMA(M) external antenna in the market, fitting into spaces other traditional monopole, dipole or rubber ducky antenna cannot go. A unique PIFA design ensures omnidirectional gain across 2.4GHz to 2.5GHz ensuring constant reception and transmission to make it a great antenna for 2.4GHz Wi-Fi and Bluetooth applications. This antenna features greater than 60% efficiency when connected directly to the ground plane of the device. Typical Applications - Application Points - Routers - IoT M2M devices - Smart Home applications This antenna comes with an RP SMA(M) to be compatible with most Wi-Fi applications and routers in the market. The WCM.01 antenna housing is also IP67 water resistant. The antenna should be mounted on the edge of the main PCB ground-plane of the device. Due to its monopole design, relatively larger ground-planes will increase the efficiency and peak gain of the antenna. The ideal position for the antenna to radiate is mounted clear of metal housings. Connector is customizable subject to minimum order quantities and possible NRE. Contact your Taoglas regional sales office for more information. SPE-16-8-079/A/WY Page 2 of 30 2. Specification ELECTRICAL Frequency (MHz) 2400 2450 2500 33.30 30.36 29.65 Efficiency (%) In free space On the 10*10cm Ground plane(center edge) 63.43 71.44 66.85 On the 10*10cm On the 20*20cm Ground plane(off center edge) Ground plane(center edge) 55.85 64.20 68.43 71.40 61.73 63.97 On the 20*20cm Ground plane(off center edge) 62.55 81.30 69.73 On the 30*30cm Ground plane(center edge) 58.31 70.49 60.87 On the 30*30cm Ground plane(off center edge) 62.11 73.46 61.90 -4.78 -5.18 -5.28 Average Gain (dBi) In free space On the 10*10cm Ground plane(center edge) -1.98 -1.46 -1.75 On the 10*10cm On the 20*20cm Ground plane(off center edge) Ground plane(center) -2.53 -1.92 -1.65 -1.46 -2.10 -1.94 On the 20*20cm Ground plane(off center edge) -2.04 -0.90 -1.57 On the 30*30cm Ground plane(center edge) -2.34 -1.52 -2.16 On the 30*30cm Ground plane(off center edge) Peak Gain (dBi) In free space -2.07 -1.34 -2.08 0.89 0.40 0.12 On the 10*10cm Ground plane(center edge) 2.02 2.45 2.37 On the 10*10cm Ground plane(off ceter edge) 3.46 4.09 3.47 On the 20*20cm Ground plane(center edge) 4.26 4.54 3.69 On the 20*20cm Ground plane(off center edge) 4.02 5.40 4.65 On the 30*30cm Ground plane(center edge) 3.64 4.85 4.06 On the 30*30cm Ground plane(off center edge) 3.79 4.23 3.15 Radiation Polarization Omnidirectional Linear Impedance 50Ω Max Input Power 10W MECHANICAL Antenna Dimension 19.8*14.3*16.4mm Casing ABS Connector RP-SMA(M) Weight 6g Ingress Protection Rating IP67 (Housing only) SPE-16-8-079/A/WY Page 3 of 30 ENVIRONMENTAL Operation Temperature -40°C ~ + 85°C Storage Temperature -40°C ~ + 85°C Humidity Non-condensing 65°C 95% RH SPE-16-8-079/A/WY Page 4 of 30 3. Antenna Characteristics 3.1 Testing Setup b) With 10*10cm c) With 10*10cm ground plane center ground plane off center edge edge a) In free space d) With 20*20cm e) With 20*20cm f) With 30*30cm g) With 30*30cm ground plane center ground plane off ground plane center ground plane off center edge center edge edge edge Figure.1 Antenna Measurement Setup SPE-16-8-079/A/WY Page 5 of 30 3.2 Return Loss (In free space) Figure 2. Return loss of WCM.01 antenna 3.3 Return Loss(On ground plane center edge) Figure 3. Return loss of WCM.01 antenna with different ground plane size SPE-16-8-079/A/WY Page 6 of 30 3.4 Return Loss (On ground plane off center edge) Figure 4. Return loss of WCM.01 antenna with different ground plane size 3.5 Efficiency (In free space) Figure 5. Efficiency of WCM.01 antenna SPE-16-8-079/A/WY Page 7 of 30 3.6 Efficiency (On ground plane center edge) Figure 6. Return loss of WCM.01 antenna with different ground plane size 3.7 Efficiency (On ground plane off center edge) Figure 7. Return loss of WCM.01 antenna with different ground plane size SPE-16-8-079/A/WY Page 8 of 30 3.8 Peak Gain (In free space) Figure 8. Peak gain of WCM.01 antenna with different ground plane size 3.9 Peak Gain (On ground plane center edge) Figure 9. Peak gain of WCM.01 antenna with different ground plane size SPE-16-8-079/A/WY Page 9 of 30 3.10 Peak Gain (On ground plane off center edge) Figure 10. Peak gain of WCM.01 antenna with different ground plane size 3.11 Average Gain (In free space) Figure 11. Average gain of WCM.01 SPE-16-8-079/A/WY Page 10 of 30 3.12 Average Gain (On ground plane center edge) Figure 12. Average gain of WCM.01 antenna with different ground plane size 3.13 Average Gain (On ground plane off center edge) Figure 13. Average gain of WCM.01 antenna with different ground plane size SPE-16-8-079/A/WY Page 11 of 30 4. Antenna Radiation Patterns The antenna radiation patterns were measured in a CTIA certified ETS Anechoic Chamber. The measurement setup is shown below. Y X Z In Free Space Y Y X Z X Z On 10*10cm ground plane (Center On 10*10cm ground plane (Off Edge Center Edge) SPE-16-8-079/A/WY Page 12 of 30 Y Y X Z X Z On 20*20cm ground plane (Center On 20*20cm ground plane (Off Edge) Center Edge) Y Y X Z X Z On 30*30cm ground plane (Center On 30*30cm ground plane (Off Edge) Center Edge) Figure.14. Testing Setup in ETS Anechoic Chamber SPE-16-8-079/A/WY Page 13 of 30 4.1 2D Radiation Pattern (In free space) XY Plane X Y XZ Plane Z X SPE-16-8-079/A/WY Page 14 of 30 YZ Plane Z Y 4.2 3D Radiation Pattern (In free space) 2400MHz 2450MHz 2500MHz SPE-16-8-079/A/WY Page 15 of 30 4.3 2D Radiation Pattern (On 10*10cm ground plane center edge) XY Plane X Y XZ Plane Z X SPE-16-8-079/A/WY Page 16 of 30 YZ Plane Z Y 4.4 3D Radiation Pattern (On 10*10cm ground plane center edge) 2400MHz 2500MHz 2450MHz SPE-16-8-079/A/WY Page 17 of 30 4.5 2D Radiation Pattern (On 10*10cm ground plane off center edge) XY Plane X Y XZ Plane Z X SPE-16-8-079/A/WY Page 18 of 30 YZ Plane Z Y 4.6 3D Radiation Pattern (On 10*10cm ground plane off center edge) 2400MHz 2500MHz 2450MHz SPE-16-8-079/A/WY Page 19 of 30 4.7 2D Radiation Pattern (On the 20*20cm ground plane center edge) XY Plane X Y XZ Plane Z X SPE-16-8-079/A/WY Page 20 of 30 YZ Plane Z Y 4.8 3D Radiation Pattern (On 20*20cm ground plane center edge) 2400MHz 2450MHz 2500MHz SPE-16-8-079/A/WY Page 21 of 30 4.9 2D Radiation Pattern (On 20*20cm ground plane off center edge) XY Plane X Y XZ Plane Z X SPE-16-8-079/A/WY Page 22 of 30 YZ Plane Z Y 4.10 3D Radiation Pattern (On 20*20cm ground plane off center edge) 2400MHz 2450MHz 2500MHz SPE-16-8-079/A/WY Page 23 of 30 4.11 2D Radiation Pattern (On 30*30cm ground plane off center edge) XY Plane X Y XZ Plane Z X SPE-16-8-079/A/WY Page 24 of 30 YZ Plane Z Y 4.12 3D Radiation Pattern (On 30*30cm ground plane center edge) 2400MHz 2450MHz 2500MHz SPE-16-8-079/A/WY Page 25 of 30 4.13 2D Radiation Pattern (On 30*30cm ground plane off center edge) XY Plane X Y XZ Plane Z X SPE-16-8-079/A/WY Page 26 of 30 YZ Plane Z Y 4.14 3D Radiation Pattern (On 30*30cm ground plane off center edge) 2400MHz 2450MHz 2500MHz SPE-16-8-079/A/WY Page 27 of 30 5. DRAWING (Unit: mm) SPE-16-8-079/A/WY Page 28 of 30 6. Packaging SPE-16-8-079/A/WY Page 29 of 30 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas SPE-16-8-079/A/WY Page 30 of 30
WCM.01.0151W 价格&库存
很抱歉,暂时无法提供与“WCM.01.0151W”相匹配的价格&库存,您可以联系我们找货
WCM.01.0151W
    • 100+52.58377
    库存:1
    WCM.01.0151W
    • 1+110.174631+14.32002
    • 10+95.6921610+12.43765
    • 25+90.6699825+11.78489
    • 100+83.78122100+10.88952
    • 300+78.87396300+10.25170
    • 500+76.74566500+9.97507
    • 1000+74.004631000+9.61880
    库存:2270
