ALPHA18/2.5M/FMEF/S/S/26 数据手册
Alpha 18
Quad Band GSM / GPRS (2G) & UMTS (3G) Dipole Antenna
Key Features
Quad band GSM / GPRS (2G) and UMTS (3G )
Dipole
Adhesive base
Low profile design
Ground plane independent
General Description
Additional Considerations
The Alpha 18 is a low profile dipole
antenna, delivering high performance
across global GSM/GPRS (2G) and
UMTS (3G) frequencies.
• Housed in a robust ABS casing for wide range climatic and
operational environments
• Does not require additional placement on metallic surface
• Meets all EU compliance criteria for electronic goods
The dipole design generates a good
peak gain response ideal for areas
with medium signal strength.
The Alpha 18 is supplied with a 3m
cable and SMA male connector or
2.5m FME Female connector as
standard. Custom cable lengths and
connector types are available for
volume orders.
Registered in England No. 08405712
VAT Registration No. GB163 04 0349
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
fax
email
web
+44(0)118 976 9014
+44(0)118 976 9020
sales@siretta.com
www.siretta.com
Rev 1.3
Alpha 18
Electrical Specifications
Operating Temperature:
Mechanical Specifications
-40°C - +85°C Dimensions:
Impedance:
96.2 x 21.5 x 9.7mm
50 Ohm Cable:
Peak Gain:
3dBi
VSWR:
ALPHA18/2.5M/FMEF/S/S/26 价格&库存
很抱歉,暂时无法提供与“ALPHA18/2.5M/FMEF/S/S/26”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+84.4371010+10.93756
