MIKE3A/5M/SMAM/S/S/17
    SIRETTA
    Mike 3A 是一种紧凑型双安装GPS天线,调谐到1575.42MHz,具有28dB的LNA增益,适用于多种户外GPS应用,包括车辆/车队/资产跟踪和移动应用。
MIKE3A/5M/SMAM/S/S/17 数据手册
MIKE 3A GPS IP67 Magnetic Mount Antenna Key Features • • • • 28dB LNA gain Weather Resistant Dual mount Ground plane independent General Description Additional Considerations The MIKE 3A is a compact dual mount GPS antenna, tuned to 1575.42MHz Band L1. • Improves signal to noise ratio for mobile applications • Mixed mounting - magnetic or adhesive pad • Meets all EU compliance criteria for electronic goods Dual mounting: with its magnetic base and separate adhesive pad, the Mike 3A can be mounted onto a diverse range of surfaces. The weather resistant design makes it an ideal outdoor GPS antenna that can be used for a host of different GPS applications including: vehicle/fleet/ asset tracking and mobile applications. The built in Low Noise Amplifier (LNA) provides a 28dB gain producing stronger signals which reduce satellite fix times. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9014 sales@siretta.com www.siretta.com Rev 2.0 Mike 3A GPS IP67 Magnetic Mount Antenna Dielectric Antenna VSWR: Mechanical Specifications 1.5:1 Impedance: 50 Ohms Centre Frequency: 1575.42 MHz >3dBic (Based on 7 x 7cm Ground plane) Peak Gain: Gain Coverage: Dimensions: L50 x W39 x H17 mm Cable: RG174 Connector: SMA Male Mounting Method: Magnetic >4dBic at 90˚ Polarization: RHCP GPS Antenna Environmental Specifications LNA Gain: 28 dB Typical Noise Figure: 1.5 dB Connector: SMA Male VSWR:
MIKE3A/5M/SMAM/S/S/17 价格&库存
很抱歉,暂时无法提供与“MIKE3A/5M/SMAM/S/S/17”相匹配的价格&库存,您可以联系我们找货
  • 1+104.07589
  • 5+102.20140
库存:74
