ALPHA14/0.5M/SMAM/S/S/26
    SIRETTA
    Alpha 14 是一款紧凑型粘贴式天线,具有低剖面设计,适用于隐蔽应用。适用于智能能源计量或遥测设备。支持四频段 GSM/GPRS (2G) 和 UMTS (3G),以及 ISM 868MHz 和 ...
ALPHA14/0.5M/SMAM/S/S/26 数据手册
Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA Key Features • • • • 2G, 3G, 4G & ISM compatible Low profile of 3mm Small footprint ISM: 868 and 915MHz General Description Additional Considerations The Alpha 14 is one of the most compact adhesive antenna, with a slim low profile design. Typically used for applications such as smart energy meters or telemetry equipment. Supplied with a 3M™ adhesive base. • Low profile design makes it ideal for covert applications • Intended for indoor use • Quad band 2G & 3G compatible for worldwide use The Alpha 14 is tuned to quad band GSM / GPRS (2G), UMTS (3G), LTE (4G) and ISM 868MHz & 915MHz frequencies, allowing for worldwide use. The antenna will also support WiFi in the lower band. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA Electrical Specifications Mechanical Specifications Polarization: Linear Impedance: 50 Ohm Max Power Input: 10 W Ground Plane Independent: Yes -40 - +85 °C Relative Humidity: L39.9 x W33.5 x H5.5 mm Weight: 15 g Cable: RG174 Connector: SMA Male Mounting method: Environmental Specifications Operating Temperature: Dimensions: Adhesive Radome material: ABS Up to 95 % Y X Z orientation Return Loss tested with 2.5 m cable Return Loss in -dB 0.00 -2.00 -4.00 -6.00 -dB -8.00 -10.00 -12.00 -14.00 -16.00 -18.00 -20.00 0 1000 2000 3000 4000 5000 6000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA VSWR tested with 2.5 m cable VSWR 10.00 9.00 8.00 VSWR 7.00 6.00 5.00 4.00 3.00 2.00 1.00 0 1000 2000 3000 4000 5000 6000 4000 5000 6000 MHz Radiation Efficiency tested with 2.5 m cable Antenna Radiation Efficiency (in %) 110.00 100.00 90.00 80.00 % Efficiency 70.00 60.00 50.00 40.00 30.00 20.00 10.00 0.00 0 1000 2000 3000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA LTE/5G Band Coverage M/5G Bands NB-IoT Band 1/n1 B1 2/n2 3/n3 LTE, CAT- Avg Efficieny % over band Max VSWR over Band Uplink Downlink Europe / Asia 1920-1980 MHz 2110-2170 MHz 40.55 / 10.59 1.84 / 2.15 B2 North America/Latin America/Caribbean 1850-1910 MHz 1930-1990 MHz 33.43 / 39.62 1.40 / 1.84 B3 Europe/Africa/Asia/Oceania 1710-1785 MHz 1805-1880 MHz 14.76 / 27.79 2.47 / 1.80 4 B4 North America/Latin America/Caribbean 1710-1755 MHz 2110-2155 MHz 10.91 / 12.67 2.47 / 2.15 5/n5 B5 Country Specific 824-849 MHz 869-894 MHz 22.51 / 29.70 4.04 / 3.64 2500-2570 MHz 2620-2690 MHz 28.38 / 28.79 1.62 / 1.72 880-915 MHz 925-960 MHz 32.25 / 33.34 7/n7 8/n8 Regional Coverage Latin America/Europe/Asia + B8 Europe / Asia + 3.42 / 3.16 x 11 B11 Country Specific 1427.9-1447.9 MHz 1475.9-1495.9 MHz 14.80 / 8.35 12/n12 B12 North America/Caribbean + 699-716 MHz 729-746 MHz 13.40 / 17.38 2.37 / 1.82 3.97 / 4.20 13/n13 B13 North America/Caribbean + 777-787 MHz 746-756 MHz 23.84 / 20.82 4.12 / 4.20 14/n14 B14 Country Specific 788-798 MHz 758-768 MHz 21.99 / 21.48 4.12 / 3.99 17 B17 North America/Caribbean + 704-716 MHz 734.746 MHz 10.74 / 17.38 3.97 / 4.20 18/n18 B18 Country Specific 815-830 MHz 860-875 MHz 20.98 / 29.06 4.04 / 3.81 19 B19 Country Specific 830-845 MHz 875-890 MHz 22.51 / 29.70 3.80 / 2.96 20/n20 B20 Europe/Africa + 832-862 MHz 791-821 MHz 24.97 / 21.44 3.81 / 4.04 21 x Country Specific 1447.9-1462.9 MHz 1495.9-1510.9 MHz 11.09 / 7.64 25/n25 B25 Country Specific 1850-1915 MHz 1525-1559 MHz 33.43 / 10.10 1.40 / 2.64 26/n26 B26 Country Specific 814-849 MHz 859-894 MHz 22.18 / 28.08 4.04 / 3.81 28/n28 B28 Latin America/Europe/Asia + 703-748 MHz 758-803 MHz 17.38 / 20.83 4.20 / 4.12 - 717-728 MHz 11.86 29/n29 Country Specific 30/n30 31 B31 32 1.86 / 1.90 3.84 Country Specific 2305-2315 MHz 2350-2360 MHz 11.29 / 18.13 Country Specific 452.5-457.5 MHz 462.5-467.5 MHz 10.21 / 8.64 Country Specific - 1452-1496 MHz 2.09 / 2.16 x 5.08 / 5.20 10.03 1.88 38/n38 Europe + 2570-2620 MHz 28.15 1.55 39/n39 Country Specific 1880-1920 MHz 36.89 1.32 40/n40 Asia + 2300-2400 MHz 15.72 2.61 41/n41 Country Specific 2496-2690 MHz 28.17 1.72 42 Country Specific 3400-3600 MHz 17.94 2.14 43 Country Specific 3600-3800 MHz 23.43 1.88 46/n46 Country Specific 5150-5925 MHz 13.58 1.73 48/n48 Country Specific 3550-3700 MHz 22.56 1.88 Country Specific 1920-2010 MHz 2110-2200 MHz 38.32 / 9.03 x 1.84 / 2.21 66/n66 B66 Country Specific 1710-1780 MHz 2110-2200 MHz 13.15 / 9.03 x 2.47 / 2.21 71/n71 B71 Country Specific 663-698 MHz 617-652 MHz 65/n65 17.98 / 14.06 3.51 / 3.47 Table data for bands as detailed in 3GPP TS 36.101 & 38.101 Usable Band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Adequate in good signal area x Not Usable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA 5G Extended Table for Band Coverage LTE/5G Band NB-IoT Band n24 Uplink Downlink 1626.5 – 1660.5 MHz 1525 – 1559 MHz Max VSWR over Band Avg Efficieny % over band 15.32 / 10.10 1.82 / 2.64 n34 2010 – 2025 MHz 33.72 1.94 n47 5855 – 5925 MHz 12.27 1.57 n50 1432 – 1517 MHz 11.22 1.98 n51 1427 – 1432 MHz 17.15 2.37 n53 2483.5 – 2495 MHz 25.79 1.91 n67 738 – 758 MHz 17.38 n70 B70 n74 1695 – 1710 MHz 1995 – 2020 MHz 4.91 / 35.08 1427 – 1470 MHz 1475 – 1518 MHz 13.12 / 8.25 4.20 x 1.66 / 1.94 2.37 / 1.90 n75 1432 – 1517 MHz 11.22 1.98 n76 1427 – 1432 MHz 17.15 2.37 n77 3300 – 4200 MHz 18.58 2.18 n78 3300 – 3800 MHz 18.69 2.18 n79 4400 – 5000 MHz 12.74 1.94 n80 1710 – 1785 MHz 14.76 2.47 n81 880 – 915 MHz 32.25 3.42 n82 832 – 862 MHz 24.97 3.81 n83 703 – 748 MHz 15.78 4.20 1920 – 1980 MHz 40.55 1.84 n84 n85 B85 n86 698 – 716 MHz 728 – 746 MHz 13.40 / 17.38 3.97 / 4.20 1710 – 1780 MHz 13.15 2.47 n89 824 – 849 MHz 22.51 4.04 n90 2496 – 2690 MHz 28.17 1.72 n91 832 – 862 MHz 1427 – 1432 MHz 24.97 / 17.15 3.81 / 2.37 n92 832 – 862 MHz 1432 – 1517 MHz 24.97 / 11.22 3.81 / 1.98 n93 880 – 915 MHz 1427 – 1432 MHz 32.25 / 17.15 3.42 / 2.37 n94 880 – 915 MHz 1432 – 1517 MHz 32.25 / 11.22 3.42 / 1.98 n95 2010 – 2025 MHz n96 5925 – 7125 MHz 33.72 n97 2300 – 2400 MHz 15.72 2.61 n98 1880 – 1920 MHz 36.89 1.32 n99 1626.5 – 1660.5 MHz 15.32 1.82 1.94 unmeasured Table data for bands as detailed in 3GPP TS 38.101 Usable Band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Adequate in good signal area x Not Usable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA Radiation Plots tested with 2.5 m cable 600 MHz XY XZ YZ 700 MHz XY XZ YZ 800 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA Radiation Plots tested with 2.5 m cable 900 MHz XY XZ YZ 1400 MHz XY XZ YZ 1500 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA Radiation Plots tested with 2.5 m cable 1600 MHz XY XZ YZ 1700 MHz XY XZ YZ 1800 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA Radiation Plots tested with 2.5 m cable 1900 MHz XY XZ YZ 2000 MHz XY XZ YZ 2100 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA Radiation Plots tested with 2.5 m cable 2300 MHz XY XZ YZ 2400 MHz XY XZ YZ WiFi Band 2.4 GHz WiFi Band 2.4 GHz Eff % 17.42 Eff % 17.42 2460 MHz XY XZ YZ WiFi Band 2.4 GHz WiFi Band 2.4 GHz Eff % 24.32 Eff % 24.32 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA Radiation Plots tested with 2.5 m cable 2500 MHz XY XZ YZ WiFi Band 2.4 GHz WiFi Band 2.4 GHz Eff % 27.42 Eff % 27.42 2600 MHz XY XZ YZ 2700 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA Radiation Plots tested with 2.5 m cable 3300 MHz XY XZ YZ 3400 MHz XY XZ YZ 3500 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA Radiation Plots tested with 2.5 m cable 3600 MHz XY XZ YZ 3700 MHz XY XZ YZ 3800 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA Radiation Plots tested with 2.5 m cable 4400 MHz XY XZ YZ 4600 MHz XY XZ YZ 4800 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA Radiation Plots tested with 2.5 m cable 5000 MHz XY XZ YZ 5200 MHz XY XZ YZ 5400 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA Radiation Plots tested with 2.5 m cable 5600 MHz XY XZ YZ 5800 MHz XY XZ YZ 6000 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA 3D Radiation Plots tested with 2.5 m cable 600 MHz 700 MHz 800 MHz Theta 65 Phi 45 Theta 65 Phi 45 Theta 65 Phi 45 900 MHz 1400 MHz 1500 MHz Theta 65 Phi 45 Theta 65 Phi 45 Theta 65 Phi 45 1600 MHz 1700 MHz 1800 MHz Theta 65 Phi 45 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Theta 65 Phi 45 Theta 65 Phi 45 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA 3D Radiation Plots tested with 2.5 m cable 1900 MHz Theta 65 Phi 45 2300 MHz 2000 MHz Theta 65 Phi 45 2400 MHz 2100 MHz Theta 65 Phi 45 2460 MHz Theta 65 Phi 45 Theta 65 Phi 45 Theta 65 Phi 45 2500 MHz 2600 MHz 2700 MHz Theta 65 Phi 45 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Theta 65 Phi 45 Theta 65 Phi 45 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA 3D Radiation Plots tested with 2.5 m cable 3300 MHz Theta 65 Phi 45 3600 MHz 3400 MHz Theta 65 Phi 45 3700 MHz 3500 MHz Theta 65 Phi 45 3800 MHz Theta 65 Phi 45 Theta 65 Phi 45 Theta 65 Phi 45 4400 MHz 4600 MHz 4800 MHz Theta 65 Phi 45 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Theta 65 Phi 45 Theta 65 Phi 45 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0 Alpha 14 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA 3D Radiation Plots tested with 2.5 m cable 5000 MHz Theta 65 Phi 45 5600 MHz Theta 65 Phi 45 5200 MHz Theta 65 Phi 45 5800 MHz Theta 65 Phi 45 5400 MHz Theta 65 Phi 45 6000 MHz Theta 65 Phi 45 Ordering Details Part Number Description ALPHA14/0.5M/SMAM/S/S/26 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA SMA MALE 0.5m CABLE ALPHA14/2.5M/SMAM/S/S/26 2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA SMA MALE 2.5m CABLE Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Ver 3.0
ALPHA14/0.5M/SMAM/S/S/26 价格&库存
很抱歉,暂时无法提供与“ALPHA14/0.5M/SMAM/S/S/26”相匹配的价格&库存,您可以联系我们找货
