ISA.05.A.033822
ISA.05.A.033822
    TAOGLASLIMITED
    ISA.05.A.033822
ISA.05.A.033822 数据手册
Specification Part No. : ISA.05.A.033822 Product Name : 915 MHz ISM Band Adhesive Mounted Patch Antenna for Internal Applications Features : Double-Sided 3M Adhesive Mounted Antenna 5dBi Peak Gain mounted on 30cm Square Ground 0dBi Peak Gain In Free Space Dimensions: 80x50.5x11 mm 300 mm Φ1.37 cable IPEX MHFHT connector (U.FL compatible) IP65 water-proof Cable and connector customizable RoHS Compliant SPE-15-8-036/B/WY Page 1 of 16 1. Introduction The Taoglas ISA.05 adhesive mounted antenna is designed primarily for 915 MHz ISM Band compact wireless applications where it may or may not be attached to metal. When placed on a reference 30cm square ground-plane, the antenna has an excellent directional hemispherical radiation pattern, high peak gain of 5dBi at zenith, and an efficiency of 68%. Even without a ground-plane underneath, the antenna achieves 0dBi and an efficiency of 45%. The antenna is IP65 water-resistant and comes standard with a Micro-Coaxial cable with 1.37mm diameter and IPEX MHFHT connector. The Taoglas ISA.05 is an excellent solution for the following applications: - Environments where there are lots of metal objects that it may be mounted to (such as near a car engine) - RFID Readers - Short range 915MHz mesh networks Cable type, length, and connector can be customized. Mechanical customization of the antenna can also be done for a minimum order quantity. Please contact your regional Taoglas office for more details. SPE-15-8-036/B/WY Page 2 of 16 2. Specification ELECTRICAL ISM 915 MHz Band Measurement Environment Free Space Direct On 30cm * 30cm Ground Plane Operation Frequency (MHz) 902 915 928 902 915 928 Return Loss (dB) -5 -6 -3 -3 -11 -3 VSWR 3.6 3 5.9 5.9 2 5.9 Efficiency (%) 46.25 47.51 18.55 26.36 68.94 62.64 Peak Gain (dBi) 0.52 -0.02 -4.10 0.83 5.12 4.77 Average Gain (dBi) -3.34 -3.23 -7.31 -5.79 -1.61 -2.03 Polarization Linear Impedance 50 Ohms Max Input Power 5 Watts MECHANICAL Dimension (mm) 80*50.5*11 (Antenna Main Body) Cable length 300mm Cable Type Ф1.37 RF Coaxial Cable Connector IPEX MHFHT Appearance Black, Heat Shrink with Glue Gasket & Adhesive 3M 9448 + CR-4305 Weight 32g ENVIRONMENTAL RATINGS Protection IP65 Storage Temperature Range -40°C to +85°C Operation Temperature Range -40°C to +85°C Humidity Non-condensing 65°C 95% RH SPE-15-8-036/B/WY Page 3 of 16 3. Antenna Characteristics 3.1 Return Loss 3.2 Average Gain SPE-15-8-036/B/WY Page 4 of 16 3.3 Efficiency 3.4 Peak Gain SPE-15-8-036/B/WY Page 5 of 16 4. Antenna Radiation Patterns 4.1 Antenna Setup The antenna radiation pattern measurement setup is shown below. Y Y X X Z In free space Z Center of 30cm*30cm Ground Plane SPE-15-8-036/B/WY Page 6 of 16 4.2 Antenna Radiation Patterns 4.2.1 In Free Space XY Plane X Y XZ Plane Z X SPE-15-8-036/B/WY Page 7 of 16 YZ Plane Z Y 4.2.2 At the Center of 30cm*30cm Ground Plane XY Plane X Y SPE-15-8-036/B/WY Page 8 of 16 XZ Plane Z X YZ Plane Z Y SPE-15-8-036/B/WY Page 9 of 16 4.2.3 3D Radiation Pattern in Free Space 4.2.4 3D Radiation Pattern On 30cm*30cm Ground Plane SPE-15-8-036/B/WY Page 10 of 16 5. Drawing (Units: mm) SPE-15-8-036/B/WY Page 11 of 16 6. Packaging SPE-15-8-036/B/WY Page 12 of 16 7. Installation SPE-15-8-036/B/WY Page 13 of 16 8. Application Note 8.1 Ground Size and proximity affects performance 8.2 Ground Plane Beside Antenna Effect Any ground plane beside the antenna should be at least 10mm away from the antenna main body to keep antenna radiating normally. SPE-15-8-036/B/WY Page 14 of 16 8.3 Ground Plane Under Antenna Effect 8.4 Ground Plane Above Antenna Effect Any ground plane above the antenna should be at least 55mm away from the antenna main body to keep antenna radiating normally. SPE-15-8-036/B/WY Page 15 of 16 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-15-8-036/B/WY Page 16 of 16
ISA.05.A.033822 价格&库存
很抱歉,暂时无法提供与“ISA.05.A.033822”相匹配的价格&库存,您可以联系我们找货
ISA.05.A.033822
  • 1+354.320751+45.84085
