ALPHA14/2.5M/SMAM/S/S/26 数据手册
Alpha 14
2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA
Key Features
2G, 3G, 4G & ISM compatible
Low profile of 3mm
Small footprint
ISM: 868 and 915MHz
General Description
Additional Considerations
The Alpha 14 is one of the most
compact adhesive antenna, with
a slim low profile design. Typically
used for applications such as
smart energy meters or telemetry
equipment. Supplied with a 3M™
adhesive base.
• Low profile design makes it ideal for covert applications
• Intended for indoor use
• Quad band 2G & 3G compatible for worldwide use
The Alpha 14 is tuned to quad
band GSM / GPRS (2G), UMTS
(3G), LTE (4G) and ISM 868MHz
& 915MHz frequencies, allowing
for worldwide use. The antenna
will also support WiFi in the lower
band.
Registered in England No. 08405712
VAT Registration No. GB163 04 0349
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
Electrical Specifications
Mechanical Specifications
Polarization:
Linear
Impedance:
50 Ohm
Max Power Input:
10 W
Ground Plane Independent:
Yes
-40 - +85 °C
Relative Humidity:
L39.9 x W33.5 x H5.5 mm
Weight:
15 g
Cable:
RG174
Connector:
SMA Male
Mounting method:
Environmental Specifications
Operating Temperature:
Dimensions:
Adhesive
Radome material:
ABS
Up to 95 %
Y
X
Z
orientation
Return Loss tested with 2.5 m cable
Return Loss in -dB
0.00
-2.00
-4.00
-6.00
-dB
-8.00
-10.00
-12.00
-14.00
-16.00
-18.00
-20.00
2000
3000
4000
5000
6000
MHz
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
VSWR tested with 2.5 m cable
VSWR
10.00
9.00
8.00
VSWR
7.00
6.00
5.00
4.00
3.00
2.00
1.00
2000
3000
4000
5000
6000
4000
5000
6000
MHz
Radiation Efficiency tested with 2.5 m cable
Antenna Radiation Efficiency (in %)
110.00
100.00
90.00
80.00
% Efficiency
70.00
60.00
50.00
40.00
30.00
20.00
10.00
0.00
2000
3000
MHz
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
LTE/5G Band Coverage
M/5G Bands
NB-IoT
Band
1/n1
B1
2/n2
3/n3
LTE, CAT-
Avg Efficieny %
over band
Max VSWR
over Band
Uplink
Downlink
Europe / Asia
1920-1980 MHz
2110-2170 MHz
40.55 / 10.59
1.84 / 2.15
B2
North America/Latin America/Caribbean
1850-1910 MHz
1930-1990 MHz
33.43 / 39.62
1.40 / 1.84
B3
Europe/Africa/Asia/Oceania
1710-1785 MHz
1805-1880 MHz
14.76 / 27.79
2.47 / 1.80
4
B4
1710-1755 MHz
2110-2155 MHz
10.91 / 12.67
2.47 / 2.15
5/n5
B5
Country Specific
824-849 MHz
869-894 MHz
22.51 / 29.70
4.04 / 3.64
2500-2570 MHz
2620-2690 MHz
28.38 / 28.79
1.62 / 1.72
880-915 MHz
925-960 MHz
32.25 / 33.34
7/n7
8/n8
Regional Coverage
Latin America/Europe/Asia +
B8
Europe / Asia +
3.42 / 3.16
x
11
B11
Country Specific
1427.9-1447.9 MHz
1475.9-1495.9 MHz
14.80 / 8.35
12/n12
B12
North America/Caribbean +
699-716 MHz
729-746 MHz
13.40 / 17.38
2.37 / 1.82
3.97 / 4.20
13/n13
B13
777-787 MHz
746-756 MHz
23.84 / 20.82
4.12 / 4.20
14/n14
B14
Country Specific
788-798 MHz
758-768 MHz
21.99 / 21.48
4.12 / 3.99
17
B17
704-716 MHz
734.746 MHz
10.74 / 17.38
3.97 / 4.20
18/n18
B18
Country Specific
815-830 MHz
860-875 MHz
20.98 / 29.06
4.04 / 3.81
19
B19
Country Specific
830-845 MHz
875-890 MHz
22.51 / 29.70
3.80 / 2.96
20/n20
B20
Europe/Africa +
832-862 MHz
791-821 MHz
24.97 / 21.44
3.81 / 4.04
21
x
Country Specific
1447.9-1462.9 MHz
1495.9-1510.9 MHz
11.09 / 7.64
25/n25
B25
Country Specific
1850-1915 MHz
1525-1559 MHz
33.43 / 10.10
1.40 / 2.64
26/n26
B26
Country Specific
814-849 MHz
859-894 MHz
22.18 / 28.08
4.04 / 3.81
28/n28
B28
703-748 MHz
758-803 MHz
17.38 / 20.83
4.20 / 4.12
717-728 MHz
11.86
29/n29
Country Specific
30/n30
31
B31
32
1.86 / 1.90
3.84
Country Specific
2305-2315 MHz
2350-2360 MHz
11.29 / 18.13
Country Specific
452.5-457.5 MHz
462.5-467.5 MHz
10.21 / 8.64
Country Specific
1452-1496 MHz
2.09 / 2.16
x
5.08 / 5.20
10.03
1.88
38/n38
Europe +
2570-2620 MHz
28.15
1.55
39/n39
Country Specific
1880-1920 MHz
36.89
1.32
40/n40
Asia +
2300-2400 MHz
15.72
2.61
41/n41
Country Specific
2496-2690 MHz
28.17
1.72
42
Country Specific
3400-3600 MHz
17.94
2.14
43
Country Specific
3600-3800 MHz
23.43
1.88
46/n46
Country Specific
5150-5925 MHz
13.58
1.73
48/n48
Country Specific
3550-3700 MHz
22.56
1.88
Country Specific
1920-2010 MHz
2110-2200 MHz
38.32 / 9.03
x
1.84 / 2.21
66/n66
B66
Country Specific
1710-1780 MHz
2110-2200 MHz
13.15 / 9.03
x
2.47 / 2.21
71/n71
B71
Country Specific
663-698 MHz
617-652 MHz
65/n65
17.98 / 14.06
3.51 / 3.47
Table data for bands as detailed in 3GPP TS 36.101 & 38.101
Usable Band
Adequate in good signal area
x Not Usable
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
5G Extended Table for Band Coverage
LTE/5G
Band
NB-IoT
Band
n24
Uplink
Downlink
1626.5 – 1660.5 MHz
1525 – 1559 MHz
Max VSWR
over Band
Avg Efficieny %
over band
15.32 / 10.10
1.82 / 2.64
n34
2010 – 2025 MHz
33.72
1.94
n47
5855 – 5925 MHz
12.27
1.57
n50
1432 – 1517 MHz
11.22
1.98
n51
1427 – 1432 MHz
17.15
2.37
n53
2483.5 – 2495 MHz
25.79
1.91
n67
738 – 758 MHz
17.38
n70
B70
n74
1695 – 1710 MHz
1995 – 2020 MHz
4.91 / 35.08
1427 – 1470 MHz
1475 – 1518 MHz
13.12 / 8.25
4.20
x
1.66 / 1.94
2.37 / 1.90
n75
1432 – 1517 MHz
11.22
1.98
n76
1427 – 1432 MHz
17.15
2.37
n77
3300 – 4200 MHz
18.58
2.18
n78
3300 – 3800 MHz
18.69
2.18
n79
4400 – 5000 MHz
12.74
1.94
n80
1710 – 1785 MHz
14.76
2.47
n81
880 – 915 MHz
32.25
3.42
n82
832 – 862 MHz
24.97
3.81
n83
703 – 748 MHz
15.78
4.20
1920 – 1980 MHz
40.55
1.84
n84
n85
B85
n86
698 – 716 MHz
728 – 746 MHz
13.40 / 17.38
3.97 / 4.20
1710 – 1780 MHz
13.15
2.47
n89
824 – 849 MHz
22.51
4.04
n90
2496 – 2690 MHz
28.17
1.72
n91
832 – 862 MHz
1427 – 1432 MHz
24.97 / 17.15
3.81 / 2.37
n92
832 – 862 MHz
1432 – 1517 MHz
24.97 / 11.22
3.81 / 1.98
n93
880 – 915 MHz
1427 – 1432 MHz
32.25 / 17.15
3.42 / 2.37
n94
880 – 915 MHz
1432 – 1517 MHz
32.25 / 11.22
3.42 / 1.98
n95
2010 – 2025 MHz
n96
5925 – 7125 MHz
33.72
n97
2300 – 2400 MHz
15.72
2.61
n98
1880 – 1920 MHz
36.89
1.32
n99
1626.5 – 1660.5 MHz
15.32
1.82
1.94
unmeasured
Table data for bands as detailed in 3GPP TS 38.101
Usable Band
x Not Usable
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
Radiation Plots tested with 2.5 m cable
600 MHz XY
XZ
YZ
700 MHz XY
XZ
YZ
800 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
900 MHz XY
XZ
YZ
1400 MHz XY
XZ
YZ
1500 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
1600 MHz XY
XZ
YZ
1700 MHz XY
XZ
YZ
1800 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
1900 MHz XY
XZ
YZ
2000 MHz XY
XZ
YZ
2100 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
2300 MHz XY
XZ
YZ
2400 MHz XY
XZ
YZ
WiFi
Band
2.4
GHz
WiFi
Band
2.4
GHz
Eff %
17.42
Eff %
17.42
2460 MHz XY
XZ
YZ
WiFi
Band
2.4
GHz
WiFi
Band
2.4
GHz
Eff %
24.32
Eff %
24.32
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
2500 MHz XY
XZ
YZ
WiFi
Band
2.4
GHz
WiFi
Band
2.4
GHz
Eff %
27.42
Eff %
27.42
2600 MHz XY
XZ
YZ
2700 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
3300 MHz XY
XZ
YZ
3400 MHz XY
XZ
YZ
3500 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
3600 MHz XY
XZ
YZ
3700 MHz XY
XZ
YZ
3800 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
4400 MHz XY
XZ
YZ
4600 MHz XY
XZ
YZ
4800 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
5000 MHz XY
XZ
YZ
5200 MHz XY
XZ
YZ
5400 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
5600 MHz XY
XZ
YZ
5800 MHz XY
XZ
YZ
6000 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
3D Radiation Plots tested with 2.5 m cable
600 MHz
700 MHz
800 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
900 MHz
1400 MHz
1500 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
1600 MHz
1700 MHz
1800 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
1900 MHz
Theta 65 Phi 45
2300 MHz
2000 MHz
Theta 65 Phi 45
2400 MHz
2100 MHz
Theta 65 Phi 45
2460 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
2500 MHz
2600 MHz
2700 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
3300 MHz
Theta 65 Phi 45
3600 MHz
3400 MHz
Theta 65 Phi 45
3700 MHz
3500 MHz
Theta 65 Phi 45
3800 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
4400 MHz
4600 MHz
4800 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
Alpha 14
5000 MHz
Theta 65 Phi 45
5600 MHz
Theta 65 Phi 45
5200 MHz
Theta 65 Phi 45
5800 MHz
Theta 65 Phi 45
5400 MHz
Theta 65 Phi 45
6000 MHz
Theta 65 Phi 45
Ordering Details
Part Number
Description
ALPHA14/0.5M/SMAM/S/S/26
2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA SMA MALE 0.5m CABLE
2G/3G/4G & ISM868/915MHz ADHESIVE FLAT BLADE ANTENNA SMA MALE 2.5m CABLE
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Ver 3.0
ALPHA14/2.5M/SMAM/S/S/26 价格&库存
很抱歉,暂时无法提供与“ALPHA14/2.5M/SMAM/S/S/26”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+146.750121+19.02161
