TANGO26/0.1M/SMAM/S/RP/29
    SIRETTA
TANGO26/0.1M/SMAM/S/RP/29 数据手册
Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna Key Features • Supports 5G NR / 4G LTE • Supports Dual Band WiFi 4/5/6 • Supports Bluetooth / Zigbee / ISM 2450 / ISM 5800 / IEEE 802.15.4 Bands • Supports WLAN2400 / WLAN5800 Bands • Miniature Design • Through Hole / Screw Mounting • IP65 Rated General Description Additional Considerations The Tango 26 is a miniature through-hole mount, WiFi/WLAN/Bluetooth/Zigbee/ 4G LTE/5G NR antenna. Despite a compact size, this antenna provides great WiFi performance. • Made out of durable ABS for a long-lasting antenna • Meets EU compliance criteria for electronic goods The Tango 26 is tuned to operate in a wide range from 2.4 to 2.5 GHz & 5.8 GHz frequencies, making this antenna perfect for Dual-band WiFi, Bluetooth and Zigbee applications. Supplied as standard with an SMA Male Reverse Polarity connector and 100 mm cable. Alternative cable lengths and connector types can be specified for volume orders. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 1 Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna Electrical Specifications Impedance: 50 Ohm Polarization: Vertical Max Input Power: 1W Ground plane independent: Yes Environmental Specifications Operating Temperature range: -30 to +60 °C Storage Temperature range: -30 to +60 °C Mechanical Specifications Dimensions: Weight: Cable: Connector: L14.75 x 22.3 mm base diameter 11 g PRO100 SMA Male Reverse Polarity Mounting method: M11 Screw Housing materials: ABS Y X Z orientation Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.0 2 Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna Spectrum Coverage Suitable band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Adequate band in good signal conditions Likely to be unsuitable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.0 3 Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna Usable Cellular Frequency Support (410 MHz – 1900 MHz) 410 450 600 700 800 850 900 1500 1600 1700 1800 1900 GSM Bands: UMTS Bands: LTE Bands: LTE Cat M Bands: LTE Cat NB Bands: 5G NR Bands: NR Cat NB Bands: Usable Cellular Frequency Support (2000 MHz – 5900 MHz) 2000 2100 2300 2400 2500 2600 3300 3500 3700 4700 5200 5900 GSM Bands: UMTS Bands: LTE Bands: LTE Cat M Bands: LTE Cat NB Bands: 5G NR Bands: NR Cat NB Bands: Usable ISM Frequency Support (433 MHz - 5800 MHz) 433 868 915 2450 5800 Bluetooth IEEE 802.15.4 LoRa Sigfox WiFi 2.4G WiFi 5G Zigbee Z-Wave Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.0 4 Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna Peak Gain vs. Frequency Peak Gain From Highest Direction (dBi) 15.00 10.00 5.00 dBi 0.00 -5.00 -10.00 -15.00 -20.00 0 1000 2000 3000 4000 5000 6000 4000 5000 6000 MHz Return Loss Return Loss in -dB 0.00 -2.00 -4.00 -6.00 -dB -8.00 -10.00 -12.00 -14.00 -16.00 -18.00 -20.00 0 1000 2000 3000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.0 5 Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna VSWR VSWR 10.00 9.00 8.00 VSWR 7.00 6.00 5.00 4.00 3.00 2.00 1.00 0 1000 2000 3000 4000 5000 6000 4000 5000 6000 MHz Radiation Efficiency Antenna Radiation Efficiency (in %) 110.00 100.00 90.00 80.00 % Efficiency 70.00 60.00 50.00 40.00 30.00 20.00 10.00 0.00 0 1000 2000 3000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.0 6 Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna Cat M E-UTRA Band Cat NB E-UTRA Band NR (5G) Band Cat NB NR (5G) Band Uplink Downlink Average Upload Efficiency (%) Average Download Efficiency (%) Maximum Upload VSWR Maximum Download VSWR 1 1 1 n1 n1 1920 - 1980 MHz 2110 - 2170 MHz 13.27 48.89 6.11 7.56 PCS-1900 2 2 2 2 n2 n2 1850 - 1910 MHz 1930 - 1990 MHz 11.75 13.82 6.49 6.34 DCS-1800 3 3 3 3 n3 n3 1710 - 1785 MHz 1805 - 1880 MHz 17.78 13.01 12.32 7.59 4 4 4 4 1710 - 1755 MHz 2110 - 2155 MHz 18.57 47.91 12.32 7.56 5 5 5 5 824 - 849 MHz 869 - 894 MHz 5.75 4.83 17.20 24.75 830 - 840 MHz 875 - 885 MHz 5.83 4.83 15.53 23.83 GSM-850 n5 n5 6 E-GSM-900 7 7 7 7 n7 n7 2500 - 2570 MHz 2620 - 2690 MHz 67.22 67.01 1.23 1.98 8 8 8 8 n8 n8 880 - 915 MHz 925 - 960 MHz 5.05 7.37 26.39 26.29 9 9 1749.9 - 1784.9 MHz 1844.9 - 1879.9 MHz 16.63 11.89 10.36 6.55 10 10 1710 - 1770 MHz 2110 - 2170 MHz 17.99 48.89 12.32 7.56 11 11 11 11 1427.9 - 1447.9 MHz 1475.9 - 1495.9 MHz 17.12 12.83 7.81 6.21 12 12 12 12 n12 n12 699 - 716 MHz 729 - 746 MHz 5.72 7.19 37.55 25.31 13 13 13 13 n13 n13 777 - 787 MHz 746 - 756 MHz 8.79 7.86 13.02 18.20 14 14 14 14 n14 788 - 798 MHz 758 - 768 MHz 8.27 8.37 12.50 14.95 704 - 716 MHz 734 - 746 MHz 5.82 7.33 34.83 23.28 815 - 830 MHz 860 - 875 MHz 6.45 4.67 13.91 21.86 830 - 845 MHz 875 - 890 MHz 5.71 4.85 16.42 24.55 832 - 862 MHz 791 - 821 MHz 5.24 7.48 19.44 12.91 1447.9 - 1462.9 MHz 1495.9 - 1510.9 MHz 16.47 10.90 6.33 6.74 3410 - 3490 MHz 3510 - 3590 MHz 40.30 42.94 4.13 3.26 1626.5 - 1660.5 MHz 1525 - 1559 MHz 24.43 10.19 12.50 7.60 1850 - 1915 MHz 1930 - 1995 MHz 11.77 14.09 6.49 6.57 814 - 849 MHz 859 - 894 MHz 6.01 4.78 17.20 24.75 807 - 824 MHz 852 - 869 MHz 6.87 4.71 13.17 20.87 703 - 748 MHz 758 - 803 MHz 6.57 8.45 35.42 14.95 17 17 18 18 18 19 19 19 19 20 20 20 20 21 21 21 21 22 22 n18 n20 24 24 24 n24 25 25 25 25 n25 26 26 26 26 n26 27 27 28 28 28 Suitable band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition n28 n18 n20 n25 n28 Adequate band in good signal conditions Use Indicator E-UTRA (4G) Band 1 GSM (2G) Band UMTS (3G) Band Cellular Standards Band Support Likely to be unsuitable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.0 7 Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna Average Download Efficiency (%) Maximum Upload VSWR Maximum Download VSWR 758 - 788 MHz 6.18 8.61 35.42 14.95 n29 N/A 717 - 728 MHz N/A 6.36 N/A 29.28 30 n30 2305 - 2315 MHz 2350 - 2360 MHz 75.21 82.02 1.81 1.25 452.5 - 457.5 MHz 462.5 - 467.5 MHz 1.70 1.55 40.98 42.34 32 N/A 1452 - 1496 MHz N/A 14.32 N/A 6.22 33 1900 - 1920 MHz 1900 - 1920 MHz 11.92 11.92 5.66 5.66 2010 - 2025 MHz 2010 - 2025 MHz 23.23 23.23 7.40 7.40 35 1850 - 1910 MHz 1850 - 1910 MHz 11.75 11.75 6.49 6.49 36 1930 - 1990 MHz 1930 - 1990 MHz 13.82 13.82 6.34 6.34 37 1910 - 1930 MHz 1910 - 1930 MHz 12.26 12.26 5.63 5.63 n38 2570 - 2620 MHz 2570 - 2620 MHz 67.72 67.72 1.42 1.42 n39 1880 - 1920 MHz 1880 - 1920 MHz 11.81 11.81 5.90 5.90 2300 - 2400 MHz 2300 - 2400 MHz 79.56 79.56 1.87 1.87 2496 - 2690 MHz 2496 - 2690 MHz 67.25 67.25 1.98 1.98 31 31 34 n34 38 39 39 40 40 41 41 41 42 42 42 3400 - 3600 MHz 3400 - 3600 MHz 41.54 41.54 4.23 4.23 43 43 43 3600 - 3800 MHz 3600 - 3800 MHz 38.83 38.83 6.56 6.56 44 703 - 803 MHz 703 - 803 MHz 7.56 7.56 35.42 35.42 45 1447 - 1467 MHz 1447 - 1467 MHz 16.31 16.31 6.39 6.39 n40 n41 n41 46 n46 5150 - 5925 MHz 5150 - 5925 MHz 63.17 63.17 4.33 4.33 47 n47 5855 - 5925 MHz 5855 - 5925 MHz 73.82 73.82 1.40 1.40 48 n48 3550 - 3700 MHz 3550 - 3700 MHz 43.59 43.59 4.94 4.94 3550 - 3700 MHz 3550 - 3700 MHz 43.59 43.59 4.94 4.94 49 50 n50 1432 - 1517 MHz 1432 - 1517 MHz 14.09 14.09 7.47 7.47 51 n51 1427 - 1432 MHz 1427 - 1432 MHz 16.65 16.65 7.90 7.90 3300 - 3400 MHz 3300 - 3400 MHz 40.16 40.16 4.52 4.52 52 Suitable band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Adequate band in good signal conditions Use Indicator Average Upload Efficiency (%) 703 - 733 MHz 29 31 32 Downlink 28A Uplink Cat NB NR (5G) Band NR (5G) Band Cat NB E-UTRA Band Cat M E-UTRA Band E-UTRA (4G) Band UMTS (3G) Band GSM (2G) Band Cellular Standards Band Support Likely to be unsuitable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.0 8 Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna 65 Average Upload Efficiency (%) Average Download Efficiency (%) Maximum Upload VSWR Maximum Download VSWR 2483.5 - 2495 MHz 2483.5 - 2495 MHz 65.55 65.55 1.26 1.26 65 n65 n65 1920 - 2010 MHz 2110 - 2200 MHz 14.82 50.90 7.05 7.56 66 n66 n66 1710 - 1780 MHz 2110 - 2200 MHz 17.84 50.90 12.32 7.56 N/A 738 - 758 MHz N/A 7.72 N/A 21.64 68 698 - 728 MHz 753 - 783 MHz 5.96 8.52 37.90 16.01 69 N/A 2570 - 2620 MHz N/A 67.72 N/A 1.42 1695 - 1710 MHz 1995 - 2020 MHz 23.36 20.78 12.81 7.30 663 - 698 MHz 617 - 652 MHz 5.44 5.20 43.73 42.23 66 66 67 n67 70 70 n70 n71 n70 71 71 71 72 72 72 451 - 456 MHz 461 - 466 MHz 1.74 1.55 40.39 42.34 73 73 73 450 - 455 MHz 460 - 465 MHz 1.77 1.55 40.01 42.34 74 74 74 n74 1427 - 1470 MHz 1475 - 1518 MHz 16.59 11.74 7.90 7.00 75 n75 N/A 1432 - 1517 MHz N/A 14.09 N/A 7.47 76 n76 N/A 1427 - 1432 MHz N/A 16.65 N/A 7.90 n77 3300 - 4200 MHz 3300 - 4200 MHz 31.34 31.34 13.77 13.77 n78 3300 - 3800 MHz 3300 - 3800 MHz 40.18 40.18 6.56 6.56 n79 4400 - 5000 MHz 4400 - 5000 MHz 20.76 20.76 10.89 10.89 n80 1710 - 1785 MHz N/A 17.78 N/A 12.32 N/A n81 880 - 915 MHz N/A 5.05 N/A 26.39 N/A n82 832 - 862 MHz N/A 5.24 N/A 19.44 N/A n83 703 - 748 MHz N/A 6.57 N/A 35.42 N/A n84 1920 - 1980 MHz N/A 13.27 N/A 6.11 N/A n85 698 - 716 MHz 728 - 746 MHz 5.71 7.16 37.90 25.66 n86 1710 - 1780 MHz N/A 17.84 N/A 12.32 N/A 85 85 85 87 87 87 410 - 415 MHz 420 - 425 MHz 3.12 2.80 29.58 31.54 88 88 88 412 - 417 MHz 422 - 427 MHz 3.06 2.73 29.01 32.08 Suitable band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Adequate band in good signal conditions Use Indicator Downlink Cat NB NR (5G) Band n53 Uplink 53 NR (5G) Band Cat NB E-UTRA Band Cat M E-UTRA Band E-UTRA (4G) Band UMTS (3G) Band GSM (2G) Band Cellular Standards Band Support Likely to be unsuitable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.0 9 Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna Downlink Average Upload Efficiency (%) Average Download Efficiency (%) Maximum Upload VSWR Maximum Download VSWR 5.75 N/A 17.20 N/A 2496 - 2690 MHz 2496 - 2690 MHz 67.25 67.25 1.98 1.98 n91 832 - 862 MHz 1427 - 1432 MHz 5.24 16.65 19.44 7.90 n92 832 - 862 MHz 1432 - 1517 MHz 5.24 14.09 19.44 7.47 n93 880 - 915 MHz 1427 - 1432 MHz 5.05 16.65 26.39 7.90 n94 880 - 915 MHz 1432 - 1517 MHz 5.05 14.09 26.39 7.47 n95 2010 - 2025 MHz N/A 23.23 N/A 7.40 N/A n97 2300 - 2400 MHz N/A 79.56 N/A 1.87 N/A n98 1880 - 1920 MHz N/A 11.81 N/A 5.90 N/A n99 1626.5 - 1660.5 MHz N/A 24.43 N/A 12.50 N/A n101 1900 - 1910 MHz 1900 - 1910 MHz 11.74 11.74 5.66 5.66 787 - 788 MHz 757 - 758 MHz 8.55 8.16 12.53 15.15 n89 n90 103 Suitable band n90 Adequate band in good signal conditions Use Indicator Uplink N/A Cat NB NR (5G) Band 824 - 849 MHz NR (5G) Band Cat NB E-UTRA Band Cat M E-UTRA Band E-UTRA (4G) Band UMTS (3G) Band GSM (2G) Band Cellular Standards Band Support Likely to be unsuitable NOTE: For each frequency band, Siretta provides a traffic light indication to show the suitability of the antenna for use at that frequency band. Determination of exactly what makes an antenna good or bad at any frequency is subjective. The view presented is that of Siretta’s engineering team having taken into account the efficiency and VSWR measurements. The end user is advised to use their own criteria and/or testing to confirm suitability. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.0 10 Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna ISM Standards Frequency Support Application Frequency Range Efficiency (%) Maximum VSWR Peak Gain from highest direction (dBi) ISM 433 MHz 433.05 - 434.79 MHz 2.37 33.25 -10.622 IMT 868 MHz 863 - 870 MHz 4.66 21.13 -4.535 ISM 915 MHz 902 - 928 MHz 5.51 26.39 -2.018 ISM 2.4 GHz 2400 - 2500 MHz 71.08 1.27 8.43 WiFi 2.4G 2401 - 2483 MHz 72.09 1.27 8.0305 WiFi 2.4G (USA) 2401 - 2473 MHz 72.99 1.27 7.953 WiFi 2.4G (Japan) 2401 - 2495 MHz 71.26 1.27 8.3125 WiFi 5G (all channels) 5150 - 5990 MHz 63.69 4.33 7.01 WiFi 5G (Ch 32-48) 5150 - 5250 MHz 52.79 4.28 3.92 WiFi 5G (Ch 32-64) 5150 - 5330 MHz 56.38 4.33 4.61 WiFi 5G (Ch 32-161) 5150 - 5815 MHz 61.23 4.33 6.47 WiFi 5G (Ch 32-173) 5150 - 5875 MHz 62.44 4.33 6.75 ISM 5.8 GHz 5725 - 5875 MHz 74.49 1.50 6.75 Suitable band Adequate band in good signal conditions Use Indicator Likley to be unsuitable NOTE: For each frequency band, Siretta provides a traffic light indication to show the suitability of the antenna for use at that frequency band. Determination of exactly what makes an antenna good or bad at any frequency is subjective. The view presented is that of Siretta’s engineering team having taken into account the efficiency and VSWR measurements. The end user is advised to use their own criteria and/or testing to confirm suitability. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.0 11 Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna 2D Radiation Plots 2300 MHz XY XZ YZ 2400 MHz XY XZ YZ 2500 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.0 12 Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna 2D Radiation Plots 2600 MHz XY XZ YZ 5200 MHz XY XZ YZ 5500 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.0 13 Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna 2D Radiation Plots 5800 MHz XY XZ YZ 5900 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.0 14 Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna 3D Radiation Plots 2300 MHz 2400 MHz 2500 MHz 2600 MHz 5200 MHz 5500 MHz 5800 MHz 5900 MHz NOTE: All 3D radiation plots are shown with Theta = 45 and Phi = 45. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.0 15 Tango 26 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna Ordering Details: Part Number Description TANGO26/0.1M/SMAM/S/RP/29 Miniature 4G/5G/WiFi/Bluetooth/Zigbee/ISM2.4G/ISM5.8G Through-Hole Mount Antenna Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.0 16
TANGO26/0.1M/SMAM/S/RP/29 价格&库存
很抱歉,暂时无法提供与“TANGO26/0.1M/SMAM/S/RP/29”相匹配的价格&库存,您可以联系我们找货
  • 1+152.268821+19.76697
