ALPHA4A/5M/SMAM/S/S/26
    SIRETTA
    Alpha 4A 是一款紧凑、自粘、防水的 GPS 天线,适用于户外安装。其 37 x 33mm 的尺寸使其能够轻松适应大多数表面,高度仅为 13mm,外观不显眼。内置低噪声放大器 (LNA) 提供 ...
ALPHA4A/5M/SMAM/S/S/26 数据手册
Alpha 4A GPS Antenna Key Features • • • • Adhesive or magnetic mountable 26db LNA gain Waterproof Compact size General Description Additional Considerations The Alpha 4A is a compact, self adhesive, waterproof, GPS antenna. Its 37 x 33mm footprint allows the Alpha 4A to fit onto most surface sizes quite comfortably, and with a modest height of only 13mm, it also provides an unobtrusive profile. The Alpha 4A comes with a strong self-adhesive base that provides a firm fixation to most flat surfaces, including: metal, glass, wood and plastic. The antenna is well suited to the harsher outdoor environment that GPS applications are often subject to. The Alpha 4A can be used for a host of different indoor or outdoor GPS applications or general positioning purposes. • Waterproof design which makes it ideal for mounting outdoors • Operates with GPS receivers with built in LNA circuit on board The built in Low Noise Amplifier (LNA) provides a 26dB gain for superior GPS performance necessary for strong signal reception from visible satellites; as well as influencing a shorter time for satellite fixing. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Ver 1.5 Alpha 4A GPS Antenna Dielectric Antenna Centre Frequency: Mechanical Specifications 1575.42+1MHz Polarization: RHCP Impedance: 50 Ohm VSWR: Axial Ratio:
ALPHA4A/5M/SMAM/S/S/26 价格&库存
很抱歉,暂时无法提供与“ALPHA4A/5M/SMAM/S/S/26”相匹配的价格&库存,您可以联系我们找货
  • 1+144.59613
  • 5+142.87785
库存:70
