ALPHA40/2.5M/SMAM/S/S/29
    SIRETTA
    Alpha 40 是一款多功能、宽带天线,支持多种IoT应用。其灵活的天线结构适合安装在大半径和弯曲表面上,简单的粘贴安装方式使其成为空间有限的IoT应用的理想选择。
ALPHA40/2.5M/SMAM/S/S/29 数据手册
Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna Key Features • Balanced dipole design - ground plane independent • Low Loss PRO100 cable • Flexible antenna construction suitable for fitting to largeradius, curved surfaces General Description Additional Considerations The Alpha 40 is a good wideband antenna for many IoT applications. The slim adhesive design is simple and quick to fit. • Simple installation with adhesive pads • Reduced attenuation from Low Loss cable • Meets all EU compliance criteria for electronic goods The antenna has two sticky pads to mount it wherever it is required. The pads ensure there is a small gap between the antenna and the surface it is to be mounted on. The Alpha 40 is available with different length cables and SMA Male connectors. Alternative cable lengths and connectors can be supplied for volume orders. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna Electrical Specifications Mechanical Specifications Impedance: 50 Ohm Dimensions: Max Input Power: 1 Watt Weight: Polarization: Vertical Cable: Ground Plane Independent: Yes 154.25 x 29.25 x 4.2 mm 40 g PRO100 low loss Connector: SMA Male Radome Material: Environmental Specification Operating Temperature range: PVC Mounting Method: Adhesive -30 - +60°C X Y Z orientation Return Loss tested with 1.5 m cable Return Loss in -dB 0.00 -2.00 -4.00 -6.00 -dB -8.00 -10.00 -12.00 -14.00 -16.00 -18.00 -20.00 0 1000 2000 3000 4000 5000 6000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna VSWR tested with 1.5 m cable VSWR 10.00 9.00 8.00 VSWR 7.00 6.00 5.00 4.00 3.00 2.00 1.00 0 1000 2000 3000 4000 5000 6000 4000 5000 6000 MHz Radiation Efficiency tested with 1.5 m cable Antenna Radiation Efficiency (in %) 110.00 100.00 90.00 80.00 % Efficiency 70.00 60.00 50.00 40.00 30.00 20.00 10.00 0.00 0 1000 2000 3000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna LTE/5G Band Coverage M/5G Bands NB-IoT Band 1/n1 B1 2/n2 3/n3 LTE, CAT- Avg Efficieny % over band Max VSWR over Band Uplink Downlink Europe / Asia 1920-1980 MHz 2110-2170 MHz 50.23 / 47.70 1.88 / 1.62 B2 North America/Latin America/Caribbean 1850-1910 MHz 1930-1990 MHz 43.47 / 51.02 1.92 / 1.92 B3 Europe/Africa/Asia/Oceania 1710-1785 MHz 1805-1880 MHz 38.17 / 40.04 1.83 / 1.92 4 B4 North America/Latin America/Caribbean 1710-1755 MHz 2110-2155 MHz 38.02 / 48.76 1.83 / 1.62 5/n5 B5 Country Specific 824-849 MHz 869-894 MHz 79.77 / 63.34 1.27 / 2.05 2500-2570 MHz 2620-2690 MHz 29.23 / 31.75 2.25 / 2.30 880-915 MHz 925-960 MHz 54.19 / 36.73 7/n7 8/n8 Regional Coverage Latin America/Europe/Asia + B8 Europe / Asia + 2.05 / 2.80 x 11 B11 Country Specific 1427.9-1447.9 MHz 1475.9-1495.9 MHz 12/n12 B12 North America/Caribbean + 699-716 MHz 729-746 MHz 3.90 / 7.02 29.82 / 44.16 3.81 / 3.42 3.95 / 3.61 13/n13 B13 North America/Caribbean + 777-787 MHz 746-756 MHz 70.49 / 48.78 2.09 / 3.13 14/n14 B14 Country Specific 788-798 MHz 758-768 MHz 77.23 / 56.28 2.01 / 2.71 17 B17 North America/Caribbean + 704-716 MHz 734.746 MHz 32.28 / 44.16 3.84 / 3.52 18/n18 B18 Country Specific 815-830 MHz 860-875 MHz 83.35 / 68.65 1.26 / 1.72 19 B19 Country Specific 830-845 MHz 875-890 MHz 79.77 / 63.34 1.26 / 2.04 20/n20 B20 Europe/Africa + 832-862 MHz 791-821 MHz 76.05 / 80.34 1.45 / 1.98 21 x Country Specific 1447.9-1462.9 MHz 1495.9-1510.9 MHz 25/n25 B25 Country Specific 1850-1915 MHz 1525-1559 MHz 43.47 / 19.24 1.92 / 3.15 26/n26 B26 Country Specific 814-849 MHz 859-894 MHz 80.62 / 67.05 1.39 / 2.05 28/n28 B28 Latin America/Europe/Asia + 703-748 MHz 758-803 MHz 44.16 / 68.15 3.84 / 2.71 - 717-728 MHz 35.04 29/n29 Country Specific 30/n30 31 B31 32 5.09 / 9.59 3.84 / 3.22 3.63 Country Specific 2305-2315 MHz 2350-2360 MHz 39.73 / 37.63 Country Specific 452.5-457.5 MHz 462.5-467.5 MHz 6.89 / 10.88 x 1.84 / 1.89 7.50 / 8.28 Country Specific - 1452-1496 MHz 6.14 x 3.84 38/n38 Europe + 2570-2620 MHz 30.51 2.30 39/n39 Country Specific 1880-1920 MHz 45.97 1.85 40/n40 Asia + 2300-2400 MHz 36.83 1.90 41/n41 Country Specific 2496-2690 MHz 30.16 2.30 42 Country Specific 3400-3600 MHz 26.81 2.27 43 Country Specific 3600-3800 MHz 22.75 2.67 46/n46 Country Specific 5150-5925 MHz 26.24 1.79 48/n48 Country Specific 3550-3700 MHz 24.62 2.38 65/n65 Country Specific 1920-2010 MHz 2110-2200 MHz 51.66 / 46.12 1.92 / 1.62 66/n66 B66 Country Specific 1710-1780 MHz 2110-2200 MHz 38.51 / 46.12 1.83 / 1.62 71/n71 B71 Country Specific 663-698 MHz 617-652 MHz 26.63 / 18.58 4.88 / 5.60 Table data for bands as detailed in 3GPP TS 36.101 & 38.101 Usable Band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Adequate in good signal area x Not Usable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna 5G Extended Table for Band Coverage LTE/5G Band NB-IoT Band n24 Uplink Downlink 1626.5 – 1660.5 MHz 1525 – 1559 MHz Max VSWR over Band Avg Efficieny % over band 37.29 / 19.24 1.98 / 3.15 n34 2010 – 2025 MHz 54.08 n47 5855 – 5925 MHz 30.28 n50 1432 – 1517 MHz 6.75 x 3.84 n51 1427 – 1432 MHz 3.51 x 3.54 n53 2483.5 – 2495 MHz 27.07 2.18 n67 738 – 758 MHz 44.16 3.45 n70 B70 n74 1.71 1.30 1695 – 1710 MHz 1995 – 2020 MHz 38.91 / 53.36 1427 – 1470 MHz 1475 – 1518 MHz 4.69 / 8.37 x 3.84 / 3.42 1.86 / 1.90 n75 1432 – 1517 MHz 6.75 x 3.84 n76 1427 – 1432 MHz 3.51 x 3.54 n77 3300 – 4200 MHz 22.56 2.67 n78 3300 – 3800 MHz 25.85 2.67 n79 4400 – 5000 MHz 18.93 2.37 n80 1710 – 1785 MHz 38.17 1.83 n81 880 – 915 MHz 54.19 2.05 n82 832 – 862 MHz 76.05 1.45 n83 703 – 748 MHz 40.53 3.84 1920 – 1980 MHz 50.23 1.88 n84 n85 B85 n86 698 – 716 MHz 728 – 746 MHz 29.82 / 44.16 3.95 / 3.61 1710 – 1780 MHz 38.51 1.83 n89 824 – 849 MHz 79.77 1.27 n90 2496 – 2690 MHz 30.16 2.30 n91 832 – 862 MHz 1427 – 1432 MHz 76.05 / 3.51 x n92 832 – 862 MHz 1432 – 1517 MHz 76.05 / 6.75 x 1.45 / 3.84 n93 880 – 915 MHz 1427 – 1432 MHz 54.19 / 3.51 x 2.05 / 3.54 n94 880 – 915 MHz 1432 – 1517 MHz 54.19 / 6.75 x 2.05 / 3.84 54.08 1.45 / 3.54 n95 2010 – 2025 MHz n96 5925 – 7125 MHz n97 2300 – 2400 MHz 36.83 1.90 n98 1880 – 1920 MHz 45.97 1.85 n99 1626.5 – 1660.5 MHz 37.29 1.98 1.71 not measured Table data for bands as detailed in 3GPP TS 38.101 Usable Band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Adequate in good signal area x Not Usable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna Radiation Plots tested with 1.5 m cable 600 MHz XY XZ YZ 700 MHz XY XZ YZ 800 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna Radiation Plots tested with 1.5 m cable 900 MHz XY XZ YZ 1500 MHz XY XZ YZ 1600 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna Radiation Plots tested with 1.5 m cable 1700 MHz XY XZ YZ 1800 MHz XY XZ YZ 1900 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna Radiation Plots tested with 1.5 m cable 2000 MHz XY XZ YZ 2100 MHz XY XZ YZ 2200 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna Radiation Plots tested with 1.5 m cable 2300 MHz XY XZ YZ 2400 MHz XY XZ YZ WiFi Band 2.4 GHz WiFi Band 2.4 GHz Eff % 30.13 Eff % 30.13 2460 MHz XY XZ YZ WiFi Band 2.4 GHz WiFi Band 2.4 GHz Eff % 39.9 Eff % 39.9 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna Radiation Plots tested with 1.5 m cable 2500 MHz XY XZ YZ WiFi Band 2.4 GHz WiFi Band 2.4 GHz Eff % 27.10 Eff % 27.10 2600 MHz XY XZ YZ 2700 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna Radiation Plots tested with 1 m cable 3300 MHz XY XZ YZ 3400 MHz XY XZ YZ 3500 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna Radiation Plots tested with 1.5 m cable 3600 MHz XY XZ YZ 3700 MHz XY XZ YZ 3800 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna Radiation Plots tested with 1.5 m cable 4000 MHz XY XZ YZ 4200 MHz XY XZ YZ 4400 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna Radiation Plots tested with 1.5 m cable 4600 MHz XY XZ YZ 4800 MHz XY XZ YZ 5000 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna Radiation Plots tested with 1.5 m cable 5200 MHz XY XZ YZ 5400 MHz XY XZ YZ 5600 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna Radiation Plots tested with 1.5 m cable 5800 MHz XY XZ YZ 6000 MHz XY XZ YZ 3D Radiation Plots tested with 1.5 m cable 600 MHz 700 MHz 800 MHz Theta 65 Phi 45 Theta 65 Phi 45 Theta 65 Phi 45 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna 3D Radiation Plots tested with 1.5 m cable 900 MHz Theta 65 Phi 45 1700 MHz 1500 MHz Theta 65 Phi 45 1800 MHz 1600 MHz Theta 65 Phi 45 1900 MHz Theta 65 Phi 45 Theta 65 Phi 45 Theta 65 Phi 45 2000 MHz 2100 MHz 2200 MHz Theta 65 Phi 45 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Theta 65 Phi 45 Theta 65 Phi 45 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna 3D Radiation Plots tested with 1.5 m cable 2300 MHz Theta 65 Phi 45 2500 MHz 2400 MHz Theta 65 Phi 45 2600 MHz 2460 MHz Theta 65 Phi 45 2700 MHz Theta 65 Phi 45 Theta 65 Phi 45 Theta 65 Phi 45 3300 MHz 3400 MHz 3500 MHz Theta 65 Phi 45 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Theta 65 Phi 45 Theta 65 Phi 45 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna 3D Radiation Plots tested with 1.5 m cable 3600 MHz Theta 65 Phi 45 4000 MHz 3700 MHz Theta 65 Phi 45 4200 MHz 3800 MHz Theta 65 Phi 45 4400 MHz Theta 65 Phi 45 Theta 65 Phi 45 Theta 65 Phi 45 4600 MHz 4800 MHz 5000 MHz Theta 65 Phi 45 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Theta 65 Phi 45 Theta 65 Phi 45 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Alpha 40 2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna 3D Radiation Plots tested with 1.5 m cable 5200 MHz Theta 65 Phi 45 5800 MHz Theta 65 Phi 45 5400 MHz Theta 65 Phi 45 5600 MHz Theta 65 Phi 45 6000 MHz Theta 65 Phi 45 Ordering Details Part Number Description ALPHA40/1.5M/SMAM/S/S29 2G/3G/4G/5G/DUALBAND WIFI ADHESIVE T-BAR ANTENNA SMA MALE 1.5M CABLE ALPHA40/2.5M/SMAM/S/S29 2G/3G/4G/5G/DUALBAND WIFI ADHESIVE T-BAR ANTENNA SMA MALE 2.5M CABLE ALPHA40/5M/SMAM/S/S29 2G/3G/4G/5G/DUALBAND WIFI ADHESIVE T-BAR ANTENNA SMA MALE 5M CABLE Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0
ALPHA40/2.5M/SMAM/S/S/29 价格&库存
很抱歉,暂时无法提供与“ALPHA40/2.5M/SMAM/S/S/29”相匹配的价格&库存,您可以联系我们找货
