SPECIFICATION
Part No.
FW.86.B.NTY.M
Description
Meteor-868MHz Flexible Whip
Monopole Antenna
Features
External 868MHz Monopole Antenna
Rugged Design for Outdoor Use
Robust Inner Steel Core
Antenna Height 243mm
N Type(M) Straight Connector
IP67 dust and water-resistant
*Tested on 30*30cm Ground Plane
RoHS Compliant
SP-15-8-SPE-16-8-080/A
Page 1 of 11
1. Introduction
The FW.86 is a flexible 868MHz whip antenna with an N type(M) connector for
outdoor use. It features excellent efficiency and high peak gain at 868MHz on a
30*30cm ground plane.
The antenna was specifically developed for applications such as weather
monitoring systems, motion/vibration sensors, pollution monitoring, and border
guard monitoring systems.
The FW.86 works at 868MHz with high efficiency, meaning that it allows your
radio to consume less power than with a lower efficiency antenna when
transferring data.
The whip is made of a flexible inner steel core covered by PE so it is extremely
resistant to abrasion and maintains its original shape and RF performance. This
rugged design and IP67 rating has been tested by our customers to withstand
environmental stress and moderate physical shock in the field.
The FW.86.B.NTY.M 868MHz whip antenna, with an N type male connector,
provides a simple solution to any outdoor devices where the FW.86 antenna’s
rugged design and high efficiency can provide the best value to the application
Page 2 of 11
2. Specification
FW.86.B.NTY.M
Center Frequency
850MHz
868MHz
890MHz
Efficiency
67.52%
70.60%
67.54%
Peak Gain
1.82dBi
2.82dBi
3.58dBi
Average Gain
-1.71dB
-1.51dB
-1.70dB
Impedance
50Ω
Polarization
Linear
Radiation Pattern
Omnidirectional
Input Power
2W
MECHANICAL
Dimensions
243 ± 5.3mm
Base Diameter
20 ± 0.6mm
Whip Diameter
6.2 ± 0.6mm
Casing
ABS
Connector
N Type(M) Straight
Weight
Dust and Water
Resistance
48.5g
IP67
ENVIRONMENTAL
Temperature Range
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
*All tested on 30*30cm Ground Plane
Page 3 of 11
3. Antenna Characteristics
3.1.
3.2.
Return Loss
Efficiency
Page 4 of 11
3.3.
Peak Gain
3.4.
Average Gain
Page 5 of 11
4. Antenna Radiation Pattern
4.1.
Antenna Setup
On 30*30cm ground plane
Y
Z
X
Page 6 of 11
4.2.
2-D Radiation Pattern
On 30*30cm Ground Plane
XY Plane
X
Y
XZ Plane
YZ Plane
Page 7 of 11
4.3 3-D Radiation Pattern
@868MHz
Page 8 of 11
5. Antenna Drawing (Unit: mm)
Page 9 of 11
6. Packaging
Page 10 of 11
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
Page 11 of 11
很抱歉,暂时无法提供与“FW.86.B.NTY.M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+257.10480
- 200+102.58920
- 500+99.16560
- 1000+97.47000
- 国内价格 香港价格
- 1+192.154271+24.90685
- 10+153.5561510+19.90380
- 50+138.1147750+17.90231
- 100+133.33435100+17.28267
- 250+128.28771250+16.62853
- 500+125.24640500+16.23432
