MIKE2A/3M/SMAM/S/S/26
    SIRETTA
    Mike 2A 是一个四频段 2G 和 3G 兼容的全向天线,具有强磁性底座,提供高增益 5dBi。
MIKE2A/3M/SMAM/S/S/26 数据手册
Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA Key Features • • • • Supports 5G NR / 4G LTE / 3G UMTS / 2G Quad-band GSM Supports LTE Cat M, LTE Cat NB, NR Cat NB Supports LoRa, Sigfox, IMT 868 MHz, ISM 915 MHz bands Strong magnetic base General Description Additional Considerations The Mike 2A is a ½ wave omni-directional antenna that operates on quad band 2G, 3G, 4G, 5G LTE and ISM 868 and 915 frequencies. • Allows quick and easy implementation into target applications • Magnetic mounting allows versatility in positioning • Meets all EU compliance criteria for electronic goods The Mike 2A comes with a magnetic base giving good stability. As standard, the Mike 2A comes with an SMA Male on RG174 cable or a low loss variant. The antenna is also available as standard with an FME Female connector on. Alternative cable lengths and connector types can be fitted for small volume orders. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 976 9000 sales@siretta.com www.siretta.com Rev 3.0 1 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA Electrical Specifications Impedance: 50 Ohm Polarization: Vertical Max Input Power: 10 W Ground plane independent: Yes Environmental Specifications Operating Temperature range: -40 to +85 °C Storage Temperature range: -40 to +85 °C Mechanical Specifications Dimensions: Weight: Cable: Connector: 311 mm (Height) x 40 mm (Base) 4.8 g RG174 or Low Loss LMR100 SMA Male Mounting method: Magnetic Housing materials: ABS Z Y X orientation Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 2 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA Spectrum Coverage Suitable band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Adequate band in good signal conditions Likely to be unsuitable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 3 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA Usable Cellular Frequency Support (410 MHz – 1900 MHz) 410 450 600 700 800 850 900 1500 1600 1700 1800 1900 GSM Bands: UMTS Bands: LTE Bands: LTE Cat M Bands: LTE Cat NB Bands: 5G NR Bands: NR Cat NB Bands: Usable Cellular Frequency Support (2000 MHz – 5900 MHz) 2000 2100 2300 2400 2500 2600 3300 3500 3700 4700 5200 5900 GSM Bands: UMTS Bands: LTE Bands: LTE Cat M Bands: LTE Cat NB Bands: 5G NR Bands: NR Cat NB Bands: Usable ISM Frequency Support (433 MHz - 5800 MHz) 433 868 915 2450 5800 Bluetooth IEEE 802.15.4 LoRa Sigfox WiFi 2.4G WiFi 5G Zigbee Z-Wave Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 4 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA Peak Gain vs. Frequency Peak Gain From Highest Direction (dBi) 10.00 5.00 0.00 dBi -5.00 -10.00 -15.00 -20.00 0 1000 2000 3000 4000 5000 6000 4000 5000 6000 MHz Return Loss Return Loss in -dB 0.00 -2.00 -4.00 -6.00 -dB -8.00 -10.00 -12.00 -14.00 -16.00 -18.00 -20.00 0 1000 2000 3000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 5 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA VSWR VSWR 10.00 9.00 8.00 VSWR 7.00 6.00 5.00 4.00 3.00 2.00 1.00 0 1000 2000 3000 4000 5000 6000 4000 5000 6000 MHz Radiation Efficiency Antenna Radiation Efficiency (in %) 110.00 100.00 90.00 80.00 % Efficiency 70.00 60.00 50.00 40.00 30.00 20.00 10.00 0.00 0 1000 2000 3000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 6 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA Cat M E-UTRA Band Cat NB E-UTRA Band NR (5G) Band Cat NB NR (5G) Band Uplink Downlink Average Upload Efficiency (%) Average Download Efficiency (%) Maximum Upload VSWR Maximum Download VSWR 1 1 1 n1 n1 1920 - 1980 MHz 2110 - 2170 MHz 25.85 24.00 1.92 1.85 PCS-1900 2 2 2 2 n2 n2 1850 - 1910 MHz 1930 - 1990 MHz 29.28 25.11 1.78 1.92 DCS-1800 3 3 3 3 n3 n3 1710 - 1785 MHz 1805 - 1880 MHz 27.97 27.30 1.68 1.83 4 4 4 4 1710 - 1755 MHz 2110 - 2155 MHz 28.95 23.19 1.68 1.85 5 5 5 5 824 - 849 MHz 869 - 894 MHz 50.27 49.44 1.51 1.47 830 - 840 MHz 875 - 885 MHz 50.48 49.30 1.45 1.45 GSM-850 n5 n5 6 E-GSM-900 7 7 7 7 n7 n7 2500 - 2570 MHz 2620 - 2690 MHz 18.32 22.50 1.93 1.67 8 8 8 8 n8 n8 880 - 915 MHz 925 - 960 MHz 48.57 35.37 1.72 2.17 9 9 1749.9 - 1784.9 MHz 1844.9 - 1879.9 MHz 26.60 28.42 1.65 1.78 10 10 1710 - 1770 MHz 2110 - 2170 MHz 28.39 24.00 1.68 1.85 11 11 11 11 1427.9 - 1447.9 MHz 1475.9 - 1495.9 MHz 41.11 34.30 1.31 1.52 12 12 12 12 n12 n12 699 - 716 MHz 729 - 746 MHz 22.94 22.67 2.82 2.89 13 13 13 13 n13 n13 777 - 787 MHz 746 - 756 MHz 33.20 25.35 2.52 2.88 14 14 14 14 n14 788 - 798 MHz 758 - 768 MHz 38.00 28.19 2.09 2.58 704 - 716 MHz 734 - 746 MHz 22.52 22.97 2.82 2.89 815 - 830 MHz 860 - 875 MHz 46.19 49.85 1.74 1.21 830 - 845 MHz 875 - 890 MHz 50.98 49.34 1.45 1.47 832 - 862 MHz 791 - 821 MHz 51.05 42.01 1.43 1.96 1447.9 - 1462.9 MHz 1495.9 - 1510.9 MHz 39.38 31.07 1.29 1.70 3410 - 3490 MHz 3510 - 3590 MHz 9.87 12.53 1.91 1.81 1626.5 - 1660.5 MHz 1525 - 1559 MHz 30.30 28.15 1.75 1.81 1850 - 1915 MHz 1930 - 1995 MHz 29.29 25.00 1.78 1.93 814 - 849 MHz 859 - 894 MHz 48.79 49.61 1.77 1.47 807 - 824 MHz 852 - 869 MHz 44.34 50.30 1.94 1.21 703 - 748 MHz 758 - 803 MHz 22.33 33.53 2.89 2.58 17 17 18 18 18 19 19 19 19 20 20 20 20 21 21 21 21 22 22 n18 n20 24 24 24 n24 25 25 25 25 n25 26 26 26 26 n26 27 27 28 28 28 Suitable band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition n28 n18 n20 n25 n28 Adequate band in good signal conditions Use Indicator E-UTRA (4G) Band 1 GSM (2G) Band UMTS (3G) Band Cellular Standards Band Support Likely to be unsuitable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 7 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA Average Download Efficiency (%) Maximum Upload VSWR Maximum Download VSWR 758 - 788 MHz 21.94 30.78 2.82 2.58 n29 N/A 717 - 728 MHz N/A 21.23 N/A 2.82 30 n30 2305 - 2315 MHz 2350 - 2360 MHz 17.45 16.73 1.63 2.00 452.5 - 457.5 MHz 462.5 - 467.5 MHz 4.54 4.02 2.29 3.04 32 N/A 1452 - 1496 MHz N/A 36.40 N/A 1.54 33 1900 - 1920 MHz 1900 - 1920 MHz 29.51 29.51 1.64 1.64 2010 - 2025 MHz 2010 - 2025 MHz 24.68 24.68 1.78 1.78 35 1850 - 1910 MHz 1850 - 1910 MHz 29.28 29.28 1.78 1.78 36 1930 - 1990 MHz 1930 - 1990 MHz 25.11 25.11 1.92 1.92 37 1910 - 1930 MHz 1910 - 1930 MHz 29.10 29.10 1.57 1.57 n38 2570 - 2620 MHz 2570 - 2620 MHz 21.67 21.67 1.76 1.76 n39 1880 - 1920 MHz 1880 - 1920 MHz 29.84 29.84 1.64 1.64 2300 - 2400 MHz 2300 - 2400 MHz 17.41 17.41 2.00 2.00 2496 - 2690 MHz 2496 - 2690 MHz 20.67 20.67 1.93 1.93 31 31 34 n34 38 39 39 40 40 41 41 41 42 42 42 3400 - 3600 MHz 3400 - 3600 MHz 11.22 11.22 1.91 1.91 43 43 43 3600 - 3800 MHz 3600 - 3800 MHz 14.23 14.23 1.84 1.84 44 703 - 803 MHz 703 - 803 MHz 27.72 27.72 2.89 2.89 45 1447 - 1467 MHz 1447 - 1467 MHz 39.16 39.16 1.42 1.42 n40 n41 n41 46 n46 5150 - 5925 MHz 5150 - 5925 MHz 7.14 7.14 1.67 1.67 47 n47 5855 - 5925 MHz 5855 - 5925 MHz 5.97 5.97 1.49 1.49 48 n48 3550 - 3700 MHz 3550 - 3700 MHz 15.03 15.03 1.77 1.77 3550 - 3700 MHz 3550 - 3700 MHz 15.03 15.03 1.77 1.77 49 50 n50 1432 - 1517 MHz 1432 - 1517 MHz 36.14 36.14 1.70 1.70 51 n51 1427 - 1432 MHz 1427 - 1432 MHz 41.30 41.30 1.20 1.20 3300 - 3400 MHz 3300 - 3400 MHz 10.18 10.18 1.94 1.94 52 Suitable band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Adequate band in good signal conditions Use Indicator Average Upload Efficiency (%) 703 - 733 MHz 29 31 32 Downlink 28A Uplink Cat NB NR (5G) Band NR (5G) Band Cat NB E-UTRA Band Cat M E-UTRA Band E-UTRA (4G) Band UMTS (3G) Band GSM (2G) Band Cellular Standards Band Support Likely to be unsuitable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 8 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA 65 Average Upload Efficiency (%) Average Download Efficiency (%) Maximum Upload VSWR Maximum Download VSWR 2483.5 - 2495 MHz 2483.5 - 2495 MHz 16.45 16.45 1.98 1.98 65 n65 n65 1920 - 2010 MHz 2110 - 2200 MHz 25.17 25.32 1.98 1.85 66 n66 n66 1710 - 1780 MHz 2110 - 2200 MHz 28.10 25.32 1.68 1.85 N/A 738 - 758 MHz N/A 24.66 N/A 2.89 68 698 - 728 MHz 753 - 783 MHz 22.32 29.40 2.82 2.75 69 N/A 2570 - 2620 MHz N/A 21.67 N/A 1.76 1695 - 1710 MHz 1995 - 2020 MHz 33.25 23.89 1.43 1.98 663 - 698 MHz 617 - 652 MHz 32.52 41.80 2.37 2.89 66 66 67 n67 70 70 n70 n71 n70 71 71 71 72 72 72 451 - 456 MHz 461 - 466 MHz 4.65 4.07 2.57 2.82 73 73 73 450 - 455 MHz 460 - 465 MHz 4.72 4.10 2.75 2.68 74 74 74 n74 1427 - 1470 MHz 1475 - 1518 MHz 39.97 32.71 1.51 1.70 75 n75 N/A 1432 - 1517 MHz N/A 36.14 N/A 1.70 76 n76 N/A 1427 - 1432 MHz N/A 41.30 N/A 1.20 n77 3300 - 4200 MHz 3300 - 4200 MHz 12.82 12.82 1.94 1.94 n78 3300 - 3800 MHz 3300 - 3800 MHz 12.22 12.22 1.94 1.94 n79 4400 - 5000 MHz 4400 - 5000 MHz 9.79 9.79 1.70 1.70 n80 1710 - 1785 MHz N/A 27.97 N/A 1.68 N/A n81 880 - 915 MHz N/A 48.57 N/A 1.72 N/A n82 832 - 862 MHz N/A 51.05 N/A 1.43 N/A n83 703 - 748 MHz N/A 22.33 N/A 2.89 N/A n84 1920 - 1980 MHz N/A 25.85 N/A 1.92 N/A n85 698 - 716 MHz 728 - 746 MHz 23.03 22.62 2.82 2.89 n86 1710 - 1780 MHz N/A 28.10 N/A 1.68 N/A 85 85 85 87 87 87 410 - 415 MHz 420 - 425 MHz 6.75 6.28 4.56 4.65 88 88 88 412 - 417 MHz 422 - 427 MHz 6.65 6.21 4.60 4.58 Suitable band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Adequate band in good signal conditions Use Indicator Downlink Cat NB NR (5G) Band n53 Uplink 53 NR (5G) Band Cat NB E-UTRA Band Cat M E-UTRA Band E-UTRA (4G) Band UMTS (3G) Band GSM (2G) Band Cellular Standards Band Support Likely to be unsuitable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 9 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA Downlink Average Upload Efficiency (%) Average Download Efficiency (%) Maximum Upload VSWR Maximum Download VSWR 50.27 N/A 1.51 N/A 2496 - 2690 MHz 2496 - 2690 MHz 20.67 20.67 1.93 1.93 n91 832 - 862 MHz 1427 - 1432 MHz 51.05 41.30 1.43 1.20 n92 832 - 862 MHz 1432 - 1517 MHz 51.05 36.14 1.43 1.70 n93 880 - 915 MHz 1427 - 1432 MHz 48.57 41.30 1.72 1.20 n94 880 - 915 MHz 1432 - 1517 MHz 48.57 36.14 1.72 1.70 n95 2010 - 2025 MHz N/A 24.68 N/A 1.78 N/A n97 2300 - 2400 MHz N/A 17.41 N/A 2.00 N/A n98 1880 - 1920 MHz N/A 29.84 N/A 1.64 N/A n99 1626.5 - 1660.5 MHz N/A 30.30 N/A 1.75 N/A n101 1900 - 1910 MHz 1900 - 1910 MHz 29.58 29.58 1.64 1.64 787 - 788 MHz 757 - 758 MHz 35.55 26.89 2.15 2.61 n89 n90 103 Suitable band n90 Adequate band in good signal conditions Use Indicator Uplink N/A Cat NB NR (5G) Band 824 - 849 MHz NR (5G) Band Cat NB E-UTRA Band Cat M E-UTRA Band E-UTRA (4G) Band UMTS (3G) Band GSM (2G) Band Cellular Standards Band Support Likely to be unsuitable NOTE: For each frequency band, Siretta provides a traffic light indication to show the suitability of the antenna for use at that frequency band. Determination of exactly what makes an antenna good or bad at any frequency is subjective. The view presented is that of Siretta’s engineering team having taken into account the efficiency and VSWR measurements. The end user is advised to use their own criteria and/or testing to confirm suitability. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 10 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA ISM Standards Frequency Support Application Frequency Range Efficiency (%) Maximum VSWR Peak Gain from highest direction (dBi) ISM 433 MHz 433.05 - 434.79 MHz 5.84 3.82 -5.8155 IMT 868 MHz 863 - 870 MHz 49.90 1.18 -0.015 ISM 915 MHz 902 - 928 MHz 44.89 1.78 0.227 ISM 2.4 GHz 2400 - 2500 MHz 16.63 2.04 -1.09 WiFi 2.4G 2401 - 2483 MHz 16.59 2.04 -1.27 WiFi 2.4G (USA) 2401 - 2473 MHz 16.73 2.04 -1.27 WiFi 2.4G (Japan) 2401 - 2495 MHz 16.57 2.04 -1.26 WiFi 5G (all channels) 5150 - 5990 MHz 7.03 1.67 -3.23 WiFi 5G (Ch 32-48) 5150 - 5250 MHz 7.00 1.67 -4.09 WiFi 5G (Ch 32-64) 5150 - 5330 MHz 7.14 1.67 -3.95 WiFi 5G (Ch 32-161) 5150 - 5815 MHz 7.31 1.67 -3.23 WiFi 5G (Ch 32-173) 5150 - 5875 MHz 7.23 1.67 -3.23 ISM 5.8 GHz 5725 - 5875 MHz 6.26 1.58 -3.98 Suitable band Adequate band in good signal conditions Use Indicator Likely to be unsuitable NOTE: For each frequency band, Siretta provides a traffic light indication to show the suitability of the antenna for use at that frequency band. Determination of exactly what makes an antenna good or bad at any frequency is subjective. The view presented is that of Siretta’s engineering team having taken into account the efficiency and VSWR measurements. The end user is advised to use their own criteria and/or testing to confirm suitability. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 11 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA 2D Radiation Plots 600 MHz XY XZ YZ 700 MHz XY XZ YZ 800 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 12 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA 2D Radiation Plots 900 MHz XY XZ YZ 1500 MHz XY XZ YZ 1600 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 13 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA 2D Radiation Plots 1700 MHz XY XZ YZ 1800 MHz XY XZ YZ 1900 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 14 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA 2D Radiation Plots 2000 MHz XY XZ YZ 2100 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 15 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA 3D Radiation Plots 600 MHz 700 MHz 800 MHz 900 MHz 1500 MHz 1600 MHz 1700 MHz 1800 MHz 1900 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 16 Mike 2A 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA 3D Radiation Plots 2000 MHz 2100 MHz NOTE: All 3D radiation plots are shown with Theta = 45 and Phi = 45. Ordering Details: Part Number Description MIKE2A/3M/SMAM/S/S/26 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA SMA Male Connector 3M Cable MIKE2A/5M/SMAM/S/S/26 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA SMA Male Connector 5M Cable MIKE2A/3M/LL1/SMAM/S/S/26 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA SMA Male Connector 3M Low Loss Cable MIKE2A/5M/LL1/SMAM/S/S/26 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA SMA Male Connector 5M Low Loss Cable MIKE2A/3M/FMEF/S/S/26 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA FME Female Connector 3M Cable MIKE2A/5M/FMEF/S/S/26 2G/3G/4G/5G/LoRa HIGH GAIN 311MM MAG MOUNT WHIP ANTENNA FME Female Connector 5M Cable Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 3.0 17
MIKE2A/3M/SMAM/S/S/26 价格&库存
很抱歉,暂时无法提供与“MIKE2A/3M/SMAM/S/S/26”相匹配的价格&库存,您可以联系我们找货
