ALPHA40/5M/SMAM/S/S/29 数据手册
Alpha 40
2G/3G/4G/5G/Dual Band WiFi Adhesive T-bar Antenna
Key Features
• Balanced dipole design - ground plane independent
• Low Loss PRO100 cable
• Flexible antenna construction suitable for fitting to largeradius, curved surfaces
General Description
Additional Considerations
The Alpha 40 is a good wideband
antenna for many IoT applications.
The slim adhesive design is simple and
quick to fit.
• Simple installation with adhesive pads
• Reduced attenuation from Low Loss cable
• Meets all EU compliance criteria for electronic goods
The antenna has two sticky pads to
mount it wherever it is required. The
pads ensure there is a small gap
between the antenna and the surface it
is to be mounted on.
The Alpha 40 is available with
different length cables and SMA Male
connectors. Alternative cable lengths
and connectors can be supplied for
volume orders.
Registered in England No. 08405712
VAT Registration No. GB163 04 0349
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
Electrical Specifications
Mechanical Specifications
Impedance:
50 Ohm
Dimensions:
Max Input Power:
1 Watt
Weight:
Polarization:
Vertical
Cable:
Ground Plane Independent:
Yes
154.25 x 29.25 x 4.2 mm
40 g
PRO100 low loss
Connector:
SMA Male
Radome Material:
Environmental Specification
Operating
Temperature range:
PVC
Mounting Method:
Adhesive
-30 - +60°C
X
Y
Z
orientation
Return Loss tested with 1.5 m cable
Return Loss in -dB
0.00
-2.00
-4.00
-6.00
-dB
-8.00
-10.00
-12.00
-14.00
-16.00
-18.00
-20.00
2000
3000
4000
5000
6000
MHz
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
VSWR tested with 1.5 m cable
VSWR
10.00
9.00
8.00
VSWR
7.00
6.00
5.00
4.00
3.00
2.00
1.00
2000
3000
4000
5000
6000
4000
5000
6000
MHz
Radiation Efficiency tested with 1.5 m cable
Antenna Radiation Efficiency (in %)
110.00
100.00
90.00
80.00
% Efficiency
70.00
60.00
50.00
40.00
30.00
20.00
10.00
0.00
2000
3000
MHz
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
LTE/5G Band Coverage
M/5G Bands
NB-IoT
Band
1/n1
B1
2/n2
3/n3
LTE, CAT-
Avg Efficieny %
over band
Max VSWR
over Band
Uplink
Downlink
Europe / Asia
1920-1980 MHz
2110-2170 MHz
50.23 / 47.70
1.88 / 1.62
B2
North America/Latin America/Caribbean
1850-1910 MHz
1930-1990 MHz
43.47 / 51.02
1.92 / 1.92
B3
Europe/Africa/Asia/Oceania
1710-1785 MHz
1805-1880 MHz
38.17 / 40.04
1.83 / 1.92
4
B4
1710-1755 MHz
2110-2155 MHz
38.02 / 48.76
1.83 / 1.62
5/n5
B5
Country Specific
824-849 MHz
869-894 MHz
79.77 / 63.34
1.27 / 2.05
2500-2570 MHz
2620-2690 MHz
29.23 / 31.75
2.25 / 2.30
880-915 MHz
925-960 MHz
54.19 / 36.73
7/n7
8/n8
Regional Coverage
Latin America/Europe/Asia +
B8
Europe / Asia +
2.05 / 2.80
x
11
B11
Country Specific
1427.9-1447.9 MHz
1475.9-1495.9 MHz
12/n12
B12
North America/Caribbean +
699-716 MHz
729-746 MHz
3.90 / 7.02
29.82 / 44.16
3.81 / 3.42
3.95 / 3.61
13/n13
B13
777-787 MHz
746-756 MHz
70.49 / 48.78
2.09 / 3.13
14/n14
B14
Country Specific
788-798 MHz
758-768 MHz
77.23 / 56.28
2.01 / 2.71
17
B17
704-716 MHz
734.746 MHz
32.28 / 44.16
3.84 / 3.52
18/n18
B18
Country Specific
815-830 MHz
860-875 MHz
83.35 / 68.65
1.26 / 1.72
19
B19
Country Specific
830-845 MHz
875-890 MHz
79.77 / 63.34
1.26 / 2.04
20/n20
B20
Europe/Africa +
832-862 MHz
791-821 MHz
76.05 / 80.34
1.45 / 1.98
21
x
Country Specific
1447.9-1462.9 MHz
1495.9-1510.9 MHz
25/n25
B25
Country Specific
1850-1915 MHz
1525-1559 MHz
43.47 / 19.24
1.92 / 3.15
26/n26
B26
Country Specific
814-849 MHz
859-894 MHz
80.62 / 67.05
1.39 / 2.05
28/n28
B28
703-748 MHz
758-803 MHz
44.16 / 68.15
3.84 / 2.71
717-728 MHz
35.04
29/n29
Country Specific
30/n30
31
B31
32
5.09 / 9.59
3.84 / 3.22
3.63
Country Specific
2305-2315 MHz
2350-2360 MHz
39.73 / 37.63
Country Specific
452.5-457.5 MHz
462.5-467.5 MHz
6.89 / 10.88
x
1.84 / 1.89
7.50 / 8.28
Country Specific
1452-1496 MHz
6.14
x
3.84
38/n38
Europe +
2570-2620 MHz
30.51
2.30
39/n39
Country Specific
1880-1920 MHz
45.97
1.85
40/n40
Asia +
2300-2400 MHz
36.83
1.90
41/n41
Country Specific
2496-2690 MHz
30.16
2.30
42
Country Specific
3400-3600 MHz
26.81
2.27
43
Country Specific
3600-3800 MHz
22.75
2.67
46/n46
Country Specific
5150-5925 MHz
26.24
1.79
48/n48
Country Specific
3550-3700 MHz
24.62
2.38
65/n65
Country Specific
1920-2010 MHz
2110-2200 MHz
51.66 / 46.12
1.92 / 1.62
66/n66
B66
Country Specific
1710-1780 MHz
2110-2200 MHz
38.51 / 46.12
1.83 / 1.62
71/n71
B71
Country Specific
663-698 MHz
617-652 MHz
26.63 / 18.58
4.88 / 5.60
Table data for bands as detailed in 3GPP TS 36.101 & 38.101
Usable Band
Adequate in good signal area
x Not Usable
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
5G Extended Table for Band Coverage
LTE/5G
Band
NB-IoT
Band
n24
Uplink
Downlink
1626.5 – 1660.5 MHz
1525 – 1559 MHz
Max VSWR
over Band
Avg Efficieny %
over band
37.29 / 19.24
1.98 / 3.15
n34
2010 – 2025 MHz
54.08
n47
5855 – 5925 MHz
30.28
n50
1432 – 1517 MHz
6.75
x
3.84
n51
1427 – 1432 MHz
3.51
x
3.54
n53
2483.5 – 2495 MHz
27.07
2.18
n67
738 – 758 MHz
44.16
3.45
n70
B70
n74
1.71
1.30
1695 – 1710 MHz
1995 – 2020 MHz
38.91 / 53.36
1427 – 1470 MHz
1475 – 1518 MHz
4.69 / 8.37
x
3.84 / 3.42
1.86 / 1.90
n75
1432 – 1517 MHz
6.75
x
3.84
n76
1427 – 1432 MHz
3.51
x
3.54
n77
3300 – 4200 MHz
22.56
2.67
n78
3300 – 3800 MHz
25.85
2.67
n79
4400 – 5000 MHz
18.93
2.37
n80
1710 – 1785 MHz
38.17
1.83
n81
880 – 915 MHz
54.19
2.05
n82
832 – 862 MHz
76.05
1.45
n83
703 – 748 MHz
40.53
3.84
1920 – 1980 MHz
50.23
1.88
n84
n85
B85
n86
698 – 716 MHz
728 – 746 MHz
29.82 / 44.16
3.95 / 3.61
1710 – 1780 MHz
38.51
1.83
n89
824 – 849 MHz
79.77
1.27
n90
2496 – 2690 MHz
30.16
2.30
n91
832 – 862 MHz
1427 – 1432 MHz
76.05 / 3.51
x
n92
832 – 862 MHz
1432 – 1517 MHz
76.05 / 6.75
x
1.45 / 3.84
n93
880 – 915 MHz
1427 – 1432 MHz
54.19 / 3.51
x
2.05 / 3.54
n94
880 – 915 MHz
1432 – 1517 MHz
54.19 / 6.75
x
2.05 / 3.84
54.08
1.45 / 3.54
n95
2010 – 2025 MHz
n96
5925 – 7125 MHz
n97
2300 – 2400 MHz
36.83
1.90
n98
1880 – 1920 MHz
45.97
1.85
n99
1626.5 – 1660.5 MHz
37.29
1.98
1.71
not measured
Table data for bands as detailed in 3GPP TS 38.101
Usable Band
x Not Usable
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
Radiation Plots tested with 1.5 m cable
600 MHz XY
XZ
YZ
700 MHz XY
XZ
YZ
800 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
900 MHz XY
XZ
YZ
1500 MHz XY
XZ
YZ
1600 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
1700 MHz XY
XZ
YZ
1800 MHz XY
XZ
YZ
1900 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
2000 MHz XY
XZ
YZ
2100 MHz XY
XZ
YZ
2200 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
2300 MHz XY
XZ
YZ
2400 MHz XY
XZ
YZ
WiFi
Band
2.4
GHz
WiFi
Band
2.4
GHz
Eff %
30.13
Eff %
30.13
2460 MHz XY
XZ
YZ
WiFi
Band
2.4
GHz
WiFi
Band
2.4
GHz
Eff %
39.9
Eff %
39.9
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
2500 MHz XY
XZ
YZ
WiFi
Band
2.4
GHz
WiFi
Band
2.4
GHz
Eff %
27.10
Eff %
27.10
2600 MHz XY
XZ
YZ
2700 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
Radiation Plots tested with 1 m cable
3300 MHz XY
XZ
YZ
3400 MHz XY
XZ
YZ
3500 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
3600 MHz XY
XZ
YZ
3700 MHz XY
XZ
YZ
3800 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
4000 MHz XY
XZ
YZ
4200 MHz XY
XZ
YZ
4400 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
4600 MHz XY
XZ
YZ
4800 MHz XY
XZ
YZ
5000 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
5200 MHz XY
XZ
YZ
5400 MHz XY
XZ
YZ
5600 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
5800 MHz XY
XZ
YZ
6000 MHz XY
XZ
YZ
3D Radiation Plots tested with 1.5 m cable
600 MHz
700 MHz
800 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
900 MHz
Theta 65 Phi 45
1700 MHz
1500 MHz
Theta 65 Phi 45
1800 MHz
1600 MHz
Theta 65 Phi 45
1900 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
2000 MHz
2100 MHz
2200 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
2300 MHz
Theta 65 Phi 45
2500 MHz
2400 MHz
Theta 65 Phi 45
2600 MHz
2460 MHz
Theta 65 Phi 45
2700 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
3300 MHz
3400 MHz
3500 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
3600 MHz
Theta 65 Phi 45
4000 MHz
3700 MHz
Theta 65 Phi 45
4200 MHz
3800 MHz
Theta 65 Phi 45
4400 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
4600 MHz
4800 MHz
5000 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
Alpha 40
5200 MHz
Theta 65 Phi 45
5800 MHz
Theta 65 Phi 45
5400 MHz
Theta 65 Phi 45
5600 MHz
Theta 65 Phi 45
6000 MHz
Theta 65 Phi 45
Ordering Details
Part Number
Description
ALPHA40/1.5M/SMAM/S/S29
2G/3G/4G/5G/DUALBAND WIFI ADHESIVE T-BAR ANTENNA SMA MALE 1.5M CABLE
ALPHA40/2.5M/SMAM/S/S29
2G/3G/4G/5G/DUALBAND WIFI ADHESIVE T-BAR ANTENNA SMA MALE 2.5M CABLE
ALPHA40/5M/SMAM/S/S29
2G/3G/4G/5G/DUALBAND WIFI ADHESIVE T-BAR ANTENNA SMA MALE 5M CABLE
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
ALPHA40/5M/SMAM/S/S/29 价格&库存
很抱歉,暂时无法提供与“ALPHA40/5M/SMAM/S/S/29”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+169.03741
- 10+157.20729
- 50+154.06231
