TANGO46/0.1M/IPEX/S/S/29
    SIRETTA
TANGO46/0.1M/IPEX/S/S/29 数据手册
Tango 46 Mini bolt-through 3G/4G Antenna Key Features • Compact size • 2dBi peak gain • Weather resistant General Description Additional Considerations The Tango 46 mini antenna is for use with 3G/4G signals, achieving its small size by confining its frequency range to 3G and 4G only and with a credible 2dBi peak gain. • Excellent for limited space applications • Use as part of an embedded system The antenna comes with a rubber O ring for use on its stud whilst bolting it to a panel or box helping to achieve a weather resistant seal. Supplied as standard with 100mm of cable and an IPEX connector for simple PCB connection. Alternative cable lengths and connector types may be specified for volume orders. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.2 Tango 46 Mini bolt-through 3G/4G Antenna Electrical Specifications Operating Temperature: Input impedance: Mechanical Specifications -30°C - +60°C 50 Ohm Dimensions: Ø 22 x 22mm Cable: RF1.13 Peak Gain: 2dBi Connector: IPEX VSWR: ≤2.2 Radome Material: ABS Frequency: 1710 - 2170/2500 - 2700MHz Mounting Method: 6.2mm D Screw Max Power: 1W 6mm Beamwidth: H-Plane - 360° E-Plane - 52° Maximum Material Thickness: Polarization: Vertical VSWR Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.2 Tango 46 Mini bolt-through 3G/4G Antenna Return Loss Radiation Patterns E-Plane 1.7 - 2.1GHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 E-Plane 2.5 - 2.7GHz Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.2 Tango 46 Mini bolt-through 3G/4G Antenna H-Plane 1.7 - 2.1GHz H-Plane 2.5 - 2.7GHz Ordering Details Part Number Description TANGO46/0.1M/IPEX/S/S/29 Mini bolt-through 3G/4G Antenna Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.2
TANGO46/0.1M/IPEX/S/S/29 价格&库存
很抱歉,暂时无法提供与“TANGO46/0.1M/IPEX/S/S/29”相匹配的价格&库存,您可以联系我们找货
  • 1+112.13620
  • 5+109.89723
库存:8
