SPECIFICATION
Part No.
WSA.2400.A.101151
Product Name
Phoenix WSA.2400 Bluetooth I-Bar 2.4GHz
Antenna
Features
Wi-Fi/WLAN 2.4GHz Adhesive Mount Antenna
1M RG-174 cable with RP-SMA(M) connector
Ingress Protection Rating IP65
Adhesive Mount
Low Profile for Ease of Installation
Fully Customizable Cable and Connector
105*30*7.7mm
RoHS Compliant
SPE-16-8-076/A
Page 1 of 23
1. Introduction
The Phoenix WSA.2400 I-Bar antenna is a robust and low profile antenna operating
on the 2.4GHz band for Wi-Fi, Bluetooth, and ISM applications.
The Phoenix has a slim-line design, which allows for covert and convenient installation
in any application, while its omnidirectional radiation pattern and 2dBi gain ensure
constant reception and transmission. It is manufactured and tested in a TS16949 first
tier automotive approved facility and has undergone full PPAP design, reliability and
quality audits.
The Phoenix is especially suited for applications such as:
First-tier automotive applications
Telematics
The Phoenix has exceptional industry performance characteristics considering its very
low profile (just 7.7mm) and compact size (105*30mm).
This UV resistant antenna is designed to be mounted on glass or plastic but not on
metal. It comes with strong 3M double-sided adhesive for a permanent and secure fix
to your application.
Cable lengths, types and connectors are fully customizable.
SPE-16-8-076/A
Page 2 of 23
2. Specification
Wi-Fi
Frequency
In free space
On glass
On the 2mm
ABS
In free space
On glass
On the 2mm
ABS
0.3m
1m
2m
3m
5m
0.3m
1m
2m
3m
5m
0.3m
1m
2m
3m
5m
0.3m
1m
2m
3m
5m
0.3m
1m
2m
3m
5m
0.3m
1m
2m
3m
5m
2400~2500MHz
Efficiency (%)
72.38
57.37
40.97
29.31
15.19
73.09
57.94
41.36
29.59
15.34
71.10
56.37
40.24
28.79
14.92
Average Gain(dBi)
-1.40
-2.41
-3.88
-5.33
-8.19
-1.36
-2.37
-3.83
-5.29
-8.14
-1.48
-2.49
-3.95
-5.41
-8.26
SPE-16-8-076/A
Page 3 of 23
Peak Gain(dBi)
In free space
On glass
0.3m
1m
2m
3m
5m
0.3m
1m
2m
3m
5m
2.18
1.18
-0.22
-1.72
-4.52
4.67
3.67
2.17
0.77
-2.13
0.3m
3.21
1m
2.21
2m
0.74
3m
-0.69
5m
-3.56
On the 2mm
ABS
Return loss
VSWR
Impedance
Polarization
Radiation Pattern
Input Power
< -10 dB
≤ 2:1
50Ω
Linear
Omnidirectional
2W
MECHANICAL
Dimensions
105*30*7.7mm
Casing
Connector
Cable
Waterproof
Weight
PC/ABS
RP-SMA(M)
RG-174
IP65
50g
Temperature Range
Humidity
ENVIRONMENTAL
-40°C to 85°C
Non-condensing 65°C 95% RH
SPE-16-8-076/A
Page 4 of 23
3. Antenna Characteristics
3.1 Antenna Test Setup
In free space
On glass
On the 2mm ABS
SPE-16-8-076/A
Page 5 of 23
3.2 Return Loss
3.3 Efficiency
SPE-16-8-076/A
Page 6 of 23
3.4 Peak Gain
3.5 Average Gain
SPE-16-8-076/A
Page 7 of 23
4. Antenna Radiation Patterns
4.1 Antenna Setup
(Antenna testing Setup in ETS Anechoic Chamber)
Y
X
Z
In free space
Y
Y
X
X
Z
On glass
Z
On the 2mm ABS
SPE-16-8-076/A
Page 8 of 23
4.2 2D Radiation Patterns
4.2.1
In free space
XY Plane
XZ Plane
YZ Plane
SPE-16-8-076/A
Page 9 of 23
4.2.2
On glass
XY Plane
XZ Plane
YZ Plane
SPE-16-8-076/A
Page 10 of 23
4.2.3
On the 2mm ABS
XY Plane
XZ Plane
YZ Plane
SPE-16-8-076/A
Page 11 of 23
4.3 Antenna 3D Radiation Pattern
4.3.1
In free space
2400MHz
2450MHz
2500MHz
SPE-16-8-076/A
Page 12 of 23
4.3.2
On glass
2400MHz
2540MHz
2500MHz
SPE-16-8-076/A
Page 13 of 23
4.3.3
On the 2mm ABS
2400MHz
2540MHz
2500MHz
SPE-16-8-076/A
Page 14 of 23
5. Drawing (Unit: mm)
SPE-16-8-076/A
Page 15 of 23
6. Packaging
SPE-16-8-076/A
Page 16 of 23
7. Application Note
Antenna performance versus cable length is shown below.
7.1 Return Loss
In free space
On glass
SPE-16-8-076/A
Page 17 of 23
On the 2mm ABS
7.2
Efficiency
In free space
SPE-16-8-076/A
Page 18 of 23
On glass
On the 2mm ABS
SPE-16-8-076/A
Page 19 of 23
7.3 Peak Gain
In free space
On glass
SPE-16-8-076/A
Page 20 of 23
On the 2mm ABS
7.4 Average Gain
In free space
SPE-16-8-076/A
Page 21 of 23
On glass
On the 2mm ABS
SPE-16-8-076/A
Page 22 of 23
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document
and reserves the right to make changes to specifications and product descriptions at any time without
notice. Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-16-8-076/A
Page 23 of 23
很抱歉,暂时无法提供与“WSA.2400.A.101151”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+93.66900
- 24+91.92789
- 50+86.70458
- 国内价格 香港价格
- 1+192.855091+24.95096
- 10+154.1282410+19.94061
- 30+142.8188630+18.47744
- 100+133.83817100+17.31554
- 250+128.77460250+16.66044
- 500+125.72308500+16.26564
