TANGO3/0.5M/SMAM/S/S/31 数据手册
Tango 3
2G/GPRS & 3G Through Hole Antenna
Key Features
• Compact size
• Tri-band 2G + 3G
• Wide frequency range
General Description
Additional Considerations
The Tango 3 is tuned to tri band 2G/
GPRS & 3G/UMTS frequencies. It is
suited to industrial and automotive
applications for panel mounting to (up
to 4mm thick) and is manufactured
with an O ring seal to prevent moisture
ingress once installed.
• Panel mounted
• Meets all EU compliance criteria for electronic goods
The brass foot has a ridged topside
allowing secure fitting to the enclosure
and a 6mm diameter screw thread for
mounting the antenna.
Supplied as standard with a 3m cable
and either SMA Male or FME Female
connectors. Alternative cable lengths or
connector types may be specified for
volume orders.
Registered in England No. 08405712
VAT Registration No. GB163 04 0349
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
fax
email
web
+44(0)118 976 9014
+44(0)118 976 9020
sales@siretta.com
www.siretta.com
Rev 1.4
Tango 3
Electrical Specifications
Temperature range:
Operating
Frequencies:
Mechanical Specifcations
-40 to 85°C
869-960/1710-1990MHz
Impedance:
50 Ohm
Gain:
2.5dBi
VSWR:
Dimensions:
L76 x W29 x 10mm Ø
Cable:
RG58
Connector:
SMA Male
Mounting method:
Through hole
TANGO3/0.5M/SMAM/S/S/31 价格&库存
很抱歉,暂时无法提供与“TANGO3/0.5M/SMAM/S/S/31”相匹配的价格&库存,您可以联系我们找货
