TANGO27/2.5M/SMAM/S/S/17 数据手册
Tango 27
Quad Band 2G (GPRS)/3G/4G Puck Antenna
Key Features
• Quad band 2G/GPRS and 3G
• Small puck design
• Ground plane independent
General Description
Additional Considerations
The Tango 27 antenna is a compact,
versatile, weather resistant, quad
band 2G/GPRS and 3G antenna with
a 2dBi peak gain and some 4G band
coverage.
• Housed in a robust ABS, weather resistant casing
The Tango 27 is ideal for use on high
sided vehicles or for external use with
IoT devices in unmanned locations.
• Does not require placement on a metallic surface
• Meets all EU compliance criteria for electronic goods
• Best for cellular signal coverage in the following bands
2G Band 9 (E-GSM-900)
3G Band 8 (E-GSM-900)
4G Band 20 (800)
It is supplied with a 2.5M cable and
SMA male connector. Custom cable
lengths and connector types can be
specified for volume orders.
Registered in England No. 08405712
VAT Registration No. GB163 04 0349
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
fax
email
web
+44(0)118 976 9014
+44(0)118 976 9020
sales@siretta.com
www.siretta.com
Rev 1.5
Tango 27
Electrical Specifications
Mechanical Specifications
Operating
Temperature:
-30 - +75°C
Storage Temperature:
-30 - +75°C
50 Ohm
Peak Gain:
2.16dBi
VSWR:
≤ 2.1
Max Input Power:
35W
Operating Frequencies:
VSWR
46 Ø x H15mm
Connector:
Impedance:
Polarization:
Dimensions:
Vertical
SMA Male
Cable:
RG174
Housing material:
ABS
Mounting Method:
M12 Screw
Base:
Adhesive
Maximum Material
Thickness:
8mm
2G: 850, 900, 1800, 1900MHz
3G: 2100MHz
4G - 800MHz
Return Loss
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
fax
email
web
+44(0)118 976 9014
+44(0)118 976 9020
sales@siretta.com
www.siretta.com
Rev 1.5
Tango 27
Ordering Details
Part number
Description
Quad Band 2G GSM/GPRS 3G and 4G Puck Antenna
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
fax
email
web
+44(0)118 976 9014
+44(0)118 976 9020
sales@siretta.com
www.siretta.com
Rev 1.5
TANGO27/2.5M/SMAM/S/S/17 价格&库存
很抱歉,暂时无法提供与“TANGO27/2.5M/SMAM/S/S/17”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+279.099421+36.28203
- 国内价格
- 1+201.93472
- 5+197.89415
