DRAFT SPECIFICATION
PATENT PENDING
Part No.
MA950.A.LBICG.005
Product Name
MA950 Guardian 5in1 Adhesive Mount Antenna
LTE*2+Wi-Fi*2+GNSS
Features
Low-profile Housing – Mounts flush to Wall
2* LTE MIMO 698-960MHz/1710-2170MHz/ 24902690MHz/ 3300-3600MHz
2* Wi-Fi MIMO 2.4GHz/5.8GHz
1* GPS-GLONASS-BeiDou Antenna
Worldwide 4G Bands including 3G and 2G
IP67 Waterproof Resistant Enclosure
Dims: 146*134*20mm
1M Low Loss KSR200-P and RG174 with SMA(M)/RPSMA(M) connectors
Cables and Connectors Customizable
RoHS Compliant
DSP-16-8-068/A
Page 1 of 185
1. Introduction
The MA950 Guardian is a next generation combination antenna. The first panel antenna
worldwide designed for IoT Gateway and Router devices. It is a low profile 5in1 wall
and adhesive mount antenna. It is a heavy-duty, fully IP67 waterproof resistant
external M2M antenna for use by RF professionals in
- IoT Gateway and Routers
- HD Video Streaming
- Transportation
- Remote Monitoring Applications
This antenna delivers powerful MIMO antenna technology for worldwide 4G LTE bands
at
698-960MHz
/1710-2170MHz
/2490-2690MHz
/3300-3600MHz
bands,
dual
2.4/5.8GHz Wi-Fi, plus GPS-GLONASS-BeiDou for location accuracy. It enables
designers to install only one antenna to cover all of these technologies.
4G wireless applications demand high speed data uplink and downlink. High efficiency
and high gain MIMO antennas are necessary to achieve the required signal to noise
ratio and throughput required to solve these challenges. Taoglas also takes care to
have high isolation among these antennas to prevent self-interference. Low loss cables
used to keep efficiency high over long cable lengths.
The GPS-GLONASS-BeiDou active antenna has been carefully designed for excellent
performance across all GNSS bands, leading to higher location accuracy and stability
of tracking in urban environments.
The housing dimension is 146*134*20mm. It is IP67 waterproof and comes with 3M
foam adhesive. The antenna can be mounted internally or externally on a vehicle. The
MA950 comes with 1 meter, low loss KSR-200P coaxial cables for the LTE and Wi-Fi
antennas, and RG174 coaxial cable for the GNSS antenna as standard. Customized
cables and connector versions are also available
DSP-16-8-068/A
Page 2 of 185
2. Specification
BeiDou-GPS-GLONASS
BeiDou:1561.098±2.046MHz
GPS:1575.42±1.023MHz
GLONASS:1602±5MHz
BeiDou: 63%
GPS: 48%
GLONASS: 57%
BeiDou: -1.97dBi
GPS: -3.13dBi
GLONASS: -2.39dBi
BeiDou: 3dBi
GPS: 1.98dBi
GLONASS: 3.01dBi
3:1 Max
Center Frequency
Passive Antenna
Efficiency(without cable loss)
Passive Antenna Average
Gain(without cable loss)
Passive Antenna Peak
VSWR
Impedance
Polarization
50Ω
BeiDou:
很抱歉,暂时无法提供与“MA950.A.LBICG.005”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1679.855901+218.34031
- 10+1429.6932310+185.82526
- 25+1367.2435125+177.70832
