MA961.A.BICG.002
MA961.A.BICG.002
    TAOGLASLIMITED
    MA961.A.BICG.002
MA961.A.BICG.002 数据手册
Specification PATENT PENDING Part No. : MA961.A.BICG.002. Product Name : Guardian 4in1 Adhesive Mount Antenna 2*LTE MIMO and 2*Wi-Fi MIMO Features : Low-profile Housing 2* LTE MIMO 698-960MHz / 1710-2170MHz / 2490-2690MHz / 3300-3600MHz 2* Dual Band Wi-Fi MIMO 2400MHz to 2500MHz / 4900MHz to 5850MHz Worldwide 4G Bands including fallback to 3G and 2G IP67 Waterproof Enclosure Dims: 146*134*20mm Cables: 3M Low Loss KSR200-P and RG174 Connectors: SMA(M)/RP-SMA(M) Cables and Connectors Customizable RoHS Compliant SPE-17-8-048/B Page 1 of 37 1. Introduction The MA961 Guardian is a next generation combination antenna. The first panel antenna worldwide designed for IoT Gateway and Router devices. It is a low profile 4in1 wall mount antenna. This unique product delivers powerful worldwide 4G LTE MIMO antenna technology at 700MHz/800MHz/1700MHz/1800MHz/ 2600MHz/3500MHz and dual band Wi-Fi. It is a heavy-duty, fully IP67 waterproof external M2M antenna for use by RF professionals in IoT Gateway and Routers, HD Video Streaming, Transportation and Remote Monitoring Applications. This antenna delivers powerful MIMO antenna technology for worldwide 4G LTE bands at 698-960MHz/1710-2170MHz/2490-2690MHz/3300-3600MHz bands and dual 2.4/5.8GHz Wi-Fi. It enables designers to cover a wide range of technologies by installing a single antenna. 4G wireless applications demand high speed data uplink and downlink. High efficiency and high gain MIMO antennas are necessary to achieve the required signal to noise ratio and throughput required to solve these challenges. Taoglas also takes care to have high isolation among these antennas to prevent self-interference. Low loss cables used to keep efficiency high over long cable lengths. The housing is made of durable ASA, is IP67 waterproof and comes with 3M foam adhesive. The antenna can be mounted internally or externally on a vehicle or building. The MA961 comes with 3 meters CFD-200 cable as standard. Customized cables and connector versions are also available. SPE-17-8-048/B Page 2 of 37 2. Specification 4G/3G/2G MIMO1 Antenna Frequency (MHz) In free space 30cm 1M 2M 3M 5M In free space 30cm 1M 2M 3M 5M LTE700 GSM850 GSM900 DCS PCS UMTS1 LTE2600 LTE3500 698~803 824~894 880~960 1710~1880 1850~1990 1920~2170 2490~2690 3300~3600 Efficiency (%) 80.59 64.37 61.48 67.87 72.91 76.16 47.65 55.23 76.15 61.48 58.71 61.90 66.50 70.02 43.45 49.00 71.06 56.46 53.55 55.17 58.52 61.35 37.52 41.47 65.87 52.33 49.65 49.03 51.74 54.25 32.54 35.03 56.97 44.54 41.98 38.65 40.59 42.27 24.39 25.12 Average Gain (dB) -0.95 -1.92 -2.11 -1.69 -1.37 -1.19 -3.42 -2.64 -1.19 -1.49 -1.82 -2.45 -2.12 -2.49 -2.82 -3.52 -2.31 -2.71 -3.04 -3.77 -2.09 -2.59 -3.10 -4.13 -1.77 -2.33 -2.86 -3.92 -1.55 -2.13 -2.66 -3.75 -3.82 -4.45 -5.08 -6.33 -3.17 -3.89 -4.62 -6.07 4.23 3.83 3.33 2.73 1.73 4.70 4.30 3.80 3.20 2.10 4.11 3.71 3.11 2.51 1.31 3.36 3.36 2.66 1.86 0.46 72.20 65.84 57.94 51.23 40.18 76.03 69.92 61.24 54.16 42.20 57.82 52.74 45.51 39.45 29.58 64.24 56.94 48.21 40.77 29.22 -1.42 -1.82 -2.37 -2.91 -3.96 -1.20 -1.56 -2.14 -2.67 -3.76 -2.47 -2.87 -3.50 -4.13 -5.38 -1.93 -2.46 -3.18 -3.91 -5.36 4.67 4.56 3.95 4.27 4.19 3.55 3.77 3.66 2.95 3.17 3.06 2.35 2.17 2.06 1.15 50Ω Linear
MA961.A.BICG.002 价格&库存
很抱歉,暂时无法提供与“MA961.A.BICG.002”相匹配的价格&库存,您可以联系我们找货
MA961.A.BICG.002
    • 50+926.43678
    库存:1
    MA961.A.BICG.002
    • 1+1486.94892
    • 3+1338.25403
    库存:1
