MA931.A.LBICGH.001
MA931.A.LBICGH.001
    TAOGLASLIMITED
    MA931.A.LBICGH.001
MA931.A.LBICGH.001 数据手册
DRAFT SPECIFICATION PATENT PENDING Part No. : MA931.A.LBICGH.001 Product Name : MA931 Guardian 6in1 Adhesive Mount Antenna LTE*2+Wi-Fi*3+GNSS Features : Low-profile Housing – Mounts flush to Wall 2* LTE MIMO 698-960MHz/1710-2170MHz/ 24902690MHz/ 3300-3600MHz 3* Wi-Fi MIMO 2.4GHz/5.8GHz 1* GPS-GLONASS-BeiDou Antenna Worldwide 4G Bands including 3G and 2G IP67 Waterproof Resistant Enclosure Dims: 146*134*20mm 1M Low Loss KSR200-P and RG174 with SMA(M)/RPSMA(M) connectors Cables and Connectors Customizable RoHS Compliant DSP-16-8-069/A Page 1 of 185 1. Introduction The MA931 Guardian is a next generation combination antenna. The first panel antenna worldwide designed for IoT Gateway and Router devices. It is a low profile 6in1 wall and adhesive mount antenna. It is a heavy-duty, fully IP67 waterproof resistant external M2M antenna for use by RF professionals in - IoT Gateway and Routers - HD Video Streaming - Transportation - Remote Monitoring Applications This antenna delivers powerful MIMO antenna technology for worldwide 4G LTE bands at 698-960MHz /1710-2170MHz /2490-2690MHz /3300-3600MHz, dual-band 2.4/5.8GHz Wi-Fi, plus GPS-GLONASS-BeiDou for location accuracy. It enables designers to install only one antenna to cover all of these technologies. 4G wireless applications demand high speed data uplink and downlink. High efficiency and high gain MIMO antennas are necessary to achieve the required signal to noise ratio and throughput required to solve these challenges. Taoglas also takes care to have high isolation among these antennas to prevent self-interference. Low loss cables used to keep efficiency high over long cable lengths. The GPS-GLONASS-BeiDou active antenna has been carefully designed for excellent performance across all GNSS bands, leading to higher location accuracy and stability of tracking in urban environments. The housing dimension is 146*134*20mm. It is IP67 waterproof and comes with a 3M foam adhesive. The antenna can be mounted internally or externally on a vehicle. The MA931 comes with 1 meter, low loss KSR-200P coaxial cables for the LTE and Wi-Fi antennas, and RG174 coaxial cable for the GNSS antenna as standard. Customized cables and connector versions are also available. DSP-16-8-069/A Page 2 of 185 Specification BeiDou-GPS-GLONASS BeiDou:1561.098±2.046MHz GPS:1575.42±1.023MHz GLONASS:1602±5MHz BeiDou: 63% GPS: 48% GLONASS: 57% BeiDou: -1.97dBi GPS: -3.13dBi GLONASS: -2.39dBi BeiDou: 3dBi GPS: 1.98dBi GLONASS: 3.01dBi 3:1 Max Center Frequency Passive Antenna Efficiency(without cable loss) Passive Antenna Average Gain(without cable loss) Passive Antenna Peak Gain(without cable loss) VSWR Impedance Polarization 50Ω BeiDou:
MA931.A.LBICGH.001 价格&库存
很抱歉,暂时无法提供与“MA931.A.LBICGH.001”相匹配的价格&库存,您可以联系我们找货
