M310220
M310220
    ETHERTRONICS
    RFANTBLUETOOTHWIFI2.4GHZ
M310220 数据手册
DATASHEET Part No. M310220 Product: 2.4 GHz Ceramic Antennas Part No. M310220 WiFI / ISM / BT / Zigbee SavviTM Ceramic Antennas 2.4 GHz Ethertronics’ Savvi series of Isolated Magnetic Dipole™ (IMD) antennas deliver on the key needs of device designers for higher functionality and performance in smaller/thinner designs. These innovative antennas provide compelling advantages for Bluetooth® enabled cell phones, media players and other mobile devices. Real-World Performance and Implementation Ceramic antennas may look alike on the outside, but the important difference is inside. Other antennas may contain simple PiFA or monopole designs that interact with their surroundings, complicating layout or changing performance with use position. Ethertronics’ antennas utilize patented IMD technology to deliver a unique size and performance combination. SavviTM Ceramic Antennas WiFI, Bluetooth, Zigbee 2.4 GHz Greater Flexibility Ethertronics’ first-in-class IMD technology enables you to develop concept designs that are more advanced and that deliver superior performance in reception critical applications. KEY BENEFITS Electrical Specifications Typical Characteristics, inside an enclosure Stay-in-Tune IMD antenna technology provides superior RF field containment, resulting in less interaction with surrounding components. Quicker Time-to-Market By optimizing antenna size, performance and emissions, customer and regulatory specifications are more easily met. Reliability Products are the latest RoHS version compliant. 2.400 – 2.480 GHz Peak Gain -1.3 dBi Average Efficiency 75% VSWR Match 1.2:1 max Feed Point Impedance 50 ohms unbalanced Polarization Linear Power Handling 0.5 Watt CW Mechanical Specifications Size 3.00x1.50x1.08mm Mounting APPLICATIONS • • • • • Embedded design Cellular, Headsets, Tablets Gateway, Access Point M2M, Industrial devices Handheld 5/30/2017 Surface mount Weight Packaging 0.1 g Tape & Reel, M310220 – 1,000 pieces per reel M310220-10K – 10,000 pieces per reel Demo Board Proprietary and confidential. M310220-01 www.ethertronics.com DATASHEET | Part No. M310220 2.4GHz Ethertronics’ SavviTM Embedded Antenna Specifications Ethertronics produces a wide variety of standard and custom antennas to meet user needs. Below are the typical performances. Typical Return Loss and Efficiency Plots Measured on 40 x 60 mm demo board Antenna Radiation Patterns Typical Performances on Ethertronics’ 40 x 60 mm PCB Test Board Measured at 2.440 GHz Antenna Layout Tuning values for references only M310220 *All dimensions provided in this document are for informational purposes only. © 2017 Ethertronics Incorporated. tel +(1) 858.550.3820 | fax +(1) 858.550.3821 email: info@ethertronics.com 5501 Oberlin Drive, Suite 100 San Diego, CA 92121 - USA
M310220 价格&库存
很抱歉,暂时无法提供与“M310220”相匹配的价格&库存,您可以联系我们找货
