B5812-04
B5812-04
    ANTENOVA(安诺亚)
    B5812-04
B5812-04 数据手册
Flavus GSM Snap-In Antenna Product Specification 1 Features • Designed for GSM applications [800/900/1800/1900 MHz] • Intended for Snap-In mounting • Supplied in trays 2 Description The Flavus antenna is intended for use with all GSM applications. The antenna is a quarterwave type. The antenna uses plastic snap ins to attach to the PCB, no need for soldering. 3 Application • GSM modules • Cell phones • Vehicle tracking Integrated Antenna Solutions  Product Specification AE030090-A Flavus GSM Snap-In Antenna Contents 1 Features 1 2 Description 1 3 Application 1 4 Model name 3 5 General data 3 6 Electrical characteristics 3 7 Electrical performance 4 7.1 Voltage Standing Wave Ratio 4 7.2 Radiation patterns 4 8 Antenna Dimensions 5 9 Antenna Footprint 5 10 Electrical interface 6 10.1 Transmission line and matching 6 10.2 Test board dimensions 6 10.3 Test board matching 7 7 11 Reliability 11.1 Temperature and Humidity 7 11.2 Mechanical 7 11.3 Miscellaneous 8 11.4 Judgement standard 8 12 Hazardous Material Regulation Conformance 8 13 Application example 9 14 Packaging 10 14.1 Shelf storage recommendation 10 14.2 Packaging characteristics 10 14.3 Tray dimension 10 14.4 Box dimension 10 14.5 Label information 10 Integrated Antenna Solutions  Product Specification AE030090-A Flavus GSM Snap-In Antenna 4 Model name 10 20 B5812 - XX PCB Thickness 01 = 0.8 mm 02 = 1.0 mm 03 = 1.2 mm 04 = 1.6 mm 05 = 1.8 mm Drawing No. Technology -Plastic Carrier Antenna Family -Snap-In 5 General data Product Name Flavus GSM Article No. 1020B5812-01..05 Frequency 880-960 MHz, 1710-1990 MHz Polarization Linear Operating temperature -40 to + 85 degC Impedance 50 Ohm Weight 0.6 gram Antenna type Snap-in 6 Electrical characteristics Characteristics Conditions* GSM DCS PCS Efficiency > 65% > 68 % > 77% Measured in 3D chamber ( near field) VSWR < 1:2.3 < 1:2.7 < 1:1.9 Measured in Network Analyzer *Note all data provided in this table are based on the Antenova reference board Integrated Antenna Solutions  Product Specification AE030090-A Flavus GSM Snap-In Antenna 7 Electrical performance 7.1 Voltage Standing Wave Ratio VSWR * HP9770 Network Analyzer 3:1 : : 700 1500 2300 MHz 7.2 Radiation patterns YZ- Plane XZ- Plane 880(MHz) 920(MHz) 960(MHz) GSM 880(MHz) 920(MHz) 960(MHz) 90deg 5.00 0.00dB 0.00 -5.00dB -5.00 -10.00dB -10.00 -15.00dB -15.00 -20.00dB 180deg 0deg -20.00 180deg 0deg 270deg 270deg 1710(MHz) 1795(MHz) 1850(MHz) 1880(MHz) 1920(MHz) 1990(MHz) 90deg 5.00dB 1710(MHz) 1795(MHz) 1850(MHz) 1880(MHz) 1920(MHz) 1990(MHz) Theta 90deg 5.00dB Theta 90deg 5.00dB 0.00dB 0.00dB -5.00dB -5.00dB -10.00dB -15.00dB -10.00dB -20.00dB -15.00dB -25.00dB -20.00dB -30.00dB DCS/PCS -35.00dB 180deg 270deg Theta 0deg -25.00dB 180deg 0deg 270deg Theta Integrated Antenna Solutions  Product Specification AE030090-A Flavus GSM Snap-In Antenna 8 Antenna Dimensions L W W1 W2 H H1 F1 F2 T1 Length Width Width Width Height Height Feed Feed PCB 27.3 ±0.2 7.9 ±0.2 9.6±0.2 8.5±0.2 3.45±0.1 3.85±0.1 11.85±0.2 2.8±0.1 T1±0.05 T2 T3 1.35±0.2 1.3±0.1 Dimensions in millimeters 9 Antenna Footprint F1 F2 F3 F4 Feed Feed Feed Feed 11.85±0.1 2.8±0.1 2±0.05 2.25±0.05 S1 P1 P2 P3 P4 D1 D2 Snap-In Position Position Position Position Diameter Diameter 5.6±0.1 4.5±0.1 11.5±0.1 0.3±0.1 5.9±0.1 3.05±0.1 1.75±0.1 T* PCB 0.8, 1.0, 1.2, 1.6, 1.8 Dimensions in millimeters Integrated Antenna Solutions  Product Specification AE030090-A Flavus GSM Snap-In Antenna 10 Electrical interface 10.1 Transmission line and matching The matching network has to be individually designed using one, two or three components. Copper area Soldering pads Transparent area Matching components t C W t, w = Unique dimensioning according to your PCB * C = Inductor and capacitor values according to your specific device* * Antenova provides this service upon request 10.2 Test board dimensions The testboard is designed for evaluation purposes for Flavus GSM antenna. The card has the same size as a typical PCMCIA card and is fitted with an SMA connector. Integrated Antenna Solutions  Product Specification AE030090-A Flavus GSM Snap-In Antenna 10.3 Test board matching Series Inductor 2.2 nH Shunt inductor 10 nH The testboard is matched with above specified component. Note! The component value(s) will vary depending on size of PCB, surrounding components etc. 11 Reliability 11.1 Temperature and Humidity Item Standard Low High Duration Operating temperature EN/IEC 60068-2-2, Test Bd: Dry heat -30 degC +90 degC - Temperature cycling EN/IEC 60068-2-14, Test Na: Change of temperature -30 degC +90 degC 100cycles / 10min Storage life Humidity EN/IEC 60068-2-1, Test Ca: Damp heat Storage life Low temperature EN/IEC 60068-2-1, Test Ad: Cold -25 degC - 200 h Storage life High temperature EN/IEC 60068-2-2, Test Bb: Dry heat - + 90 degC 1000 h +40 degC / 93% RH 96 h 11.2 Mechanical Item Standard Specification Duration Contact force Antenna is mounted on reference board. and a pressure gauge is applied to antenna contact. Drop test Dummy weight: 150g Height: 170cm One drop at each side, total drops: 6 Acceleration spectral density:10-1000Hz Acceleration: 20m/s2 Number of axes: 3 mutually perpendicular 5 cycles per axis Vibration EN/IEC 60068-2-6, Test Fc (sinusoidal) Integrated Antenna Solutions  Product Specification AE030090-A Flavus GSM Snap-In Antenna 11.3 Miscellaneous Item Contact pad Corrosion Standard ASTM B117 Specification SO2 Concentration: 25 ppm Temperature : 25 Deg C RH: 93% Duration 96 hours 11.4 Judgement standard The judgement of the above tests should be made as follows: 1. Visual inspection - Normal appearance with no obvious deformation 2. Electrical inspection - The antenna satisfies the VSWR specification throughout the GSM band 3. Mechanical inspection - Acceptable contact force min. 0.5 N 12 Hazardous Material Regulation Conformance Cadmium and cadmium compound. Lead and lead compound Organic brominated compound (PBB, PBDE) Mercury and mercury compound Polychlorinated biphenyl (PCB) Sexivalent chrome compound Polychlorinated naphthalene (PCN) Chlorinated paraffin (CP) Organic tin compound Mirex Asbestos Formaldehyde Azo compound Tetra-bromo-bisphenol-A-bis (TBBP-A-bis) Integrated Antenna Solutions  Product Specification AE030090-A Flavus GSM Snap-In Antenna 13 Application example 8 Fig. 1 1. Placement of antenna The antenna shall preferably be placed at the edge of the PCB oriented as above. Other placements and orientations and size of groundplanes are possible, but will affect the performance. Avoid active components near the antenna. 2. Placement of GSM module or radio To avoid losses the module shall be placed as close to the antenna as possible. 3. Strip line The strip line must be dimensioned according to your specific PCB. ( see Fig 1). No crossing strip lines are allowed between the strip line and its ground plane. 4. Via connections To avoid spurious effects, via connections must be made to analogue ground. 5. Component matching Component values are depending on antenna placement, PCB dimensions and location of other components. 6. DC Block Might be needed depending on RF Module configuration. 7. Clearance area Avoid components and parts close to the antenna. 8. Alternate positioning The Flavus GSM antenna can placed horisontally to the groundplane, but this position is less favourable then the recommended vertical placement, and will cause a decrease in performance. Note ! Incorrect implementation of the antenna will affect the performance. Contact Antenova for implementation services. Integrated Antenna Solutions  Product Specification AE030090-A Flavus GSM Snap-In Antenna 14 Packaging 14.1 Shelf storage recommendation Temperature -10 to +40 degree C Humidity Less than 75% RH Shelf Life 12 Months Storage place Away from corrosive gas and direct sunlight 14.2 Packaging characteristics Quantity Number of trays Tray quantity 840 pcs / box 6 / box 140 pcs 14.3 Tray dimension Material: Anti static plastic tray Width [mm] W: 290 W Breadth [mm] B: 390 Height [mm] B H: 14 H 14.4 Box dimension Material:  Paper Width [mm] W: 296 Breadth [mm] B: 396 Height [mm] H: 75 antenova ® Antenova 14.5 Label information antenova ® Antenova Integrated Antenna Solutions 10 Product Specification AE030090-A www.antenova.com Corporate Headquarters Asia Headquarters Antenova Ltd. Far Field House Albert Road Stow-cum-Quy Cambridge CB9 5AR Antenova Asia Ltd. 3F, No 10, Alley 6, Lane 45 Poa Shing Road Hsin Tien City Taipe County ROC 23145 Tel: +44 (0) 1223 810600 Fax: +44 (0) 1223 810650 Email: info@antenova.com Tel: +886 (0) 2 2917 6536 Fax: +886 (0) 2 2910 6546 Email: info@antenova.com Sales Offices Europe Charlotta Olander UK/EU Sales Manager America David Nuti NA Sales Manager Tel: +46 702 913731 Tel: +1 214 668 0357 Email: Lotta.Olander@antenova.com Email: David.Nuti@antenova.com Asia CL Lim VP Sales Asia Tel: +886 (0) 931 201 318 Email: CL.Lim@antenova.com Integrated Antenna Solutions 11 Product Specification AE030090-A
B5812-04 价格&库存
很抱歉,暂时无法提供与“B5812-04”相匹配的价格&库存,您可以联系我们找货
