11
5
Lc
16.4
ASSY COAX CABLE
2X
4.78
MAP24057
THIS VIEW SHOWS TYPE"A"
CONNECTOR ORIENTATION
49.5
CONNECTOR
1.52
A
B
STRAIN RELIEF
(WITH INTERNAL ADHESIVE)
(OPTIONAL)
TYPE OF CONNECTOR
ORIENTATION
(REFER TABLE.1)
HEAT SHRINK TUBE Ø4X12
MAR70008
C
6.0 +0/-3.0
HEAT SHRINK TUBE Ø2X12
MAR70006
R
ANTENNA SBU
PENANG, MALAYSIA
D
Lf
CONNECTOR TYPE:
6.00±0.30
3.00±0.30
2.00±0.30
I-PEX
TOLERANCE
(UNLESS STATED)
MMCX/RPMMCX
X
XX
ANGULAR =
STRAIGHT SMA
#0.3
#0.13
# 30'
- PRODUCT & PROCESS MUST COMPLY TO LT-GES
- MISSING INFORMATION REFER TO 3D DATA
- DIMENSIONS ARE IN MILLIMETERS UNLESS STATED
OTHERWISE
- THIS DRAWING WAS GENERATED VIA PRO/ENGINEER
- PRINT NOT TO SCALE
FPEN001.015B
SYM
FERRITE BEAD
(OPTIONAL)
3.0 +0/-3.0
NOTES:
1. MATERIAL: SINGLE SIDED 0.06" NELCO NX 9260 Ioz/ft^2 CU
2. FINISH: PURE TIN PLATING WITH SOLDER MASK
3. SOLDER MASK: BLACK ALL OVER EXCEPT FOR
EXPOSED SOLDER PADS (DOUBLE SIDED)
4. POLARIZATION: VERTICAL, OMNIDIRECTIONAL
5. NOMINAL IMPEDENCE: 50 ohm
6. V.S.W.R. 2:1 MAX ACROSS ALL BANDS
FREQUENCY RANGE
2.4-2.5 GHz
4.9-5.825 GHz
CABLE STRIPPING
DIMENSION FOR FLYING LEAD
ECO/DESCRIPTION
DATE
CK
DRAWN BY:
AL CHAN
APP
R
(F16)
ECN-IAS-04028
5MAY15
LCTAN
CHFONG
ANTENNA SBU
PENANG, MALAYSIA
(F17)
ECN-IAS-04477
12AUG15
LCT
CHF
(F18)
ECN-IAS-04595
9SEP15
LCT
CHF
(F14)
ECN-IAS-03758
04MAR15
KHOO
FONG
(F15)
ECN-IAS-03848
24MAR15
KHOO
FONG
CONFIDENTIAL
THE INFORMATION CONTAINED IN THIS DOCUMENT IS OF
PROPRIETARY NATURE. IT MAY NOT BE REPRODUCED OR USED
WITHOUT EXPRESS WRITTEN PERMISSION OF
LAIRD TECHNOLOGIES, ANTENNA SBU
CHECKED BY:
GJ CHIN
DWG. NO.:
MAF94355
2007
LAIRD TECHNOLOGIES
PROJECT NO. REFER TABLE
REV
F18
MATERIAL:
SEE NOTE
DESCRIPTION:
NANOBLADE ANTENNA MASTER PRINT
C
PG.
1/8
DATE: 10/09/07
SCALE: 2.000
UNITS: MM
TABLE
TOLERANCE
(UNLESS STATED)
X
XX
ANGULAR =
#0.3
#0.13
# 30'
OTHERWISE
SYM
ECO/DESCRIPTION
DATE
CK
DRAWN BY:
AL CHAN
APP
R
ANTENNA SBU
PENANG, MALAYSIA
CONFIDENTIAL
DWG. NO.:
MAF94355
2007
LAIRD TECHNOLOGIES
PROJECT NO.:REFER TABLE
PG.
2/8
REV
F18
MATERIAL:
SEE NOTE
DESCRIPTION:
C
FPEN001.015B
CHECKED BY:
GJ CHIN
DATE: 10/09/07
SCALE: 2.000
UNITS: MM
很抱歉,暂时无法提供与“MAF94153”相匹配的价格&库存,您可以联系我们找货
