SRF2W012-150
SRF2W012-150
    ANTENOVA(安诺亚)
    Dromus 是一款灵活的双频Wi-Fi天线,适用于2.4/5GHz频段,具有高集成度和高性能。
SRF2W012-150 数据手册
Dromus Dual-band Wi-Fi Antenna Part No. SRF2W012 1. flexiiANT ® Product Specification Features        2. Antenna for 2.4 – 2.5 GHz and 4.9 – 5.9 GHz applications: Wi-Fi ® 802.11a/b/g/j/n/ac Maintains high performance within device: DFI (Designed For Integration) 1.13mm diameter RF cable with IPEX MHF connector Self-Adhesive mounted Quick integration minimizes design cycle High performance Available 3 standard cable lengths Description Dromus is intended for use with all Wi-Fi applications. A flexible antenna with cable enables direct connection to the host PCB. Simple integration with plug and play simplicity. This product specification shows the performance of the antenna to cover a typical dual band Wi-Fi reception: 2.4-2.5/ 4.9-5.9GHz. 3. Applications         Access Points Portable Devices PC-cards Game Consoles Set-Top-Box Network Devices Wearable devices MIMO Systems Antennas for Wireless M2M Applications Product Specification Page 1 Dromus Part No. SRF2W012 4. Part Number Dromus: SRF2W012-xxx Note. -xxx refers to cable length option: 5. Part Number SRF2W012-50 Cable Length 50mm SRF2W012-100 100mm SRF2W012-150 150mm General Data Product name Dromus Part Number SRF2W012 Frequency 2.4-2.5GHz;4.9-6.0GHz Polarization Linear Operating temperature -40°C to +85°C Impedance with matching 50 Ω Weight < 0.5 g FPC Self-adhesive 3M 468MP Antenna Assembly type Dimensions (Antenna) 30.0 x 6.0 x 0.15 (mm) Cable length 50 /100 / 150 Connection MHF IPEX 6. RF Characteristics 2.4 – 2.5 GHz 4.9 – 5.9 GHz Peak gain 3.0dBi 4.0dBi Average gain -1.5dBi -1.8dBi Average efficiency >60% >60% Maximum return loss -14dB -10dB Maximum VSWR 1.5:1 1.8:1 Conditions All data measured in a loaded condition adhered to a plastic carrier free space. Antennas for Wireless M2M Applications Product Specification Page 2 Dromus Part No. SRF2W012 7. RF Performance 7.1 Return Loss 5 [dB ] Atyune 0 -5 -1 0 2 -1 5 3 1 -2 0 -2 5 -3 0 [M H z] -3 5 2300 2500 2700 2900 3100 3300 3500 3700 3900 4100 4300 4500 4700 4900 5100 5300 5500 5700 5900 M A RK E RS : MHz dB MHz dB WL A N .S 1 P - S 1 1 1: 2401 2: 2495 - 1 8 .6 9 - 1 5 .5 1 3: 4900 4: 5900 - 1 8 .3 8 - 4 0 .0 8 7.2 VSWR 10 [] Atyune 9 8 7 6 5 4 3 2 1 2 3 4 [M H z] 1 2300 2500 2700 2900 3100 3300 3500 3700 3900 4100 4300 4500 4700 4900 5100 5300 5500 5700 5900 M A RK E RS : MHz MHz WL A N .S 1 P - S 1 1 1: 2401 2: 2495 1 .2 6 1 .4 0 3: 4900 4: 5900 1 .2 7 1 .0 2 Antennas for Wireless M2M Applications Product Specification Page 3 Dromus Part No. SRF2W012 7.3 Antenna patterns 7.3.1 2400 MHz – 2500 MHz 3D pattern at 2.45GHz Drag to rotate pattern and PCB by using Adobe Reader (Click to Activate) Antennas for Wireless M2M Applications Product Specification Page 4 Dromus Part No. SRF2W012 7.3.2 4900 MHz – 5900 MHz 3D pattern at 5.45GHz Drag to rotate pattern and PCB by using Adobe Reader (Click to Activate) Antennas for Wireless M2M Applications Product Specification Page 5 Dromus Part No. SRF2W012 8. Antenna Dimensions 8.1 Dimensions FPC section L 2.0 1.5 W 2 Holes = 1mm ø (diameter) 1.0 1.5 L W T Length Width Thickness 30.0 ±0.2 (mm) 6.0 ±0.2 (mm) 0.15 (mm) nominal All dimensions in mm 8.2 Dimensions assembled L SRF2W012-50 SRF2W012-100 SRF2W012-150 L L L 51 ±2.0 (mm) 101 ±2.0 (mm) 151 ±2.0 (mm) Antennas for Wireless M2M Applications Product Specification Page 6 Dromus Part No. SRF2W012 8.3 IPEX Connector I-PEX Front Material Copper Alloy Plating Ag Side Back 5.0 3.0 All dimensions in mm 8.4 Assembly 1.13mm ø Cable I-PEX Connector FPC Antennas for Wireless M2M Applications Product Specification Page 7 Dromus Part No. SRF2W012 9. Electrical Interface 9.1 Host Interface The host PCB requires the mating connector which is IPEX MHF (UFL) receptacle. The location should be close to the chip/modules pin for the RF. Any feed from this receptacle should be maintained at 50Ω impedance. 9.2 Transmission Line All transmission lines should be designed to have a characteristic impedance of 50Ω. • The length of the transmission lines should be kept to a minimum. • Any other parts of the RF system like transceivers, power amplifiers, etc, should also be designed to have an impedance of 50 Ω. Once the material for the PCB has been chosen, (PCB thickness and dielectric constant), a coplanar transmission line can easily be designed using any of the commercial software packages for transmission line design. For the chosen PCB thickness, copper thickness and substrate dielectric constant, the program will calculate the appropriate transmission line width and gaps on either side of the feed. A DC blocking capacitor should be placed in line to protect the RF front end. 10. Mechanical Fixing The antenna uses 3M 468MP adhesive on the reverse side of the FPC. The antenna has an easy access split line to peel off to reveal the adhesive side. It is designed for a one time fix to a clean smooth surface. FPC back side Split line for easy peel Antennas for Wireless M2M Applications Product Specification Page 8 Dromus Part No. SRF2W012 10.0 Antenna Integration Guide 10.1 Placement For placing the FPC antenna within a device, the host PCB size is not a factor like PCB mounted antennas. However placement still needs to follow some basic rules, as any antenna is sensitive to its environment. Using six spatial directions shown below as a guide. The antenna FPC section should try to maintain a minimum of three directions free from obstructions to be able to operate effectively. The other directions will have obstacles in its path, these directions still require a minimum clearance. These minimum clearances are further defined in this section. The plastic case is not included in this, only metal objects/components that will obstruct or come in close proximity to the antenna. Six spatial directions relative to FPC Example with 4 spatial directions clear Battery FPC PCB Antennas for Wireless M2M Applications Product Specification Page 9 Dromus Part No. SRF2W012 10.2 Orientation of FPC The orientation of the FPC with respect to the host PCB should be defined depending on the unit. The proximity of the GND will have an influence on the antenna so the PCB location relative to the antenna should be considered. The FPC will normally be placed in one of the three following options for orientation. In each option a distance (d) is the critical dimension to consider. Below shows the minimum value of (d) for each. Other obstructions may increase this dimension. 1) Vertical mounted FPC Cable +Connector d ≥ 2mm PCB 1) Co-planar to PCB d ≥ 10mm 2) Planar to PCB (Same plane) d ≥ 2mm Antennas for Wireless M2M Applications Product Specification Page 10 Dromus Part No. SRF2W012 10.3 Device Integration example An example of integration within a device is shown below. The device contains the major components along with the device outer case. The FPC is shown adhered to the inside of the device’s plastic housing. The cable routing is along the edge of the PCB so as not to interfere with any other component. The length of the cable is sufficient to allow ease of assembly when produced (SRF2W012-100). The FPC was placed vertically relative to the PCB. The battery is conductive and is kept the minimum recommended distance away from the FPC of 10mm. The FPC is kept at maximised height above the PCB to ensure it is above the minimum clearance of ≥2mm. This example shows the FPC 5mm above the PCB. For vertical placement relative to PCB d=5mm (min ≥2mm) Distance to battery follows minimum spec for co-planar placement d= 10mm (min ≥10mm) Antennas for Wireless M2M Applications Product Specification Page 11 Dromus Part No. SRF2W012 11. Hazardous Material Regulation Conformance The antenna has been tested to conform to RoHS requirements. A certificate of conformance is available from Antenova M2M’s website. 12. Packaging The antennas are stored in individual plastic (PE) bags, then stored within a second bag of 10pcs. Single antenna per bag 10 units per second bag (Labelled) 12.1 Optimal Storage Conditions Temperature -10ºC to 40ºC Humidity Less than 75% RH Shelf life 24 Months Storage place Away from corrosive gas and direct sunlight Antennas should be stored in unopened sealed manufacturer’s plastic packaging. Packaging The shelf life of the antenna is two years, provided the bag of 10 pieces remains factory- sealed. Antennas for Wireless M2M Applications Product Specification Page 12 Dromus Part No. SRF2W012 12.2 Label Information Antenova Limited Antenova Asia Ltd 4F, No 324, Sec 1, Nei-Hu Road Nei-Hu District, Taipei 11493, Taiwan, ROC 50.00mm info@antenova-m2m.com / www.antenova-m2m.com Description: Dromus Part number: SRF2W012 Quantity: 1000 Date Code: YYWW Manufacturer’s code number: flexiiANT® 70.00mm Antennas for Wireless M2M Applications Product Specification Page 13 Dromus Part No. SRF2W012 www.antenova-m2m.com Corporate Headquarters North America Headquarters Asia Headquarters Antenova Limited 2nd Floor Titan Court Bishop Square Hatfield AL10 9NA UK Antenova Limited 100 Brush Creek Road, Suite 103 Santa Rosa California 95404 USA Antenova Asia Limited 4F, No. 324, Sec. 1, Hei-Hu Road Hei-Hu District Taipei 11493 Taiwan, ROC Tel: +1 847 551 9710 Email: sales@antenova-m2m.com Tel: +886 (0) 2 8797 8630 Fax: +886 (0) 2 8797 6890 Email: sales@antenova-m2m.com Tel: +44 1233 810600 Email: sales@antenova-m2m.com Copyright® Antenova Ltd. All Rights Reserved. Antenova ® , Antenova M2M ® , gigaNOVA ® the Antenova product family names and the Antenova and Antenova M2M logos are trademarks and/or registered trademarks of Antenova Ltd. Any other names and/or trademarks belong to their respective companies. The materials provided herein are believed to be reliable and correct at the time of printing. Antenova does not warrant the accuracy or completeness of the information, text, graphics or other items contained within this information. Antenova further assumes no responsibility for the use of this information, and all such information shall be entirely at the user’s risk. Antennas for Wireless M2M Applications Product Specification PS-SRF2W012-1.0 Release date November 2015 Page 14
SRF2W012-150 价格&库存
很抱歉,暂时无法提供与“SRF2W012-150”相匹配的价格&库存,您可以联系我们找货
