1002428
1002428
    ETHERTRONICS
    Ceramic
    ANTENNA GPS CERAMIC 1.575GHZ
1002428 数据手册
PRODUCT: GPS/GNSS PATCH ANTENNA Part No. 1002428 Embedded GPS Ceramic Patch Antenna GPS/GNSS, 25x25x4 mm KEY BENEFITS Ethertronics’ series of GPS Ceramic Patch Antennas deliver on the key needs of device designers for higher functionality and performance in M2M designs. These innovative antennas provide compelling advantages for GPS enabled M2M applications such as vehicle tracking. DESIGN ADVANTAGES Best in Class Performance  Circularly polarized patch antennas are designed to maintain high efficiency in a variety of device configurations.  Minimal ground clearance and component “keep out” area.  High selectivity eliminates the need for additional filters and frees up board space. Quicker Time-to-Market  Standard part means fewer design changes.  Simple implementation.  Single part works for various PCB sizes and layouts. RoHS Compliant  Ethertronics’ antennas comply with the European RoHS Directive 2002/95/EC. Automotive Application  Ethertronics’ antennas are manufactured according to ISO TS 16949 quality standards. More information is available on our Website at www.ethertronics.com/resources/. END USER ADVANTAGES Superior Range  Greater antenna efficiency means longer range and a better end user experience. Exceptional Coverage  Better coverage results in improved performance in line of sight conditions as well as while inside cars or other areas where signal reflection occurs. Faster Acquisition Times  Users experience faster signal acquisition for GPS readings. SERVICE AND SUPPORT Extensive RF Experience  Our ceramic patch antennas are supported by extensive documentation, and when needed, by the expertise of RF engineers who have integrated hundreds of antenna designs into wireless devices. Global Operations & Design Support  Ethertronics’ global operations encompass an integrated network of design centers that provide local customer support. PRODUCT: GPS/GNSS Antenna - P/N 1002428 Ethertronics’ Embedded GPS/GNSS Ceramic Patch Antenna Specifications Below are the typical specs for a GPS/GNSS applications. Electrical Specifications Typical Characteristics once Patch is on GND plane 60x60mm and under plastic radome PC/ABS Frequency (MHz) S11 (dB) Gain 0˚ XZ-Plane (dBic) Polarization Axial Ratio 1575.42 -11.55 5.26 RHCP 2 dB 1598 -12.93 4.25 RHCP 3 dB 1606 -13.95 3.46 RHCP 3 dB Return Loss in dB Efficiency, in % Peak Gain in dBi ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: GPS/GNSS Antenna - P/N 1002428 Mechanical Specifications Size 25 x 25 x 4 mm Mounting Adhesive (Nitto 5000NS 22x22x0.16mm) and Soldered Pin Packaging Tray Bottom View Top View ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: GPS/GNSS Antenna - P/N 1002428 © 2013 Ethertronics. All rights reserved. Ethertronics, the Ethertronics logo, shaping antenna technology, Isolated Magnetic Dipole and the iMD logo are trademarks of Ethertronics. All other trademarks are the property of their respective owners. Specifications subject to change and are dependent upon actual implementation. 1002428 19 OCT 2013
1002428 价格&库存
很抱歉,暂时无法提供与“1002428”相匹配的价格&库存,您可以联系我们找货
