SRFG017-150
SRFG017-150
    ANTENOVA(安诺亚)
SRFG017-150 数据手册
Bentoni Part No. SRFG017 Bentoni GNSS Antenna Part No. SRFG017 1. flexiiANT ® Product Specification Features         2. Antenna for 1559 – 1609 MHz applications Solution for all global public constellations: GPS, GLONASS, Beidou and GALILEO Maintains high performance within device: DFI (Designed For Integration) 1.13mm diameter RF cable with IPEX MHF connector Self-Adhesive mounted Quick integration minimizes design cycle High performance Available 3 standard cable lengths Description Bentoni is intended for use with all positioning applications. A flexible antenna with cable enables direct connection to the host PCB. Simple integration with plug and play simplicity. This product specification shows the performance of the antenna to cover a typical GNSS reception: 1559 – 1609 MHz. 3. Applications      Trackers Portable devices Drones Network devices Wearable devices Antennas for Wireless M2M Applications Product Specification Page 1 Bentoni Part No. SRFG017 4. Part Number Bentoni: SRFG017-xxx Note. -xxx refers to cable length option: 5. Part Number Cable Length SRFG017-50 50mm SRFG017-100 100mm SRFG017-150 150mm General Data Product name Bentoni Part Number SRFG017 Frequency 1559 – 1609MHz Polarization Linear Operating temperature -40°C to +85°C Impedance with matching 50 Ω Weight < 0.5 g FPC Self-adhesive 3M 468MP Antenna Assembly type Dimensions (Antenna) 40.0 x 14.0 x 0.15 (mm) Cable length 50 /100 / 150 Connection MHF IPEX 6. RF Characteristics 1559 – 1609 MHz Peak gain 4.0dBi Average gain -1.2dBi Average efficiency >75% Maximum return loss -14dB Maximum VSWR 1.45:1 Conditions All data measured in a loaded condition adhered to a plastic carrier free space. Antennas for Wireless M2M Applications Product Specification Page 2 Bentoni Part No. SRFG017 7. RF Performance 7.1 Return Loss 5 [dB] Atyune 0 -5 -10 4 1 -15 3 2 -20 -25 -30 -35 1450 [MHz] 1500 MARKERS: MHz RD8017.s1p - S11 1: 1563 2: 1587 1550 dB 1600 MHz -15.40 -18.18 3: 1597 4: 1609 1650 1700 dB -17.06 -14.76 7.2 VSWR 10 [] Atyune 9 8 7 6 5 4 3 2 1 1 1450 2 3 4 [MHz] 1500 1550 MARKERS: MHz RD8017.s1p - S11 1: 1563 2: 1587 1600 1650 1700 MHz 1.41 1.28 3: 1597 4: 1609 1.33 1.45 Antennas for Wireless M2M Applications Product Specification Page 3 Bentoni Part No. SRFG017 7.3 Antenna patterns 7.3.1 1575 MHz 3D pattern at 1575MHz Drag to rotate pattern and PCB by using Adobe Reader (Click to Activate) Antennas for Wireless M2M Applications Product Specification Page 4 Bentoni Part No. SRFG017 8. Antenna Dimensions 8.1 Dimensions FPC section 2 Holes = 1mm ø (diameter) L W T Length Width Thickness 40.0 ±0.2 (mm) 14.0 ±0.2 (mm) 0.15 (mm) nominal All dimensions in mm 8.2 Dimensions assembled L SRF2W012-50 SRF2W012-100 SRF2W012-150 L L L 57 ±2.0 (mm) 107 ±2.0 (mm) 157 ±2.0 (mm) Antennas for Wireless M2M Applications Product Specification Page 5 Bentoni Part No. SRFG017 8.3 IPEX Connector I-PEX Front Material Copper Alloy Plating Ag Side Back 5.0 3.0 All dimensions in mm 8.4 Assembly 1.13mm ø Cable I-PEX Connector FPC Antennas for Wireless M2M Applications Product Specification Page 6 Bentoni Part No. SRFG017 9. Electrical Interface 9.1 Host Interface The host PCB requires the mating connector which is IPEX MHF (UFL) receptacle. The location should be close to the chip/modules pin for the RF. Any feed from this receptacle should be maintained at 50Ω impedance. 9.2 Transmission Line All transmission lines should be designed to have a characteristic impedance of 50Ω. • The length of the transmission lines should be kept to a minimum • Any other parts of the RF system like transceivers, power amplifiers, etc, should also be designed to have an impedance of 50 Ω Once the material for the PCB has been chosen (PCB thickness and dielectric constant), a coplanar transmission line can easily be designed using any of the commercial software packages for transmission line design. For the chosen PCB thickness, copper thickness and substrate dielectric constant, the program will calculate the appropriate transmission line width and gaps on either side of the feed. A DC blocking capacitor should be placed in line to protect the RF front end. 10. Mechanical Fixing The antenna uses 3M 468MP adhesive on the reverse side of the FPC. The antenna has an easy access split line to peel off to reveal the adhesive side. It is designed for a one time fix to a clean smooth surface. FPC back side Split line for easy peel Antennas for Wireless M2M Applications Product Specification Page 7 Bentoni Part No. SRFG017 10.0 Antenna Integration Guide 10.1 Placement For placing the FPC antenna within a device, the host PCB size is not a factor like PCB mounted antennas. However placement still needs to follow some basic rules, as any antenna is sensitive to its environment. Using six spatial directions shown below as a guide. The antenna FPC section should try to maintain a minimum of three directions free from obstructions to be able to operate effectively. The other directions will have obstacles in its path, these directions still require a minimum clearance. Six spatial directions relative to FPC Antennas for Wireless M2M Applications Product Specification Page 8 Bentoni Part No. SRFG017 10.2 Orientation of FPC The orientation of the FPC with respect to the host PCB should be defined depending on the unit. The proximity of the GND will have an influence on the antenna so the PCB location relative to the antenna should be considered. The FPC will normally be placed in one of the three following options for orientation. In each option a distance (d) is the critical dimension to consider. Below shows the minimum value of (d) for each. Other obstructions may increase this dimension. 1) Vertical mounted FPC Cable +Connector d ≥ 3mm PCB 1) Co-planar to PCB d ≥ 12mm 2) Planar to PCB (Same plane) d ≥ 3mm Antennas for Wireless M2M Applications Product Specification Page 9 Bentoni Part No. SRFG017 10.3 Device Integration example An example of integration within a drone is shown below. The device contains the major components along with the device outer case. The FPC is shown adhered to the inside of the device’s plastic housing. The length of the cable should be chosen to be sufficient to allow ease of assembly when produced (SRFG017-100 in example). The FPC was placed vertically relative to the PCB. The FPC is kept at maximised height above the PCB to ensure it is above the minimum clearance of ≥2mm. This example shows the FPC 5mm above the PCB. For this type of device it is advisable to keep the antenna away from the electric motor cables and motors themselves that may interfere. For vertical placement relative to PCB d=15mm (min ≥2mm) Antennas for Wireless M2M Applications Product Specification Page 10 Bentoni Part No. SRFG017 11. Hazardous Material Regulation Conformance The antenna has been tested to conform to RoHS requirements. A certificate of conformance is available from Antenova M2M’s website. 12. Packaging The antennas are stored in individual plastic (PE) bags. Then stored within a second bag of 10pcs. Single antenna per bag 10 units per second bag (Labelled) 12.1 Optimal Storage Conditions Temperature -10ºC to 40ºC Humidity Less than 75% RH Shelf life 18 Months Storage place Away from corrosive gas and direct sunlight Antennas should be stored in unopened sealed manufacturer’s plastic packaging. Packaging Antennas for Wireless M2M Applications Product Specification Page 11 Bentoni Part No. SRFG017 12.2 Label Information Antenova Limited Antenova Asia Ltd 4F, No 324, Sec 1, Nei-Hu Road Nei-Hu District, Taipei 11493, Taiwan, ROC 60.00mm info@antenova-m2m.com / www.antenova-m2m.com Description: Bentoni Part number: SRFG017 Quantity: 1000 Date Code: YYWW Manufacturer’s code number: flexiiANT ® 90.00m m Antennas for Wireless M2M Applications Product Specification Page 12 www.antenova-m2m.com Corporate Headquarters North America Headquarters Asia Headquarters Antenova Limited nd 2 Floor Titan Court Bishop Square Hatfield AL10 9NA UK Antenova Limited 100 Brush Creek Road, Suite 103 Santa Rosa California 95404 USA Antenova Asia Limited 4F, No. 324, Sec. 1, Nei-Hu Road Nei-Hu District Taipei 11493 Taiwan, ROC Tel: +44 1233 810600 Email: sales@antenova-m2m.com Tel: +1 (707) 890 5202 Email: sales@antenova-m2m.com Tel: +886 (0) 2 8797 8630 Fax: +886 (0) 2 8797 6890 Email: sales@antenova-m2m.com Copyright® Antenova Ltd. All Rights Reserved. Antenova ®, Antenova M2M ®, gigaNOVA ® the Antenova product family names and the Antenova and Antenova M2M logos are trademarks and/or registered trademarks of Antenova Ltd. Any other names and/or trademarks belong to their respective companies. The materials provided herein are believed to be reliable and correct at the time of printing. Antenova does not warrant the accuracy or completeness of the information, text, graphics or other items contained within this information. Antenova further assumes no responsibility for the use of this information, and all such information shall be entirely at the user’s risk. Antennas for Wireless M2M Applications Product Specification DS-SRFG017 1.0 Release date January 2016 Page 13
SRFG017-150 价格&库存
很抱歉,暂时无法提供与“SRFG017-150”相匹配的价格&库存,您可以联系我们找货
