9000130
9000130
    ETHERTRONICS
    RF ANTENNA WLAN
9000130 数据手册
PRODUCT: WLAN Part No. 9000129 & 9000130 PresttaTM WLAN Embedded Antenna 2.4/4.9/5.2/5.8 GHz (802.11 a/b/g/n + Japan) KEY BENEFITS DESIGN ADVANTAGES Ethertronics’ Prestta series of Isolated Magnetic Dipole™ (IMD) trace antennas address the challenges facing today’s product designers. IMD’s high performance and isolation characteristics offer better connectivity and minimal interference. IMD antennas can be used in a variety of devices:  Notebook Computers  Access Points  WiFi enabled Televisions & Monitors TECHNOLOGY ADVANTAGES Stays in Tune IMD antenna technology provides superior RF field containment, resulting in less interaction with surrounding components. Ethertronics IMD antennas resist de-tuning; providing a robust radio link regardless of the usage position. Prestta WLAN antennas use patented IMD technology in a trace configuration to provide high performance. IMD antennas requires a smaller design keep-out area, carry lower program development risk which yields a quicker time-to-market, without sacrificing RF performance. Quicker Time-to-Market  By optimizing antenna size, performance and emissions, customer and regulatory specifications are more easily met. Greater Flexibility  Ethertronics’ first-in-class IMD technology enables you to develop concept designs that are more advanced and that deliver superior performance in receptioncritical applications.  Multiple cable lengths to fit a variety of devices. RoHS Compliant  Ethertronics’ antennas are fully compliant with the European RoHS Directive 2002/95/EC. END USER ADVANTAGES Unique Form Factors Support Advanced Industrial Designs  Smaller, more efficient IMD embedded antennas break through restrictive design rules and provide new freedom in component placement. Superior Range & Signal Strength  Better antenna function means longer range and greater sensitivity to critically precise signals—delivering greater customer satisfaction while building brand loyalty. SERVICE AND SUPPORT Extensive RF Experience  Our WLAN antennas are supported by documentation, and when needed, by the expertise of RF engineers who have integrated hundreds of antenna designs into wireless devices. Global Operations & Design Support  Ethertronics’ global operations supports an integrated network of design centers that can take projects from concept to production. ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: WLAN a/b/g/n + Japan - P/N 9000129 & 9000130 Ethertronics’ Internal (Embedded) Antenna Specifications. Below are the typical specs for a WLAN application. Electrical Specification Typical Characteristics (In reference device housing made of PC/ABS plastic) WLAN a/b/g/n + Japan Antenna (GHz) 4.900-5.100 Japan 5.150-5.350 a 5.35-5.90 a Peak Gain in dBi 2.0 4.0 5.0 6.0 Efficiency 65% 72% 72% 65% < -10.0 < -10.0 < -10.0 Return Loss in dB Feed Point Impedance Mechanical Specification 2.390-2.490 b, g < -10.0 50 Ω unbalanced (other if required) Dimensions 42.0 x 8.0 x 0.8 mm Weight Cable / Connector 0.4 g U.fl Connector, 1.13mm diameter coaxial cable. Cable Length Main Antenna Substrate 100mm cable P/N 9000129: Based on PCB substrate P/N 9000130: Based on FPC substrate Return Loss in dB Efficiency in % ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: WLAN a/b/g/n + Japan - P/N 9000129 & 9000130 Ethertronics’ Internal (Embedded) Antenna Specifications. Below are the typical specs for a WLAN application. 2.4GHz 5GHz © 2013 Ethertronics. All rights reserved. Ethertronics, the Ethertronics logo, shaping antenna technology, Prestta, Savvi, Tavvel, Isolated Magnetic Dipole and the iMD logo are trademarks of Ethertronics. All other trademarks are the property of their respective owners. Specifications subject to change and are dependent upon actual implementation. 9000129 & 9000130 5NOV2013
9000130 价格&库存
很抱歉,暂时无法提供与“9000130”相匹配的价格&库存,您可以联系我们找货
