Mitis Antenna for LTE applications
Part No. SRFL026
1.
flexiiANT ®
Product Specification
Features
2.
Antenna for 4G LTE applications including MIMO systems.
LTE 700, GSM850, GSM900, DCS1800, PCS1900, WCDMA2100, LTE B7
(2500-2690 MHz), LTE B40 (2300 – 2400 MHZ)
1.13mm diameter RF cable with IPEX MHF connector
Self-adhesive mounted
Quick and simple integration minimizes design cycle
Available in 3 standard cable lengths
Description
Mitis is intended for use with 4G LTE applications. This product specification shows
the performance of this antenna in all workable bands. Simplified integration with
plug and play simplicity.
3.
Applications
Smart meters
Network devices
Femto / Pico base stations
Telematics
Remote monitoring
Machine to Machine
POS (Point of Sale) terminals
Antennas for Wireless M2M Applications
Product Specification Mitis-SRFL026-PS-1.1
Page 1
Mitis
Part No. SRFL026
4.
Part Number
Mitis: SRFL026
5.
General Data
Product name
Mitis
Part Number
Polarization
SRFL026
698-798MHz
824-960MHz
1710-2170MHz
2300-2400MHz
2500-2690MHz
Linear
Operating temperature
- 40°C to +85°C
Environmental condition test
ISO 16750-4 5.1.1 / 5.1.2
Impedance with matching
50 Ω
Weight
< 0.5 g
Antenna type
FPC Self-adhesive 3M 468P
Dimensions (Antenna)
110.0 x 20.0 x 0.15 (mm)
Connection
IPEX
Frequency
Page 2
Mitis
Part No. SRFL026
6.
RF Characteristics
698 – 798 MHz
824 – 960 MHz
1710 - 2170 MHz
Peak gain
2.50dBi
2.30dBi
3.50dBi
Average gain
-1.50dBi
-1.60dBi
-1.70dBi
Average efficiency
>55%
>65%
>65%
Maximum return loss
-5.5dB
-10.0dB
-7.0dB
Maximum VSWR
3.20:1
1.95:1
1.90:1
2300 – 2400 MHz
2500 – 2690 MHz
Peak gain
4.00dBi
4.50dBi
Average gain
-170dBi
-1.40dBi
Average efficiency
>55%
>70%
Maximum return loss
-7.0dB
-5.5dB
Maximum VSWR
2.10:1
3.10:1
All data measured in a loaded condition adhered to a 1.6mm
thick plastic carrier free space.
An RF choke was used to prevent cable radiation.
Page 3
Mitis
Part No. SRFL026
7.
RF Performance
7.1 Return Loss
5
[dB]
Atyune
-5
10
9
6
7
8
4
-10
5
2
3
-15
-20
-25
600
[MHz]
700
800
900 1000 1100 1200 1300 1400 1500 1600 1700 1800 1900 2000 2100 2200 2300 2400 2500 2600 2700 2800
MARKERS: MHz
dB
SRFL026.S1P - S11
1: 698 -5.52
2: 798 -12.36
MHz
dB
3: 824 -13.39
4: 960 -10.05
MHz
dB
MHz
5: 1710 -10.62
6: 2170 -7.22
7: 2500
8: 2690
dB
MHz
-7.19
-9.18
dB
9: 2300
10: 2400
-6.24
-5.67
7.2 VSWR
10
Atyune
9
8
7
6
5
4
1
10
9
3
7
6
8
4
2
2
1
600
5
3
[MHz]
700
800
MARKERS: MHz
SRFL026.S1P - S11
1: 698
2: 798
MHz
3.25
1.63
3: 824
4: 960
MHz
1.54
1.92
5: 1710
6: 2170
MHz
1.84
2.54
MHz
7: 2500
8: 2690
2.55
2.07
9: 2300
10: 2400
2.90
3.17
Page 4
Mitis
Part No. SRFL026
7.3 Antenna patterns
7.3.1
698 MHz – 798 MHz
dBi
3D pattern at 745 MHz
Drag to rotate pattern and PCB by using Adobe Reader
(Click to Activate)
Page 5
Mitis
Part No. SRFL026
7.3.2
824 MHz – 960 MHz
dBi
3D pattern at 890 MHz
(Click to Activate)
Page 6
Mitis
Part No. SRFL026
7.3.3
1710 MHz – 2170 MHz
dBi
3D pattern at 1990 MHz
(Click to Activate)
Page 7
Mitis
Part No. SRFL026
7.3.4
2300 MHz – 2400 MHz
dBi
3D pattern at 2350 MHz
(Click to Activate)
Page 8
Mitis
Part No. SRFL026
7.3.5
2500 MHz – 2690 MHz
dBi
3D pattern at 2600 MHz
(Click to Activate)
Page 9
Mitis
Part No. SRFL026
8. Antenna Dimensions
8.1 Dimensions FPC section
L
W
T
Length
Width
Thickness
110.0 ±0.2 (mm)
20.0 ±0.2 (mm)
0.15 (mm) nominal
All dimensions in mm
8.2 Dimensions assembled
L
SRFC026-100
SRFC026-150
SRFC026-200
L
L
L
112 ±2.0 (mm)
162 ±2.0 (mm)
212 ±2.0 (mm)
Page 10
Mitis
Part No. SRFL026
8.3 IPEX Connector
I-PEX
Material
Copper Alloy
Plating
Ag
Front
Back
Side
5.0
3.0
8.4 Assembly
1.13mm ø Cable
I-PEX Connector
FPC
Page 11
Mitis
Part No. SRFL026
9. Electrical Interface
9.1 Host Interface
The host PCB requires the mating connector which is IPEX MHF (UFL) receptacle.
The location should be close to the chip/modules pin for the RF. Any feed from this
receptacle should be maintained at 50Ω impedance.
9.2 Transmission Line
All transmission lines should be designed to have a characteristic impedance of 50Ω.
• The length of the transmission lines should be kept to a minimum
• Any other parts of the RF system like transceivers, power amplifiers, etc, should
also be designed to have an impedance of 50 Ω
Once the material for the PCB has been chosen (PCB thickness and dielectric
constant), a coplanar transmission line can easily be designed using any of the
commercial software packages for transmission line design. For the chosen PCB
thickness, copper thickness and substrate dielectric constant, the program will
calculate the appropriate transmission line width and gaps on either side of the feed.
A DC blocking capacitor should be placed in line to protect the RF front end.
10. Mechanical Fixing
The antenna uses 3M 468MP adhesive on the reverse side of the FPC. The antenna
has an easy access split line to peel off to reveal the adhesive side. It is designed for
a one time fix to a clean smooth surface.
FPC back side
Split line for
easy peel
Page 12
Mitis
Part No. SRFL026
10.0 Antenna Integration Guide
10.1 Placement
For placing the FPC antenna within a device, the host PCB size is not a factor like
with PCB mounted antennas. However placement still needs to follow some basic
rules, as any antenna is sensitive to its environment.
Using six spatial directions shown below as a guide. The antenna FPC section
should try to maintain a minimum of three directions free from obstructions to be able
to operate effectively. The other directions will have obstacles in their paths, these
directions still require a minimum clearance. These minimum clearances are further
defined in this section. The plastic case is not included in this, only metal
objects/components that will obstruct or come in close proximity to the antenna.
Six spatial directions relative to FPC
Page 13
Mitis
Part No. SRFL026
10.2 Orientation of FPC
The orientation of the FPC with respect to the host PCB should be defined
depending on the unit. The proximity of the GND will have an influence on the
antenna so the PCB location relative to the antenna should be considered.
The FPC will normally be placed in one of the three following options for orientation.
In each option a distance (d) is the critical dimension to consider. Below shows the
minimum value of (d) for each. Other obstructions may increase this dimension.
1) Vertical mounted
FPC
Cable +Connector
d ≥ 3mm
PCB
1) Co-planar to PCB
d ≥ 15mm
2) Planar to PCB (Same plane)
d ≥ 3mm
Page 14
Mitis
Part No. SRFL026
11. Hazardous Material Regulation Conformance
The antenna has been tested to conform to RoHS requirements. A certificate of
conformance is available from Antenova M2M’s website.
12. Packaging
The antennas are stored in individual plastic (PE) bags. Then stored within a second
bag of 10pcs.
Single antenna per bag
10 units per second bag (Labelled)
12.1 Optimal Storage Conditions
Temperature
-10ºC to 40ºC
Humidity
Less than 75% RH
Shelf life
18 Months
Storage place
Away from corrosive gas and direct sunlight
Antennas should be stored in unopened sealed manufacturer’s
plastic packaging.
Packaging
The shelf life of the antenna is 18 months, provided the bag of 10 pieces remains factory
sealed.
Page 15
Mitis
Part No. SRFL026
12.2 Label Information
Antenova Limited
Antenova Asia Ltd
4F, No 324, Sec 1, Nei-Hu Road
Nei-Hu District, Taipei 11493, Taiwan, ROC
60.00mm
info@antenova-m2m.com / www.antenova-m2m.com
Description: Mitis
Part number: SRFL026
Quantity: 10
Date Code: YYWW
Manufacturer’s code number:
flexiiANT
90.00m
m
Page 16
Mitis
Part No. SRFL026
Corporate Headquarters
North America Headquarters
Asia Headquarters
Antenova Limited
nd
2 Floor Titan Court
3 Bishop Square
Hatfield
AL10 9NA
UK
Antenova Limited
100 Brush Creek Road, Suite 103
Santa Rosa
California 95404
USA
Antenova Asia Limited
4F, No. 324, Sec. 1, Nei-Hu Road
Nei-Hu District
Taipei 11493
Taiwan, ROC
Tel: +1 707 890 5202
Email: sales@antenova-m2m.com
Tel: +886 (0) 2 8797 8630
Fax: +886 (0) 2 8797 6890
Tel: +44 1223 810600
Copyright® Antenova Ltd. All Rights Reserved. Antenova ®, Antenova M2M ®, gigaNOVA ®, the Antenova
product family names, and the Antenova and Antenova M2M logos are trademarks and/or registered trademarks
of Antenova Ltd. Any other names and/or trademarks belong to their respective companies.
The materials provided herein are believed to be reliable and correct at the time of printing. Antenova does not
warrant the accuracy or completeness of the information, text, graphics or other items contained within this
information. Antenova further assumes no responsibility for the use of this information, and all such information
shall be entirely at the user’s risk.
Product Specification Mitis-SRFL026-PS-1.1 released May 2016 revised June 2016
Page 17
很抱歉,暂时无法提供与“SRFL026-200”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+49.98240
- 200+19.94760
- 500+19.27800
- 1000+18.95400
