SRF2I019-200
SRF2I019-200
    ANTENOVA(安诺亚)
    Montana是一款适用于ISM和LoRa应用的柔性天线,带有电缆,可直接连接到主机PCB,便于集成。
SRF2I019-200 数据手册
Montana ISM Antenna Part No. SRF2I019 1. flexiiANT ® Product Specification Features        2. Antenna for ISM bands (863 – 870MHz and 902 - 928MHz) Maintains high performance within device: DFI (Designed For Integration) 1.13mm diameter RF cable with IPEX MHF connector Self-Adhesive mounted Quick integration minimizes design cycle High performance Available 3 standard cable lengths Description Montana is intended for use with ISM applications. A flexible antenna with cable enables direct connection to the host PCB. Simple integration with plug and play simplicity. This product specification shows the performance of the antenna to cover a typical dual band ISM from 863 – 928MHz. 3. Applications      Remote Sensors Smart meters Medical devices Monitoring equipment Automotive devices Antennas for Wireless M2M Applications Product Specification Page 1 Montana Part No. SRF2I019 4. Part Number Montana: SRF2I019-xxx Note. -xxx refers to cable length option: 5. Part Number SRF2I019-100 Cable Length 100mm SRF2I019-150 150mm SRF2I019-200 200mm General Data Product name Montana Part Number SRF2I019 Frequency 863-928MHz Polarization Linear Operating temperature -40°C to +85°C Impedance with matching 50 Ω Weight < 0.5 g Antenna Assembly type FPC Self-adhesive Dimensions (Antenna) 232 x pi x 0.15 (mm) Cable length 100 / 150 / 200 (mm) Connection MHF IPEX 6. RF Characteristics Typical performance Peak gain 1.9dBi Average gain -2.4dBi Average efficiency >50% Maximum return loss
SRF2I019-200 价格&库存
很抱歉,暂时无法提供与“SRF2I019-200”相匹配的价格&库存,您可以联系我们找货
