ANT-DB1-HDP-TNC
ANT-DB1-HDP-TNC
    LINXTECHNOLOGIES(灵思)
    SMD
    ANT-DB1-HDP-TNC
ANT-DB1-HDP-TNC 数据手册
ANT-DB1-HDP-xxx Data Sheet by Product Description The HDP Series is a compact, center-fed antenna that achieves efficient operation at any or all three frequency bands. Its durable, unobtrusive housing attaches permanently with integral adhesive to flat, non-conductive surfaces such as windows, drywall, ceiling tiles, plastic, etc. The antenna is supplied with 9.8 feet (3 m) of RG-174 cable and can be terminated in a TNC, standard SMA or FCC Part 15 compliant RP-SMA connector. 132.3 mm (5.23") 12.1 mm (0.48") Features 20.0 mm (0.79") • Tri-band (824–960MHz, 1.71–1.99GHz and 2.401–2.483GHz) • Center-fed from the side • Surface-mount • Low VSWR • Excellent performance • Omni-directional pattern • Fully weatherized, durable & unobtrusive • TNC, SMA or RP-SMA connector 14.0 mm (0.55") TNC connector 7.9 mm (0.31") SMA, RP-SMA connector Electrical Specifications Recm. Freq. Range: Band 1: 824–960MHz Band 2: 1.71–1.99GHz Band 3: 2.40–2.48GHz Wavelength: ½-wave VSWR: Band 1: ≤1.5 typ. at center Band 2: ≤1.9 typ. at center Band 3: ≤1.9 typ. at center Peak Gain: Band 1: 0.2dBi Band 2: –3.3dBi Band 3: 0dBi Impedance: 50-ohms Connector: TNC, SMA or RP-SMA Cable: 9.8' (3 m) RG-174 coax Oper. Temp. Range: –40°C to +80°C Ordering Information ANT-DB1-HDP-TNC (with TNC connector) ANT-DB1-HDP-SMA (with SMA connector) ANT-DB1-HDP-RPS (with RPS connector) –1– Revised 12/4/13 VSWR Graph VSWR 3:1 1.228 1.438 1.282 Reflected Power 25% 2:1 11% 1:1 0% CENTER 910.000MHz CENTER 1 825.000MHz CENTER 2 450.000MHz SPAN 200.000MHz What is VSWR? The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load versus the voltage wave that is reflected back from the load. A perfect match will have a VSWR of 1:1. The higher the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side note, since the “:1” is always implied, many data sheets will remove it and just display the first number. How to Read a VSWR Graph VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s operational center frequency. In most cases, this will be different than the designed center frequency due to fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1. 159 Ort Lane, Merlin, OR, US 97532 Phone: +1 541 471 6256 Fax: +1 541 471 6251 www.linxtechnologies.com –2– Data Sheet ANT-DB1-HDP-xxx by
ANT-DB1-HDP-TNC 价格&库存
很抱歉,暂时无法提供与“ANT-DB1-HDP-TNC”相匹配的价格&库存,您可以联系我们找货
