ANT-DB1-RMT-TNC
ANT-DB1-RMT-TNC
    LINXTECHNOLOGIES(灵思)
    ANT-DB1-RMT-TNC
ANT-DB1-RMT-TNC 数据手册
ANT-DB1-RMT-xxx Data Sheet by Product Description 27.4 mm (1.08") Designed for permanent mounting through a metal surface such as an automobile roof or trunk, this compact RMT antenna offers outstanding performance in a durable and futuristic housing. The antenna may be operated at either or both of two frequency bands. It is supplied with 14.1 feet (4.3 m) of RG-58 cable and can be terminated in a standard SMA, FCC Part 15 compliant RP-SMA connector or a TNC connector. 14.0 mm (0.55") 41.9 mm (1.65") 93.7 mm (3.69") 27.5 mm (1.08") Features • • • • • • • • • 8.0 mm (0.31") Dual-band (824–960MHz and 1.71–1.99GHz) Compact & futuristic Through-hole mount Low VSWR Excellent performance Omni-directional pattern Fully weatherized Durable construction SMA, RP-SMA or TNC connector 7.0 mm (0.28") 44.0 mm (1.73") Standard 13.34–13.97 mm (0.525–0.550") Suggested Mounting Holes Anti-Rotation 11.48–11.56 mm (0.452–0.455") 11.3 mm (0.44") Electrical Specifications 13.1 mm (0.52") Recom. Freq. Range: Band 1: 860–960MHz Band 2: 1.71–1.88GHz Wavelength: ¼-wave VSWR: Band 1: ≤ 1.5 typ. at center Band 2: ≤ 2.7 typ. at center Impedance: 50-ohms Oper. Temp. Range: –40°C to +80°C Connector: SMA, RP-SMA or TNC Cable: 14.1' (4.3 m) RG-58 coax Ordering Information ANT-DB1-RMT-SMA (with SMA connector) ANT-DB1-RMT-RPS (with RP-SMA connector) ANT-DB1-RMT-TNC (with TNC connector) –1– Revised 12/11/13 VSWR Graph VSWR 1.354 1.791 Reflected Power 3:1 25% 2:1 11% CENTER 868.000MHz CENTER 1 800.000MHz SPAN 200.000MHz What is VSWR? The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load versus the voltage wave that is reflected back from the load. A perfect match will have a VSWR of 1:1. The higher the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side note, since the “:1” is always implied, many data sheets will remove it and just display the first number. How to Read a VSWR Graph VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s operational center frequency. In most cases, this will be different than the designed center frequency due to fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1. –2– Data Sheet ANT-DB1-RMT-xxx by
ANT-DB1-RMT-TNC 价格&库存
很抱歉,暂时无法提供与“ANT-DB1-RMT-TNC”相匹配的价格&库存,您可以联系我们找货
