ANCF2-1MMQW
ANCF2-1MMQW
    MULTI-TECHSYSTEMS
    ANTENNA DIPOLE 850MHZ 1.9GHZ
ANCF2-1MMQW 数据手册
Specifications Manufacturer Boboto Model TQC-800/1900-3A Type Mag Mount Frequency 850/1900 MHz Polarization Vertical Gain 3dBi Impedance 50 Ohms VSWR 2.0 : 1 Wave 1/4 Wave Dipole Connector SMA Coax Cable RG174 Housing ABS/PVC Color Black RoHS Compliant Yes 7.62 .2 105 2 28.5 .2 3000mm ALL DIMENSIONS IN mm -NOTICEThis drawing may contain confidential and proprietary information of Multi-Tech Systems Inc.. It is loaned for limited purposes only and remains the property of Multi-Tech Systems Inc.. It may not be reproduced in whole or part without written consent. This drawing is to be returned upon request. Uncontrolled when printed. Title Drawn 850/1900 MHz Mag Mt Antenna Checked Dean Brandt 12/12/08 Approved Scale NONE Size Dwg. No. A Sheet 1 of 1 ANCF2-1MMQW 45009707L Rev. -
ANCF2-1MMQW
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外发射二极管。
2. 器件简介:EL817是一种红外发射二极管,用于红外线发射,常用于遥控器等设备。
3. 引脚分配:EL817有两个引脚,分别为阳极和阴极。
4. 参数特性:工作电压范围为1.4V至1.8V,工作电流为50mA,发射波长为940nm。
5. 功能详解:EL817主要功能是发射红外光,用于无线通信。
6. 应用信息:广泛应用于遥控器、红外线通信等领域。
7. 封装信息:EL817采用黑色环氧树脂封装,尺寸为3.4mm x 1.6mm。
ANCF2-1MMQW 价格&库存
很抱歉,暂时无法提供与“ANCF2-1MMQW”相匹配的价格&库存,您可以联系我们找货
