EXC450PE
EXC450PE
    LAIRD(莱尔德)
    ANT TWO-WAY 450-470MHZ PE CONN
EXC450PE 数据手册
EXC Two-Way Radio Antenna EXC400 Today’s work and lifestyles require us to communicate anytime, anywhere whether on the move or sitting still. Bluetooth and 802.11 standards make wireless connections to computer networks and other devices possible, while at the same time enabling freedom of movement. Laird's practical and rugged external wireless device antennas are designed to fit into the portable devices used in office, industrial and home environments. The antennas feature flexible elements and many are ½ wave coaxial dipole design for reduced ground dependence and improved performance. FEATURES MARKETS • • • • • • For Bluetooth & IEEE 802.11b/g devices Injection molded ¼ wave flexible cable antenna High durability, high efficiency Textured finish with strain-relief base Available in various standard connectors An original ‘Tuf Duck’ antenna eter SPECIFICATION Frequency Range UHF Trunking/Cellular VSWR 1.5:1 max at resonance Polarization Vertical Nominal Impedance 50 ohms Temperature Range -40°C to +85°C Power Rating 50 Watts Drop Test M PART# FREQUENCY BAND EXC400 400-420 MHz EXC410 EXC420 The EXC model antenna is available in the following frequencies and connectors. Order by antenna model, frequency and connector. For example: EXC450MX. Length of each antenna will vary according to the connector chosen. CONNECTORS AVERAGE LENGTH BN, BNX, KR, MD, MX, MXI, SF, SFU, SM, SMV, TN & TNX 6.75” – 7.0” SMI 420-450 MHz EXC440 BN, BNX, KR, MD, MX, SF, SFU, SM, SMV, TN & TNX 6.75” – 7.0” SMI EXC450 450-470 MHz BN, BNX, KR, MD, MX, MXI, SF, SFU, SM, SMV, TN & TNX 6.39” – 6.9” EXC470 470-512 MHz BN, BNX, KR, MD, MX, MXI, SF, SFU, SM, SMV, TN & TNX 6.13” – 6.7” EXC806 806-866 MHz BN, BNX, KR, MD, MX, SF, SFU, SM, SMV, TN & TNX 3.7” – 4.6” EXC902 902-960 MHz BN, BNX, KR, MD, MX, SF, SFU, SM, SMV, TN & TNX 3.5” – 3.65” Specifications subject to change without notice.according to the connector chosen. Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com ANT-DS-EXC400 0115 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trademarks or registered trademarks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
EXC450PE
物料型号:EXC400
器件简介:Laird的双向无线电天线设计用于便携式设备,适用于办公室、工业和家庭环境。这些天线具有柔性元件,许多是半波长同轴偶极设计,减少了对地面的依赖,提高了性能。
引脚分配:文档中没有提供引脚分配信息。
参数特性: - 频率范围:UHF集群/蜂窝 - VSWR(电压驻波比):在谐振时最大为1.5:1 - 极化:垂直 - 标称阻抗:50欧姆 - 温度范围:-40°C至+85°C - 功率等级:50瓦特 - 跌落测试:1米
功能详解:天线具有高耐用性和高效率,表面有纹理处理,带有应力释放底座。
应用信息:适用于蓝牙和IEEE 802.11b/g设备。
封装信息:天线有多种标准连接器可供选择,包括BN、BNX、KR、MD、MX、MXI、SF、SFU、SM、SMV、TN和TNX等。不同频率和连接器的天线长度会有所不同。
EXC450PE 价格&库存
很抱歉,暂时无法提供与“EXC450PE”相匹配的价格&库存,您可以联系我们找货
