EXS144SFU
EXS144SFU
    LAIRD(莱尔德)
    ANT TUF DUCK VHF 144-148MHZ SFU
EXS144SFU 数据手册
EXS Two-Way Radio Antenna FEATURES • Injection molded 1/4 wave helical ‘slim mini’ antenna • High durability, high efficiency • Textured finish with strain-relief base • Available in various standard connectors • An original ‘Tuf Duck’ antenna arameter SPECIFICATION Frequency VHF Trunking / Cellular Polarization Vertical Nominal Impedance 50 ohms VSWR 1.5:1 max at resonance Power Rating 50 watts Temperature Range -40°C to +85°C Drop Test 1M ors PART# FREQUENCY BAND CONNECTORS th EXS118 118-127 MHz V 5.1” EXS127 127-136 MHz V 3.62” - 4.4” EXS136 136-144 MHz V 3.62” - 4.4” EXS144 144-148 MHz V 3.55” - 4.45” EXS150 150-162 MHz V 3.5” - 4.39” EXS155 155-164 MHz V 3.45” - 4.2” EXS161 161-174 MHz MXI & SMI 3.5” EXS164 164-174 MHz V 3.3” - 3.95” EXP902 806-866 MHz SF & TN - The EXS model antenna is available in the following frequencies and connectors. Order by antenna model, frequency and connector. For example: EXS150MX. Length of each antenna will vary according to the connector chosen. Americas: +1.847 839.6925 IAS-AmericasSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: IAS-AsiaSales@lairdtech.com Middle East & Affrica: +44.1628.858941 IAS-MEASales@lairdtech.com www.lairdtech.com ANT-DS-EXS 1216 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. Responsibility for the use and application of Laird Technologies materials rests with the end user, since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness, merchantability or suitability of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2016 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trade marks or registered trade marks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
EXS144SFU
物料型号:EXS系列天线,包括EXS118、EXS127、EXS136、EXS144、EXS150、EXS155、EXS161和EXS164等型号,以及EXP902。
器件简介:这些天线是注塑成型的1/4波长螺旋“迷你”天线,具有高耐用性和高效率,表面有纹理并配有抗拉基座。
引脚分配:文档中没有提供引脚分配信息。
参数特性: - 频率:VHF集群/蜂窝 - 极化:垂直 - 标称阻抗:50欧姆 - VSWR(电压驻波比):在谐振时最大1.5:1 - 功率等级:50瓦 - 温度范围:-40°C至+85°C - 跌落测试:1米
功能详解:文档中没有提供详细的功能解释。
应用信息:这些天线适用于VHF集群和蜂窝通信,具有多种标准连接器,并且具有高耐用性。
封装信息:天线的平均长度会根据所选连接器而变化。
联系信息:文档提供了美洲、欧洲、亚洲、中东和非洲的联系方式。
版权信息:Laird Technologies, Inc. 版权所有。
EXS144SFU 价格&库存
很抱歉,暂时无法提供与“EXS144SFU”相匹配的价格&库存,您可以联系我们找货
