CAF94166(IO2450-NF06)
    LAIRD(莱尔德)
    ANTENNA2400-2500MHZ3DBINFML
CAF94166(IO2450-NF06) 数据手册
Model Number: 2.4 GHz Sphere IO2450 Omnidirectional In-Building Antenna Specifications: Element Type Frequency Range Peak Gain Polarization1 Impedance Maximum Input Power VSWR (Min. Performance) Dimensions (L x W x H) Housing Operating Temperature Storage Temperature Air-Loaded Patch 2.4 – 2.5 GHz 3 dBi Linear 50 ohms 50 watts 1.5:1 6.4 x 6.3 x 1.7 cm ABS -40º to +70ºC -40º to +70ºC 1 Contains both vertical and horizontal components, the ratio of which varies with the spatial location. Mounting: Includes metal clip for mounting to a ceiling tile grid Cables & Connectors: Model # IO2450-NF06 IO2450-NF12 IO2450-RN12 IO2450-SM12 IO2450-MX17 IO2450-LU18 IO2450-NM18 IO2450-RT36 IO2450-RT60 IO2450-RT84 Reference # CAF94166 CAF94170 CAF94120 CAF94101 CAF95991 CAF95977 CAF94119 CAF94150 CAF94674 CAF94672 Azimuth Plenum Rated Coax 6" RG-142 12" RG-142 12" RG-142 12" RG-142 17" RG-142 & RG-316 18" RG-142 & RG-178 18" RG-142 36" RG-142 60" RG-142 84" RG-142 Connector N-Female N-Female RP-N-Female SMA-Male Straight MMCX Plug Straight Lucent Plug N- Male RP-TNC RP-TNC RP-TNC Elevation Plane phi=0 Specifications subject to change without notice. 3425 N.44th Street, LINCOLN, NE 68504 USA PHONE: 402.467.4491 • FAX: 402.467.4528 TECHNICAL SUPPORT: 888.454.6914 www.centurion.com • sales@centurion.com Copyright  2004 Centurion Wireless Technologies, Inc. All Rights Reserved Pattern data files for LANPlanner are available at www.centurion.com or www.wirelessvalley.com. Omni Plane phi=90 IO2450a – 4/12/04
CAF94166(IO2450-NF06) 价格&库存
很抱歉,暂时无法提供与“CAF94166(IO2450-NF06)”相匹配的价格&库存,您可以联系我们找货
