OD49M-6
OD49M-6
    LAIRD(莱尔德)
    ANT OMNIDIR 6BI 4.9GHZ N MALE
OD49M-6 数据手册
TM Omni Antennas ODxxM 2.4-5.85 GHZ VERTICALLY POLARIZED OMNIDIRECTIONAL ANTENNA The Mesh Series™ omnidirectional antenna systems offered by Laird are designed with mesh networking in mind. With their waterproof N male connector they can be easily mounted to an enclosure like the die-cast enclosure (DCE-7x6x2) to give total wireless coverage. Various gains and frequencies are available. They are constructed of UV resistant materials and are waterproof for a long service life. FEATURES s • Mesh networking vertically polarized omni-directionals • Various gains available: 5dBi to 12dBi • Various frequencies available: 2.4GHz 3.5GHz, 4.9GHz, 5GHz, also tri-band model • Type N male integrated connector • Rugged, lightweight, and waterproof • • • • • • Mesh networking applications 2 to 6 GHz wireless applications Point to multi-point systems Base station antennas WiFi access points WiMax base stations PARAMETER VSWR Impedance Input power Rate wind velocity Operating temperature Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com 1.5:1 50 ohm 10W 125 mph (56 m/sec) -40 - +70°C MODEL FREQ. (MHz) GAIN VERT BW WEIGHT OD24M-5 2400-2485 5dBi 25° 0.5 lbs (0.2 kg) 12 x 0.6 in (355 x 15 mm) DIM (L x DIA) OD24M-7 2400-2485 7dBi 18° 0.6 lbs (0.3 kg) 21 x 0.6 in (540 x 15 mm) OD24M-9 2400-2485 9dBi 14° 0.8 lbs (0.4 kg) 27 x 0.6 in (690 x 15 mm) OD24M-12 2400-2485 12dBi 7° 1.4 lbs (0.6 kg) 48 x 0.6 in (1220 x 15 mm) OD35M-10 3400-3600 10dBi 14° 1.1 lbs (0.5 kg) 27 x 0.6 in (690 x 15 mm) OD49M-6 4940-4990 6dBi 30° 1.5 oz (43 g) 7 x 0.5 in (175 x 13 mm) OD49M-11 4940-4990 11dBi 5° 1.1 lbs (0.5 kg) 31 x 0.6 in (787 x 15 mm) OD5WM6 5150-5850 6dBi 8.5° 5 oz (0.14 kg) 19 x 0.6 in (483 x 15 mm) OD58M-12 5400-5850 12dBi 7° 0.65 lbs (0.5 kg) 27.5 x 0.6 in (700 x 15 mm) Mesh SeriesTM Omni Antennas ODxxM s OD24M-5 E-Plane OD24M-7 E-Plane OD24M-9 E-Plane OD24M-12 E-Plane OD49M-11D1 E-Plane OD49M-6 E-Plane OD58M-12 OD5WM-6 SYSTEM ORDERING OD M- Frequency Gain 24 = 2400 to 2485 MHz 35 = 3400 to 3600 MHz 49 = 4940 to 4990 MHz 58 = 5400 to 5858 MHz 5W = 5150 to 5850 MHz 5 = 5dBi 12 = 12dBi Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com ANT-DS-ODxxM 0115 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trademarks or registered trademarks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
OD49M-6 价格&库存
很抱歉,暂时无法提供与“OD49M-6”相匹配的价格&库存,您可以联系我们找货
