Specification
ISA.06.A.301111
Part No
Product Name
0dBi 400~470MHz UHF Band Low Profile
Adhesive Mount Antenna for Plastic Surfaces
For ISM/ TETRA/CDMA 450/ SCADA
Family Radio Service/General Mobile Radio Service/Bio-Medical
Telemetry
Features
239*42*11mm
Robust, Heavy Duty, Semi-Flexible, Low profile
Omnidirectional
Wide-band response from 400Mhz to 470MHz
IP67 Waterproof (Internal PCB)
3M Adhesive for easy mounting
Standard 3 meters RG174 cable
SMA(M) Connector
Cables and Connectors Fully Customizable
RoHS Compliant
SPE-13-8-006/D/WY
Page 1 of 11
1. INTRODUCTION
The ISA.06 is an omnidirectional 400MHz to 470MHz UHF band antenna with IP67 level
protection antenna for internal or external applications. The housing is made of robust TPR and
can flex up to 20 degrees to fit curved surfaces.
Unlike our competitors, Taoglas shows full performance data for our antennas. The ISA.06 shows
real gain figures and radiation patterns INCLUDING cable losses, tested in state of the art low
frequency anechoic chambers. We have invested heavily in research to create a uniquely wideband UHF antenna with minimum 70MHz bandwidth that can replace expensive externally
mounted antenna solutions. The wide-band compared to other narrow-band 20MHz antennas
delivers more stable performance in more environments with more resistance to detuning. All
low frequency UHF antennas need to be tuned to suit their mounting environment. For this
reason this antenna is tuned to be mounted on plastic surfaces (i.e. excluding metal or glass
mounting), so is ideal for covert non-obtrusive placement in vehicles.
For glass-mount
applications please use ISA.01.
Typical applications are in law enforcement (Tetra and public safety), remote telemetry, public
transportation, mining,
At only 10.5mm thick and 42mm in width, its semi-flexible properties and strong 3M automotive
approved double-sided adhesive allows for convenient installation. The standard cable is 3
meters RG174 coaxial cable.
Cable length and connector type are fully customizable
The ISA.06 can be customized for other low frequency bands for a minimum order quantity.
Please contact your local Taoglas sales office.
SPE-13-8-006/D/WY
Page 2 of 11
2. Specification
ISM
Frequency
Peak Gain
410
433
450
470
MHz
Cable 1m
2.0
0.1
-1.5
-1.0
dBi
Cable 2m
1.2
-2.3
-2.5
-1.8
dBi
0.5
1.5
0.8
-0.2
dBi
Average Gain *
Cable 3m
-5.0
-3.5
-4.5
-4.8
dBi
Efficiency *
30
45
35
33
Return Loss *
-9.0
很抱歉,暂时无法提供与“ISA.06.A.301111”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+139.00997100+17.98306
