WRL-13982
WRL-13982
    SPARKFUNELECTRONICS
    WRL-13982
WRL-13982 数据手册
  Telescopic Antenna SMA - 300 MHz to 1.1 GHz (ANT700) W R L- 139 82 Description: This ANT700 is a telescopic antenna designed for operation from 300 MHz to 1.1 GHz with a total length that is configurable from 9.5 cm to 24.5 cm. Each ANT700 is constructed of stainless steel and features an SMA male connector, rotating shaft, and adjustable elbow. The ANT700 is a 50 Ohm antenna designed to match HackRF One. It is the perfect first antenna for general purpose use with HackRF One, but we won’t stop you from using it with different projects! https://www.sparkfun.com/products/13982 9/14/2016
WRL-13982 价格&库存
很抱歉,暂时无法提供与“WRL-13982”相匹配的价格&库存,您可以联系我们找货
